Need Info on servos
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> OMP - Ohio Model Products Support Forum >> Need Info on servos
Page: [1]
Login
Need Info on servos - 12/2/2007 12:29:26 PM
ranger351w
Status: offline
Good day
I have never been around anything that needs four servos on the rear. How do they work? Do you have to do anything trick ? Curious as they install on both sides . I have a x3d 52 fusion. Curious as to how its done???
_____________________________
But thats just me
       Post #: 1
RE: Need Info on servos - 12/2/2007 1:46:26 PM
150flyer
Status: offline
There are a few ways to run multiple servos to one control surface. I like to use a Smartfly Equalizer 2. You simply plug the Equalizer into one of your receiver channels and two servos into the Equalizer. The Equalizer allows you to synchronize the servos by matching their end points. It will also allow you to reverse an individual servo if necessary.
http://www.smart-fly.com/Products/EqualizerII/equalizer.htm
Click to see fullsize image.
Click for fullsize
< Message edited by 150flyer -- 12/2/2007 1:47:19 PM >
(in reply to ranger351w)
       Post #: 2
RE: Need Info on servos - 12/2/2007 4:54:45 PM
daveopam
Status: online
The 52" Fusion only has two servos in the tail. One for rudder one for elev. Did I missread your question or are you talking about a different plane?
David
"Choose your shirt and shoes by the color. Choose your friends by their character." unknown
(in reply to 150flyer)
       Post #: 3
RE: Need Info on servos - 12/2/2007 5:37:15 PM
ranger351w
Status: offline
quote:
ORIGINAL: daveopam
David
Good day
Well I guess I kind of wondered about that. The instructions and the pics are pretty sparse and every pic I saw looked like there was two on each side of the tail. There is no instructions that tell how many. And there are spots on both side of the fuse for them. But you sure made it a lot easier to put together. Thank you
Mike
But thats just me
(in reply to daveopam)
       Post #: 4
RE: Need Info on servos - 12/3/2007 1:09:15 AM
AKFireMedic
Status: offline
The servos you see on both sides of the tail are the same servos. Just seeing the front and the back of them.
Da** it feels good to be a Pro Bro
       Post #: 5
RE: Need Info on servos - 12/3/2007 1:45:44 AM
daveopam
Status: online
Mike since your at that point. If you are an extreme flyer put 4/40 rod on the rudder. I bent mine doing knife edge loops with the plane. The stock hardware has too long of a run to use 2/56.
David
(in reply to AKFireMedic)
       Post #: 6
RE: Need Info on servos - 12/3/2007 2:04:13 AM
AFSalmon
Status: offline
Mike,
Hope you have it figured out. The pics in the manual show the typical tail servo installation. One elevator and one rudder servo is what is required. Pretty much standard setup on every 40 size profile on the market these days. Obviously being a profile the servos will stick through both sides of the fuse so that is probably what is confusing you.
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes, Team OMP Captain
       Post #: 7
RE: Need Info on servos - 12/3/2007 11:48:54 AM
ranger351w
Status: offline
Thanks you guys I needed that. I am red faced as a little common sense would have gone a long ways here. This is the first profile since probably 1975 and those were cl planes. Gettin old I guess.
But thats just me
(in reply to AFSalmon)
       Post #: 8
RE: Need Info on servos - 12/3/2007 11:54:39 AM
ranger351w
Status: offline
i am putting a OS 70 four stroke on it . What is your opinion? I have 46s but they are tied up.
Mike
Thanks again
But thats just me
       Post #: 9
RE: Need Info on servos - 12/3/2007 1:02:51 PM
AFSalmon
Status: offline
The OS 70 4S should be plenty of power for the 40 size profiles. I've never run that engine but I would assume it would require 20% nitro to be any good.
       Post #: 10
RE: Need Info on servos - 12/10/2007 10:36:15 AM
ranger351w
Status: offline
quote:
ORIGINAL: AFSalmon
Why 20%? Are they that pouchy? Better to use OS FXI 46? What size prop for both? Not going to do 3d.
But thats just me
       Post #: 11
RE: Need Info on servos - 12/10/2007 1:21:56 PM
AFSalmon
Status: offline
This is just pretty much what everyone says regarding the 4s engines. I know my Saito 100 runs very poorly on 10% nitro. I use 20% and it runs much smoother and more reliably.....plus better power. There are many threads on fuel and tuning for the 4s engines. I have never run an OS 4s so am only speaking from reference.
       Post #: 12
RE: Need Info on servos - 12/10/2007 7:17:41 PM
AKFireMedic
Status: offline
I think a lot of it is personal as well as climate/ altitude. I run 15% here in everything 2 and 4 stroke and it works great for me.
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
