Cermark/EJF F-16 Assembly Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric RC Jets >> Cermark/EJF F-16 Assembly Thread Page: [1] 2 3   next >   >>
Login
Cermark/EJF F-16 Assembly Thread - 12/4/2007 9:01:55 PM
Ron101
Status: online
So I've had this plane kicking around the garage for awhile now. I got a few other projects done so now I'm hot to get this done. I wouldn't dare call it a build thread just an assembly thread for anyone that may be interested in this kit.
I started with installing the servos in the wing and rudder. I went with the Hitec Thin digital metal gear wing servo's (HS-5125) on ailirons and rudder. I normally go over kill on everything. But Tam is useing them with good results on his A-4 so I went for it. They are very light at .84 oz compared to 2 oz. for most digital servos. I also used Tams servo mounts... very nice and easy to install servos...I didn't use any of the hardware in the kit.
First I burned in all my servo on the hitec programmer... I let them run for 30 minutes each.... one servo was bad right out of the box.. bought a new one and sent back the bad one..
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
"It''''s not personal, Sonny. It''''s strictly business."
       Post #: 1
RE: Cermark/EJF F-16 Assembly Thread - 12/4/2007 9:05:10 PM
Ron101
Status: online
Here's a shot of the wing and the rudder setup...
I have Flaperons set up on the wings..not sure if I'll need them but it's there if I do
Click for fullsize
Click for fullsize
(in reply to Ron101)
       Post #: 2
RE: Cermark/EJF F-16 Assembly Thread - 12/4/2007 9:09:57 PM
Ron101
Status: online
Setup the elevator using the Tam jets mounts again.. nice and easy.. the hardware they give you here for the elevator setup looks real nice.. I went with sullivan gold clevis's here again..
The servo's are hi tec 5958 metal gear digitals (172oz of tork)
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 3
RE: Cermark/EJF F-16 Assembly Thread - 12/4/2007 9:13:58 PM
Ron101
Status: online
For a RX I'm going to use the new futaba fasst 7ch on my 9c controller..
I've had this rx in a 40 sized extra with a os 55ax which hauls balls... and the link has been outstanding
My Fan is Settup and ready to go! it's a DS-94 with a neu motor 1527 and a CC 110.. Tam set this baby up for me with his heat sink .. plug and play..ready to roll.. also note the nice resistor for no spark pulg in
Click for fullsize
Click for fullsize
       Post #: 4
RE: Cermark/EJF F-16 Assembly Thread - 12/4/2007 9:16:27 PM
Ron101
Status: online
Tam also hooked me up with this very cool cockpit from his F-16...
I got it all trimmed up and installed.. I left out the dash it was over 1oz
So it may be a bit heavy but I love it.. with cockpit and canopy frame it's 8oz
Click for fullsize
Click for fullsize
       Post #: 5
RE: Cermark/EJF F-16 Assembly Thread - 12/4/2007 9:18:33 PM
Ron101
Status: online
I've been using my Thunder Power charger settup for my 30% extra for awhile now and it works great!!
I have to give credit to BVM for this settup.. it's in there electra instruction made by chris true.. works like a dream
Click for fullsize
       Post #: 6
RE: Cermark/EJF F-16 Assembly Thread - 12/4/2007 9:22:47 PM
Ron101
Status: online
Next was on to the retracts...
I installed the nose gear servo first.. again using Tams hardware
then I installed the nose gear... and hooked up the pull pull setup
I had a screw break on me puting in the nose gear.. I had to drill it out and replace
Click for fullsize
Click for fullsize
       Post #: 7
RE: Cermark/EJF F-16 Assembly Thread - 12/4/2007 9:24:24 PM
Ron101
Status: online
Got the main gear in..still need to hook up the lines.. but it's in
it took a small amount of trimming to get the gear to go up nice and clean
Click for fullsize
       Post #: 8
RE: Cermark/EJF F-16 Assembly Thread - 12/4/2007 9:33:16 PM
Ron101
Status: online
So of coarse I had to mock it up and get a look at her on her legs..
it's coming along nice..
My plan now is to make up two small wood plates .One to mount my retract air valve too and micro servo the other for the brake valve and. I'm going to put these up under the ledge where the wing roots meet.. I'll have one on each side.. Then the air tanks back along side the thrust tube...
I'll ditch the big heavy wood plate under the canopy.. just velcro in the batteries there... put the RX batt way back in the tail.. RX up in the nose..
and hope my CG is good
So this is where I'm at for now keep ya posted... I need to bust this out so I can get to my Tam Jets A-4
Click for fullsize
Click for fullsize
       Post #: 9
RE: Cermark/EJF F-16 Assembly Thread - 12/4/2007 9:34:24 PM
Ron101
Status: online
So I got a few things done... I've got the flu so I'm bored and thought I'd put up a few pics.
I made up a couple small plates to mount my retract and brake valve on.. I'm putting these up along the side of the fan. The retract valve that comes with the kit is leaking. So I put in one I had.. but it's slamming the gear up too hard. I ordered a robart variable valve so I can slow it down. Of course they are on backorder just about everywhere. I found one at DreamWorks. Todd’s a great guy to deal with.
Don't give me a hard time for the mess of wires I have ..
I'm going to clean it up real nice once I have things where I want them
The brakes are working very strong... is there an adjustment at the wheels to loosen them up?
Ron
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Ron101 -- 12/4/2007 9:38:19 PM >
       Post #: 10
RE: Cermark/EJF F-16 Assembly Thread - 12/4/2007 11:29:54 PM
Airforce7
Status: offline
Ron,
If you don't like the Robart valve adjustments I have some airflow restrictors you can try. They are inline restrictors w/ bards on either end for tubing.
I'm not familiar with the main gear you have, but a little grease on the contact surface will help with smoothing out the braking. A proportional brake valve is ideal as well.
How are the stabilizer servos held down inside the fuse? Did you glue the mount down so that you can remove the servo if necessary?
Ken
       Post #: 11
RE: Cermark/EJF F-16 Assembly Thread - 12/5/2007 12:57:47 AM
Ron101
Status: online
Hey Ken
I've had pretty good luck with the robart adj. valve on warbirds... so if it give me problems I'll give those a restictors a try.
thanks for the offer.
Grease.. thats a good idea.. it's just so tight.. affaid if I hit the brakes it will rip the gear off...lol
your right I should get a BVM smooth stop.. but I'm being cheap ken
as for the stabilizer servos.. I glued down tam jets mounts then screwed the servo to the mount.. so if needed the servo can be replaced (see pic)
I wish I wouldn't have seen you alfa a-4... it's on the must have list..
Do you have any winter projects going on over there ken?
Ron
Click for fullsize
(in reply to Airforce7)
       Post #: 12
RE: Cermark/EJF F-16 Assembly Thread - 12/6/2007 3:32:04 PM
Ron101
Status: online
Last night I got the new robart retract valve in... got the gear slowed down real nice.. no more slamming
also cleaned up the wiring a bit..
with the bad weather and no flying I hope to get alot done this weekend
< Message edited by Ron101 -- 12/6/2007 3:35:29 PM >
