wrecker5
Joined: 4/11/2003 From: Eldora, IA, USA Status: offline
rcdemon, I tried my Tracker II with a JR reciever, I had to change the PPM mod to + instead of -, but when I did it swapped the aileron (ch1) and throttle (ch3). I aslo tried it with a Futaba reciever. It seemed to work fine except for the Flapperon function, which only had 1/2 as much travel to the left as it did to the right. The Flaps didn't work right either, they wanted to work like ailerons when I turned the knob. It may be possable to program the flaps to work properly but I didn't get that far into it. The way the Flapperons worked I couldn't fly, and I couldn't fly with the aileron and throttle reversed either. I have emailed Polk Hobbies about this, I hope I get quick response. I liked the scanner part of the radio, and the programming seemed simple enough. Wrecker5
< Message edited by wrecker5 -- Apr 14 2003 4:58PM >
