Fastest .40 sized spad
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> Fastest .40 sized spad Page: [1]
Login
Fastest .40 sized spad - 12/2/2007 8:21:38 PM
acarter
Status: offline
I just got back from flying my pizza box flyer (it's on it's 15th flight) I like it so much that i'm ready to build my next spad.
What's the fastest .40 spad out there, it actually doesn't have to be .40 because i have a OS .40 LA which is more like a .35 so anything between .25 and .40 would work, I would prefer a delta wing design but I'm not 100% sure.
Austin
_____________________________
May the fulfillment come from the journey, not the destination!http://faapiper.home.comcast.net/~faapiper/
       Post #: 1
RE: Fastest .40 sized spad - 12/2/2007 9:04:16 PM
DLSmith2
Status: offline
Austin,
Check out the Dogfighter, Bulldawg, or Flipper ( at http://spadworld.net/ ) and I think one will satisfy your "need for speed."
Let us know what you decide to build, and don't forget the pics!
SPAD skies,
DL
(in reply to acarter)
       Post #: 2
RE: Fastest .40 sized spad - 12/2/2007 10:28:14 PM
acarter
Status: offline
I think that the bull dog is the one for me, i like the looks of it and the construction, the only problem I see is the avialiability of the gutter pipe. I have heard of using the coro to make the fuselage but I have no idea how to do this. I'm sorry if these questions have already been asked
Austin
(in reply to DLSmith2)
       Post #: 3
RE: Fastest .40 sized spad - 12/3/2007 12:05:01 AM
Gringo Flyer
Status: offline
The sickle is a good choice too. Its a solid flyer and a ton of fun.
"Courage is being scared to death...and saddling up anyway."---John Wayne
       Post #: 4
RE: Fastest .40 sized spad - 12/7/2007 4:24:20 AM
OzMo
Status: offline
search SPAD TO THE BONE for coro fuse or search here a coro fuse is lighter and stronger if made right and if you do it wrong ...try again, it just a bit o plastic! Just think light and design your own.
Yes dear, I did glue my hand to the airplane to keep from dropping it.
(in reply to Gringo Flyer)
       Post #: 5
RE: Fastest .40 sized spad - 12/7/2007 8:30:48 AM
somegeek
Status: offline
Coroplast Fuselage w/ Sickle pics.
If you're looking for all out speed, go with a symmetrical winged craft. This sickle moves at a good clip with a .46AX and APC 10x7 prop. Pondering trying a 9x8 next. With this setup, releasing this from my hand when launching at WOT, it seems to lunge out of my hand when I start to release it. The vertical is sick.
somegeek
< Message edited by somegeek -- 12/7/2007 8:33:43 AM >
Fly safe, have fun. Measure three times, cut once. The man who makes no mistakes does not usually make anything.
(in reply to OzMo)
       Post #: 6
RE: Fastest .40 sized spad - 12/7/2007 11:41:34 PM
broke_n_bummin
Status: offline
Have you looked at the Diamond Dust? I built one and powered it with a .40 LA. It's pretty quick and builds fast. It took me a couple tries to get the hang of hand launching a glow ... but I finally got there.
I may have to give up R/C Airplanes and Golf ... They make my Torrets act up...
(in reply to somegeek)
       Post #: 7
RE: Fastest .40 sized spad - 12/8/2007 1:04:53 AM
MrGreenSpeed
Status: offline
I'll put in a plug for the Draco ( Terror of the sky's )
It will fly great fast or slow and can turn and burn with the best of them.
It's a flying wing like the Sickle but doesn't have a fuse.
It's a little more complicated to build as it has a tapered LE and TE and a double tapered spar with the servos hidden inside the wing.
http://www.rudigreyling.com/photopage12.html
Jeff
< Message edited by MrGreenSpeed -- 12/8/2007 1:05:44 AM >
(in reply to broke_n_bummin)
       Post #: 8
RE: Fastest .40 sized spad - 12/23/2007 9:28:11 PM
voyager_663rd
Status: offline
My ddust came out kinda heavy (had to use 1/4" ply for the ribs) but I clocked it at 100 mph. Used a 46fx with a 9x9 apc. wing was 35" span.
