sahartman21 -> RE: q 40 (3/14/2008 2:51:47 AM)
I made several more flights on the Napier. The following are the suggested control throws: Ailerons: Hi rate 5/16", Low 3/16" Elevator: Hi rate 1/4", Low 5/32" Rudder: 1/2" Use Hi rate during take off and landing. For the rest of the flying use Low rate. Initially I used a 6 ounce tank in my model. I later switched to a 4 ounce tank and still have plenty of time to fly the pylons and fly around another couple minutes. For props the APC 9x7 and 9x8 work well. Attached is a copy of the instructions. The original document was written in Word and did not convert very well to .txt. I have a full set of pictures, typical orders, and other documents. Just send me an email at sahartman21athotmail.com. Change the at to @ in the address. Good luck and turn left! [:D]
