RE: Dying Xtreme parts
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> RE: Dying Xtreme parts
Page: <<   < prev  1 [2]
Login
RE: Dying Xtreme parts - 12/4/2007 6:09:21 PM
eat2muchrice
Status: offline
can you dye it in rainbow swerls and put peace sign decales on so we can call it a hippy helli.
_____________________________
<<--- My dogs first look and sniff at her worst nightmare.
(in reply to SomeJerk)
       Post #: 26
RE: Dying Xtreme parts - 12/4/2007 6:14:31 PM
Tom Z
Status: offline
quote:
ORIGINAL: stump3r
Michael, any idea if we can dye the white super-skids? I'm feeling that modding sensation coming on something fierce! Solo you have the white skids on your falcon do you not?
You can dye the white super-skids.
Gary (super-skids.com) told me he uses Rit Dye to dye the skids you see on his web site.
He sent me his procedure on how to do it.
If it's OK by Gary and soloboss I'll post it here.
Tom
Blade CX2 (V2), Esky Belt-CP, T-Rex 450 SA
(in reply to stump3r)
       Post #: 27
RE: Dying Xtreme parts - 12/4/2007 6:34:35 PM
Tom Z
Status: offline
I dyed my Xtreme parts with Rit Dye and they came out great. Here are some pictures.
I have used Gary's (super-skids.com) and steersman’s (boomtownhobbies.com) procedures and both work very well.
Tom
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to soloboss)
       Post #: 28
RE: Dying Xtreme parts - 12/5/2007 3:09:30 AM
soloboss
Status: offline
Hey Stump3r - Yep, I am currently sporting the white skids on the Falcon. Honestly the green canopy with the black / white trim and the white skids don't look half bad - or even all bad. I mean they look OK. Ya know what I mean? Wheww!
ANYHOW, There's no doubt that I''m gonna dye the skids and tail junk to some color, but it has to be a light color or it won't stand out against the black boom, struts and tail rotor.
I kept trying to dye the canopy for the CX - I heated the water really hot and held it under for a long time - but it JUST WOULDN'T DYE!!!
So I gave up.
I'll paint it.
I'm thinking WD-40 Blue and Yellow. lol
I like the color of the CX but I won't use the same color on the F40. I'm not going for the sibling look. I'll probably look around for a Walkera clone canopy with a cool look and then color the white bits to complement that. I like the F40 canopy, but what appears to be dark tinted plastic for the windshield is actually black. The black hides the innards, but I like to see the mechanical stuff. And I might actually get to see that the 4 in 1 does arm before I fly.
Ya know what I discovered about the super skids? Well I'll tell you what I discovered. After replacing two stock tail booms due to blade strikes and shattered booms, I discovered that the wing thing above the tail struts is in just the right place to deflect the rotor tips. No more blade strikes on the boom! Simply elegant, don't you think?
TOM Z - By now I'm sire you have seen the post from Stersman about dying the Xtreme parts. If you have additional tips or information for the soon to be dyed, please don't hold back. Good information is always accepted.
A giggle for y'all - In Fort Wayne we have a hospital helicopter. It's the Samaritan from Park View Hospital. Before the helicopter was named Samaritan it was nearly named the Park Chop. Sorry, I thought it was funny.
Soloboss
If everyone''s thinking alike, then somebody isn''t thinking. George Patton
       Post #: 29
RE: Dying Xtreme parts - 12/5/2007 3:20:52 AM
stump3r
Status: offline
Excellent news on the super-skids taking the dye! I guess I'm dying to dye? Sorry had to do it. Thanks for the info guys. Now for the color scheme for the old #4!
Life is tough. Its even tougher when your stupid! - John Wayne
CX2, Gaui 200SD, HBKII FP, CX450SEV2, DX7
       Post #: 30
RE: Dying Xtreme parts - 12/5/2007 3:32:59 PM
Tom Z
Status: offline
Just got permission from Gary (super-skids.com) to post his Dye procedure.
Thanks Gary!
Tom
This is for the real (or authentic) SuperSkids only, and may not work on other brands.
I'd use the correct color if you can find it or mix it (as opposed to using a darker color and dying for less time).
Most parts take about 15 minutes, I think, but it depends on how strong you make the mixture.
Check one of the parts often to make sure they aren't getting too dark.
If they do get a bit too dark, you can lighten them a little by washing them in soapy water right away.
The tail saver bead and skid caps don't like the dye very much because they're made out of silicon.
You get a slight tint after a few hours. Some people leave them in the dye for a day or so and
then use a marking pen to help color them, or they just leave them white or use black.
On my red dyed landing gear, I left them white.
I usually cut a gallon milk jug in half to make a 6" deep bowl out of the bottom (so it's disposable).
