papajeff
NY, USA Status: offline
Ron, Very nice build thread, eventhough you may not consider it such. I learned a lot from you and appreciate your effort. I am in the process of converting the Nitro F-16 from a pusher to an EDF and your posts are very helpfull. I will be using a 90mm Wemo Midi fan, which fit perfectly in the fuse after triming some of the formers, an AMMO 36-56-1800, Castle 80A ESC with the CCBEC, Spektrum Tx & Rx and Flight Power 5-6S 4200mAh packs. I'm sure that I willl have more questions for you as I progress and I look forward to seeing your video. Keep up the good work.
< Message edited by papajeff -- 1/6/2008 5:01:24 PM >