< Message edited by voyager_663rd -- 12/23/2007 9:32:44 PM >
Len-> More questions than answers some answers are here [url]http://www.freewebs.com/rc_tips_and_hints[/url] 18,000+ hi
(in reply to MrGreenSpeed)
       Post #: 9
RE: Fastest .40 sized spad - 12/24/2007 4:30:14 AM
huck1199
Status: offline
Austin
If you have an Agway store nearby they can order 2.5" sq downspout for you. The current price is about $15 for 10'. They say it is vinyl but I think it is pvc. Works well.
Huck
       Post #: 10
RE: Fastest .40 sized spad - 12/24/2007 9:32:57 PM
MrGreenSpeed
Status: offline
pvc = polyvinyl chloride
Yup it's vinyl.
Jeff
(in reply to huck1199)
       Post #: 11
RE: Fastest .40 sized spad - 12/25/2007 6:37:19 AM
ChrisSpad
Status: offline
quote:
ORIGINAL: voyager_663rd
who knows, you might've gotten more with a 10x7 or 10x8 apc. Mine really unloaded in the air, i was spinning well over 23 grand with a 21 buggy engine, and a 7x6. That was on the smaller size, though. But, with a tt 36, i know it was doing 120+. Just almost too small and too fast to keep up with. I can't imagine it with the same setup and a tuned pipe, or MCP. It was unreal as it was.
No matter how many planes i plant, they just won't grow.
[link]http://www.chrisspad.com/planes/[/link]
(in reply to voyager_663rd)
       Post #: 12
RE: Fastest .40 sized spad - 12/26/2007 1:42:03 AM
JohnRC
Status: offline
Here is a SPAD I built with a OS 46 and a tower hobbies muffler.
We clocked it at 130mph
I was using a APC 9x6 at the time running around 15,000. Broke it during landing that is why there is a MAS on it now.
The wing is 48" and has a small Al U channel to make it very slim and strong.
Plan on building a new plane with a JETT 35 to see if I can go faster.
Click to see fullsize image.
Click for fullsize
       Post #: 13
RE: Fastest .40 sized spad - 12/26/2007 2:13:34 AM
microsprint9
Status: offline
9x6 at 15000, must have had a very strong tailwind or a very high dive to get 130 out of her, 9x6 at 15000 is only 85MPH pitch speed, how did the engine gain 10000RPM in the air?.
acarter my OS .40la isn't even close to a .35, my Magnum .15 has almost as much power as my .40la
OS .40 LA 11x5 @ 10500rpm .605HP 4.34lbs thrust
MAG .15XLS 8x3 @ 18000rpm .512HP 3.98lbs thrust
< Message edited by microsprint9 -- 12/26/2007 2:17:55 AM >
(in reply to JohnRC)
       Post #: 14
RE: Fastest .40 sized spad - 12/26/2007 2:17:09 PM
JohnRC
Status: offline
The engine is a OS 46AX. The org. muffler removed and the Tower Hobbies muffler from the Tower 46 is used. It will give you more RPM's on the OS.
We Tach the engine up with the 9x6 APC Prop, it usually peaks at 15200 to 15300, then we back it off about 200 to keep it from over heating.
This is how we clock our planes. I use a Robic SC-554 stop watch. (see picture) I get two people 300ft apart, one to signal and one to run the stop watch. When the plane reaches the signal person he drops his arm and the person with the stop watch starts the watch and stops it when the plane passes him we have the mph.
This stop watch has the ability to cal. mph by putting in the distance (300') between to points.
I found that a high dive to the signal person then leveling out slows the plane down. A small dive then leveling out some distance before the signal person gives the best speed. For safety the people are back off the run way in the safe area and the plane is flown accross
the top of the run way about 20ft off the ground.
Click for fullsize
(in reply to microsprint9)
       Post #: 15
RE: Fastest .40 sized spad - 12/26/2007 3:46:07 PM
ChrisSpad
