A newbie to coroplast.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> A newbie to coroplast.
Page: [1]
Login
A newbie to coroplast. - 12/5/2007 12:15:48 AM
weathervane
Status: offline
A friend just gave me a stack of coroplast along with some square pvc tubing. I have been looking at the Spadtothebone web site. I really like the Spads on rails. So, are there any do's and dont's when building a Spad. Where can I find plans for the flying dog house? Can you cover or paint coroplast?
Thanks, Andrew
_____________________________
Without trucks, America stops.
www.freestateaeromodelers.org
       Post #: 1
RE: A newbie to coroplast. - 12/5/2007 12:45:53 AM
mclina
Status: offline
I need to find better friends.
If you stick to the plans on STTB, you can't go wrong. I have been building mine on aluminum angle/channel/tube because I can't find square PVC.
If your club has combat, you should find out what type of planes they fly. My club has a few guys who fly Derelict .25's, so I built something similar using 1" aluminum angle and a Defender .25 wing.
I haven't seen plans for the doghouse. I would like to build one, or a lawnmower. The kids would love them.
Good luck.
If all of your friends were named Cliff, would you jump off them? - Hugh Neutron
(in reply to weathervane)
       Post #: 2
RE: A newbie to coroplast. - 12/5/2007 3:29:53 AM
draftman1
Status: online
thats the best part about spads NO COVERING!!! a few graphics are put on the surface for coloring and top/ bottom distinction. usually it is vinyl sign stick on material scraps that your new buddy, the sign shop owner, will give you have fun!!! i just started spads and there great!!
(in reply to mclina)
       Post #: 3
RE: A newbie to coroplast. - 12/5/2007 4:33:55 AM
huck1199
Status: offline
Mclina,
If you have an Agway store near by, they can order it for you -about $15 for a 10' piece, it is 2 1/2" vinyl downspout. A 10' piece makes three 40" fuses.
Huck
(in reply to draftman1)
       Post #: 4
RE: A newbie to coroplast. - 12/5/2007 3:28:27 PM
Villa
Status: offline
Hi mclina
Just noticed you use aluminum square tubing, angles, and channels for the SPAD fuselages. I have been doing that for 3-4 years. I use the 1" square tubing on my flying lawnmower. You can download the plans and building instructions from our club website at
http://www.wilsonrc.org
It flys fantastic. Three or four experienced club members have flown mine with no problem. Have you seen my COROPLAST CANARD? You can search for it on this website. If you build these let me know how they fly.
(in reply to huck1199)
       Post #: 5
RE: A newbie to coroplast. - 12/5/2007 5:03:46 PM
mclina
Status: offline
Thanks Villa. I definitely want to build a mower. I'll post pics when I get it under construction.
(in reply to Villa)
       Post #: 6
RE: A newbie to coroplast. - 12/6/2007 1:04:58 AM
weathervane
Status: offline
Thanks guys, I'm looking forward to my first build.
Andrew
       Post #: 7
RE: A newbie to coroplast. - 12/6/2007 4:40:29 PM
broke_n_bummin
Status: offline
I built a SPAD canard about a year ago. Don't know if it was Villas or not. I have built everything on STTB and a few others I found on other pages. My favorites were the Sickle, Diamond Dust, Corostang, Corsair, BUHOR and of course the SPA3D ( I even converted a Gnat to a mini SPA3D). The best thing about them is no matter how deep you plant a SPAD plane, 20 minutes with a hot glue gun and you're back in the air.
I may have to give up R/C Airplanes and Golf ... They make my Torrets act up...
       Post #: 8
RE: A newbie to coroplast. - 12/7/2007 4:15:32 AM
OzMo
Status: offline
Welcome to SPADs
you can paint coro with Krylon but clean it first with solvent and rough it up with fine sand paper or steel wool but REMEMBER paint is HEAVY so just for stripes or contrast and GO very light with the spray. let it cure for a couple of days. Works better away from exhaust.
If you have downspout skip the alum angle stuf and go for a Das Plas Stick make your wing as simetrical as possible and it will be a great flyer. I like the fold it first method then insert the yard stick spar for a very simetric wing.
The two best Spad tips I ever got are ... 1. don't over apply the CA (and give it plenty of time under pressure to set).
2. use a jig or have a hepler when it comes time to fold the wing
have fun
Yes dear, I did glue my hand to the airplane to keep from dropping it.
(in reply to broke_n_bummin)
       Post #: 9
RE: A newbie to coroplast. - 12/19/2007 3:00:32 AM
weathervane
Status: offline
Ok, My first SPAD build is under way. A few pics for everyone to ponder. I do have one question, What is the propane torch used for???
-Andrew
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to OzMo)
       Post #: 10
RE: A newbie to coroplast. - 12/19/2007 3:44:25 AM
OzMo
Status: offline
Its called "flashing". Coroplast has an oily film on it from the manufacturing process. This film can be removed with a quick flash heating of a torch or by wiping it off with solvent such as denatured alcohol or acitone. The glue works much better if this is done.
If you do use the torch practice on a piece of scrap first. Sometimes you can see the vapor of the oil go off the sheet but it is easy to melt the plastic.
       Post #: 11
RE: A newbie to coroplast. - 12/19/2007 12:40:20 PM
weathervane
Status: offline
Ok, Thanks. I wish I had asked before I started to build my wing. ( problems with the CA sticking )
-Andrew
(in reply to OzMo)
       Post #: 12
RE: A newbie to coroplast. - 12/19/2007 4:34:07 PM
Villa
Status: offline
Hi weathervane
If you worry about the CA glue holding wing together, add a few of the very small nylon tie wraps to the glue joints.
       Post #: 13
RE: A newbie to coroplast. - 12/20/2007 11:01:23 PM
weathervane
Status: offline
quote:
ORIGINAL: Villa
Hi weathervane
That is a good idea. Thanks
-Andrew
(in reply to Villa)
       Post #: 14
RE: A newbie to coroplast. - 12/21/2007 3:01:31 AM
OzMo
Status: offline
Well it is a spad so anything goes. I have often stapled seams such as the TE and aileron seam using a household staple gun and then a needle nose pliars to role the ends. Very strong REMEMBER SPAD RULE #1 if you got it you can use it! RULE # 2 if you ain't got it go get it
       Post #: 15
RE: A newbie to coroplast. - 12/31/2007 8:33:03 PM
weathervane
