mortimersnerd
CO, USA Status: offline
Haven't heard of 23 series. Maybe wheels with 23mm hexes? If thats the case, you don't need'em, as 17mm works great for most folks and has a better selection of wheels to choose from. 40 series are a wheel/tire combo that run a larger wheel with a lower profile tire, with the same (mostly) outer diameter you've got now. Sharper handling on smoother surfaces such as many tracks, but not generally great for bashing on rougher surfaces or tracks. Beadlocks are a kind of wheel that holds the tire on with a band and small bolts. This eliminates the need for glue. Nice for when you have to change tires (and they look cool), but they're heavy, hurting acceleration, and, to a lesser extent, handling due to the increase in unsprung weight. For a straight basher, they're great, but only if you mind a speed and acceleration penalty. I'm in the same boat you are tire-wise, and am seriously considering a light dish wheel with a set of regular profile Proline Badlands. Not quite as good as small pin tires on really hard packed surfaces, but much more versatile and durable. You can get 1/2 inch offset wheels, mostly in beadlocks, I think. This will make the truck more stable, but will affect the handling some as well. Also makes the truck tougher to navigate on narrow sections of track. Hope this helps....