I wash the parts with soapy water, rinse them well and let them dry. I add about 2 or 3 cups of
hot water (microwave to a boil) to my bowl and about half a pack of powdered Rit Dye and mix it good.
After I dye them and get the color I want, I rinse them off (cold or room temperature water) so they
don't dye more.
If you just let them air dry after taking them out of the dye, the color could continue to change.
If you've done all the steps properly; washed the parts first and rinsed them thoroughly, dyed them,
taken them out and rinsed them, and the color doesn't look good, the problem is in the plastic or the mold.
I've been doing this for a long time. If the color comes out blotchy, dark in some areas and light in others,
it's not a good quality plastic. If the surface has texture, but it's not uniform, don't even bother trying
to dye the part.
Shiny areas (which are usually near the mold lines or seams) will not generally even take the dye, or they'll
take it much slower than the other areas. This is a sign of poor tooling in making the molds.
Shiny spots in other areas are a sign of poor molding technique. If you look at a part and it has a lot of
flashing left at the seams, chances are your dye job won't come out good because it's a sign of poor quality molds.
Edit: 12-6-07
Just added more information from Gary
< Message edited by Tom Z -- 12/6/2007 10:50:32 PM >
       Post #: 31
RE: Dying Xtreme parts - 12/8/2007 6:53:58 AM
heli8mymoney
Status: offline
Great Info! Now there are way too many possibilities. Did a quick photochop mock up of a few colors. Any wild color scheme ideas???
No I don't plan on using pink.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Tom Z)
       Post #: 32
RE: Dying Xtreme parts - 12/8/2007 11:32:09 AM
HELINTX
Status: offline
Great job Heli8. Now I have some ideas! The black and green is cool and I also like the black and white.
(in reply to heli8mymoney)
       Post #: 33
RE: Dying Xtreme parts - 12/15/2007 1:00:01 AM
quattro1975
Status: offline
I just got those blades and I want to try this. I have one concern about temperature. Will these blades warp at all? How about when you go pull them out of almost boiling water and then take them over the cold water to set? Does this drastic temp change have any adverse affects on the blades? We're not talking about a non-mission critical part here. please provide some reassurance. thanks
quattro
T-Rex 450 SE V2 - MD500 Fuselage
       Post #: 34
RE: Dying Xtreme parts - 12/15/2007 1:11:18 AM
soloboss
Status: offline
One trick we use to straighten blades is to heat-soak them in boiling water for one minute. The warp comes out of the blades and they regain their original shape. And all of the blades in a pack match after the dip.
I don't think you will hurt your blades a bit. As far as cooling, I move the boiling water away from the heat so the boiling stops, then run warm water into the vessel to cool the blades. Another method would be to remove the blades by snagging them through the screw hole with a wire and hanging them vertical to cool. As long as they are flat, they'll be OK - or better than new.
Soloboss
(in reply to quattro1975)
       Post #: 35
RE: Dying Xtreme parts - 12/16/2007 4:58:43 PM
quattro1975
Status: offline
just did it and they came out perfect. got the water to almost a boil..I used RIT liquid black. I poured the hot water into a coffee can and stirred 10 blades at once for about 5min. Once I was satisfied with the results I tempered the water back down to warm and then cold. rinsed in cold water one more time and picked them up and no bleeding. they are currently drying flat and no holidays on the blades. I did this process in a stainless sink while i kept the sprayer going the whole time washing away splashes.
thanks for the info, guys
quattro
       Post #: 36
RE: Dying Xtreme parts - 12/16/2007 5:04:55 PM
J-MICHAEL
Status: offline
Same here...! Lol.. Got some navy blue, and black, just to see what it's like. And yeah, it works good...Did a few small pieces for starters that were white on the Trex. Now I look for anything that can be improved or enhanced that's plastic...Lol..
Have fun,
-- Jeff
Logo 10 /Trex 500 CF /Trex 450 /Cp-Pro x2 /Cx2 /Mini-Funtana X /Typhoon2 3-D /Aero Chlngr x2 /E-Maxx,Bandit,Stampede /Evader
       Post #: 37
RE: Dying Xtreme parts - 12/16/2007 6:10:44 PM
soloboss
Status: offline
Cool! I'm sure glad it worked out for you. It's as reliable as any color method I can imagine.
I had a bit of a color match problem with mine so I did overshoot the dyed parts with my final color, but I think that the dye base tint with the color / metalic overshoot did a nice job of blending the colors. I wanted a translucent canopy - slightly see-through, with a clear window and that's what I got. The body other than the canopy would not be the color I want if I would have shot blue over the white. The tint base is a good start. Here's where I ended up.
Soloboss
Click for fullsize
Soloboss
       Post #: 38
RE: Dying Xtreme parts - 12/16/2007 6:53:08 PM
stump3r
Status: offline
Nice job solo, I'm sending mine down for a makeover...please PM me your address
