thevirginian
Joined: 4/13/2004 From: chesapeake, VA, USA Status: offline
Thanks for the laurels, guys martno1fan; I know what you're saying. You absolutely correct. I could have made it to be glassed afterwards. But I didn't use 1/4 ply for the motor stringers. Also no ply for the transom. My intension was to build a balsa model quickly to see what the outlines are in real life. I could have designed it using a 3D software I also work with, but I am a more of a hands on type of guy, if you know what I mean. And to honest this model was done in no time. I started last sunday and she is basically done by now. I did get inspired by "Hydro Junkie". He seems to be a great builder. I used AutoCad for designing my plans and have the luxury of a large plotter. So I can plot full scale. Like I mentioned in my previous post I made some changes on the model, which I implemented into my plans, afterwards. The other reason for using plywood is that the boat will be straighter and truer compared to balsa. Unless I would have used more bulkheads and stringers. webdr; If I start a project such as this, I think I know what I am doing. Basically the only opposition was like "Do yourself a favour and buy some plans from Newton Marines". I didn't take it in a negative way, though. But designing and building a boat is no rocket sience. I have built several full scale boats, a couple model sailboats and two full scale kayaks. For me this project is no different. I will keep you guys posted with plenty of pictures and progress updates. But first I have to order teh plywood and get started with the real model.
