Scratch building a 1/8 Hydro
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - RC Gas Boats >> Scratch building a 1/8 Hydro
Page: [1] 2 3 4 5 6 7 8   next >   >>
Login
Scratch building a 1/8 Hydro - 12/2/2007 10:34:49 PM
thevirginian
Status: offline
After completing my design in CAD a decided to build a model of the boat using balsa wood only. I thought if I run into a problem I can easily alter the plans before I go with ply wood and fiberglass. The progress in building the balsa model was fast and without any glitches. I did find a couple areas where I made changes to the original plans, though. Now, since everything seems to fit my likings I am determined to purchase the plywood sheets and start with the real thing soon. But before I am going to do that, I still have to make the cowling. I will show the method I have chosen how to build the cowling once I got started. For right now here are some pictures of my balsa model.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 1
RE: Scratch building a 1/8 Hydro - 12/2/2007 10:50:48 PM
martno1fan
Status: online
nice boat mate what plans did you use how big is it? ,if that were mine id stick a nitro motor or brushless electric motor in it and get it wet.you could go gas if you glass the whole thing using glass cloth .ive used glass cloth over balsa before on big sailboats and it works great.might save you some building and get you on the water faster .
_____________________________
im not argumentative im just missunderstood
(in reply to thevirginian)
       Post #: 2
RE: Scratch building a 1/8 Hydro - 12/3/2007 12:42:58 PM
thevirginian
Status: offline
martno1fan,
Despite several opposing comments from RCU boat fans in this forum I designed the boat myself on CAD. What you said about glassing the balsa hull with glass I had in mind before. I strip built several sailboats from balsa znd glassed them. Difference is a hydro is subjected to a lot more stress then a sailboat. I am planning to put either a Zen 26 or Sikk 27 in it. The measurements are 43.5x23". I promised the balsa model a buddy of mine. He wants to glass her and power it with electric. I posted my plans below.
Click for fullsize
Click for fullsize
(in reply to martno1fan)
       Post #: 3
RE: Scratch building a 1/8 Hydro - 12/3/2007 1:06:31 PM
Dana W
Status: offline
Nice job . Nice to have a CAD as well .
DaVette Boats
       Post #: 4
RE: Scratch building a 1/8 Hydro - 12/3/2007 1:39:10 PM
martno1fan
Status: online
i dont see a problem using that hull if you glass it mate its no diff than having a glass hull exept you will have youres lined with wood and looking nice on the inside .Just make sure you lay the glass thick enough to handle the rigours of running a gas motor.The plans look good i have a few similar on a smaller scale.how did you get those plans printed full size? print shop?.
       Post #: 5
RE: Scratch building a 1/8 Hydro - 12/3/2007 3:40:04 PM
webdr
Status: offline
Incredible work brother!
Looks like you have good grasp of what your doing, what opposition did you get from the masses?
Matt G.
RCUniverse Senior Surface Editor
Atlanta, GA
       Post #: 6
RE: Scratch building a 1/8 Hydro - 12/3/2007 4:57:49 PM
thevirginian
Status: offline
Thanks for the laurels, guys
martno1fan;
I know what you're saying. You absolutely correct. I could have made it to be glassed afterwards. But I didn't use 1/4 ply for the motor stringers. Also no ply for the transom. My intension was to build a balsa model quickly to see what the outlines are in real life. I could have designed it using a 3D software I also work with, but I am a more of a hands on type of guy, if you know what I mean. And to honest this model was done in no time. I started last sunday and she is basically done by now. I did get inspired by "Hydro Junkie". He seems to be a great builder. I used AutoCad for designing my plans and have the luxury of a large plotter. So I can plot full scale. Like I mentioned in my previous post I made some changes on the model, which I implemented into my plans, afterwards. The other reason for using plywood is that the boat will be straighter and truer compared to balsa. Unless I would have used more bulkheads and stringers.
webdr;
If I start a project such as this, I think I know what I am doing. Basically the only opposition was like "Do yourself a favour and buy some plans from Newton Marines". I didn't take it in a negative way, though. But designing and building a boat is no rocket sience. I have built several full scale boats, a couple model sailboats and two full scale kayaks. For me this project is no different. I will keep you guys posted with plenty of pictures and progress updates. But first I have to order teh plywood and get started with the real model.
(in reply to webdr)
       Post #: 7
RE: Scratch building a 1/8 Hydro - 12/3/2007 6:26:35 PM
martno1fan
Status: online
No worries mate im sure when you build the plywood one it will turn out even better ,after all youve had a practice run now .Keep us posted mate im very keen to see how it turns out.Dont ever get put off by people saying you cant do it,i never have been .
       Post #: 8
RE: Scratch building a 1/8 Hydro - 12/3/2007 10:14:39 PM
thevirginian
Status: offline
martno1fan
you betcha. If somebody tells me "you can't do that", it's even more of a challenge for me.
       Post #: 9
RE: Scratch building a 1/8 Hydro - 12/3/2007 11:39:38 PM
chief3452
Status: offline
Hey Virginian,
Mock up model looks like a winner! Can't wait to see what comes next. I wish I had access to all those great design tools you have, must be nice. My hydro is plodding along too. I'm curious where you came up with your dimensions for your sponson riding surfaces, I am trying to figure out what would be a good width of ride pad to do on my boat. http://www.rcuniverse.com/forum/m_6574785/tm.htm Appreciate any input you could provide, thanks.
Scott
       Post #: 10
RE: Scratch building a 1/8 Hydro - 12/3/2007 11:54:33 PM
Hydro Junkie
Status: offline
Time for a suggestion session. There are some changes I would make when you do your plywood hull:
1) Raise the ramwing and round it off, adjusting the bottom angle accordingly
2) Leave the center open for the full length of the hull
3) Let the center of the sponson bottom run slightly below the side panels
4) Use the following materials in these locations:
1) 1/4 aircraft ply for the right sponson and rear transoms
2) 1/8th aircraft ply for the sponson insides, engine bay walls, sponson sheers and left sponson transom
3) 1/16th aircraft ply for everything else
5) Plan on a 7" engine bay width to allow room for the carb and exhaust header rather than trying to run them both out over the deck
< Message edited by Hydro Junkie -- 12/4/2007 12:35:33 AM >
       Post #: 11
RE: Scratch building a 1/8 Hydro - 12/4/2007 12:27:27 AM
dwr9
Status: offline
Looks great. Keep posting pics as you work on it. Doug
(in reply to Hydro Junkie)
       Post #: 12
RE: Scratch building a 1/8 Hydro - 12/4/2007 1:07:20 AM
thevirginian
Status: offline
Hey, chief;
I admire your shovelnose very much. Looks really great. For my sponsons I kinda copied what I thought was alright on an 'Insane' Hydro a buddy of mine races. I don't think I am going to be too far off. Yeah, good computer software sure is a great help in designing stuff like that. I will keep you guys posted.
Hydro Junkie;
I appreciate your input very much. I can imagine you are an expert in this class of boats. Let me ask you a few questions regarding your comments: Why do you think the ramwing is too sharp and too low? I am not disputing your suggestion. I am just curious. Could you elaborate on your second and third suggestion a little bit more? Regarding the plywood thickness, that's exactly what I had planned to use.
Thanks for your help
(in reply to chief3452)
       Post #: 13
RE: Scratch building a 1/8 Hydro - 12/4/2007 1:25:22 AM
Hydro Junkie
Status: offline
On the ramwing, as low as yours is, you will be taking a lot of water over it. By rounding it off, it will be more aerodynamic than a sharp edge and not so likely to get damaged if you hit something
On leaving the center section open, it will make running and repairing drive gear, cooliing lines and pushrods. it will also make getting any water that gets in there easier to get out
On dropping the center of the sponson down slightly, it will prevent the water from sucking your boat down. With the flush joints between the bottom and sloping sides, your boat will have a hard time getting up on plane since the water will have more surface area to grab. By dropping the center section and keeping the edges sharp and at approximately 90*, the water will have less to grab. This will result in better handling and more speed.
       Post #: 14
RE: Scratch building a 1/8 Hydro - 12/4/2007 2:14:29 AM
Strikar
