AFPD doesn't start unless i deactivate my soundcard
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> AFPD doesn't start unless i deactivate my soundcard Page: [1]
Login
AFPD doesn't start unless i deactivate my soundcard - 12/6/2007 1:19:05 PM
Komb.at
Status: offline
hi there,
well for short, AFP doesn't start
here's my system first:
Windows Vista Ultimate 64
Intel q6600
4GB ram
8800GTX
Audgy2 (and later X-Fi xtreme Music)
the problem lies most likely in OpenAL, because the log files end with "openal: init". I've also found a small program that plays a sound file with openal, and that doesn't work either.
I've try updating the drivers for my Audigy2, and also upgrading to a X-Fi Xtreme Music (also with newest drivers)
Everything i tried (except for deactivating the soundcard in the hardwaremanager) leads to a complete hang right at the start of AFPD
Thing's i've tried:
Installing it to a different directory
undo all write protected files
re-install drivers from audigy2
swap audigy2 for x-fi (with newest drivers)
(re)install OpenAL from openal.org
run AFPD as administrator
run AFPD with Alchemy
I hope that someone recognizes this problem and can help me
       Post #: 1
RE: AFPD doesn't start unless i deactivate my soundcard - 12/7/2007 3:17:58 AM
rajul
Status: offline
Hi Kombat, did you install any addon? Which patch did you install? With Vista, it is better to disable UAC before installation of AFPD, addons and patch.
Please also post you tmlog file here for diagnosis. You can find the tmlog file in the AFPD program folder and open it with a text editor like notepad or word. Thanks
_____________________________
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
(in reply to Komb.at)
       Post #: 2
RE: AFPD doesn't start unless i deactivate my soundcard - 12/7/2007 7:28:40 AM
Komb.at
Status: offline
I have the version which includes Addon 1&2 allready, no other addons. I've installed the patch 1110709, however it doesn't work before or after patch. The version number noted on the CD is 1.11.7.1
UAC is always disabled on this machine.
here's the log file after a crash:
tm: Library Version 4.4, Copyright (C) 1999-2007, IPACS
tm: http://www.ipacs.de
tmsystem: init random with 707911431
tmsystem: cpu type=(nlogical=1) (nphysical=4) (no hyper-threading)
tmsystem: cpu=3005 Mhz
tmsystem: memory=(physical=4094MB, avail=2859MB) (virtual=2047MB, avail=1866MB)
tmsystem: operating system=Microsoft Windows Vista Version 6.0 (Build 6000)
loading font v2 texture/fontuni.tff=(2048x2048) (h=16) (nc=65536) (split=1) ok
tmgl: loading mouse texture/mouse.tmt=ok
tmprogram: AeroFly Professional Deluxe Version 1.11.7.9, Copyright (C) 1998-2007 IPACS
loading configfile config/main.mcf=ok
loading player configfile config/player1.mcf=ok
loading player configfile config/player2.mcf=ok
openal: register sound sound/beep.wav=(0, rd=100.00) ok
openal: register sound sound/balloon.wav=(1, rd=100.00) ok
openal: register sound sound/crash.wav=(2, rd=100.00) ok
openal: register sound sound/splash.wav=(3, rd=100.00) ok
openal: register sound sound/glider.wav=(4, rd=2.00) ok
openal: register sound sound/glider2.wav=(5, rd=2.00) ok
openal: register sound sound/glider.wav=(already registered)(6, rd=5.00) ok
openal: register sound sound/glider2.wav=(already registered)(7, rd=5.00) ok
openal: register sound sound/glider.wav=(already registered)(already registered)(8, rd=2.00) ok
openal: register sound sound/glider2.wav=(already registered)(already registered)(9, rd=2.00) ok
openal: register sound sound/glider.wav=(already registered)(already registered)(already registered)(10, rd=5.00) ok
openal: register sound sound/glider2.wav=(already registered)(already registered)(already registered)(11, rd=5.00) ok
tmgl: failed to load texture texture/cockpitmain.bmp
tmgl: loading geometry objects/horizon.obj= ok
afdesign: init ok
tmgl: loading geometry objects/card.tgo= ok
tmgl: loading geometry objects/pylon.obj= ok
directinput: init=ok
tmsystem: current monitor frequency=60
init window=(window=1920x1200) (screen=1920x1200) (32bpp) (60Hz) (fullscreen)
openal: init
right after a second the game window stops responding, goes to a black and then a white screen, and has to be terminated.
I've played an hour today, and i found out that if i reactivate my soundcard after the start, and then re-activate the music, it runs... but just the music, not the sound though (which would be the only thing i'd need anyway)
(in reply to rajul)
       Post #: 3
RE: AFPD doesn't start unless i deactivate my soundcard - 12/7/2007 7:34:37 AM
Komb.at
Status: offline
oh and, here is the log file when i deactivate the soundcard and it runs:
tmsystem: init random with 634784434
tmsystem: memory=(physical=4094MB, avail=2750MB) (virtual=2047MB, avail=1866MB)
afdesign: init ok
openal: init (default=) ERROR alcopendevice = 0
init pixelformat=ok
gl: vendor=NVIDIA Corporation, renderer=GeForce 8800 GTX/PCI/SSE2, version=2.1.2, opengl version=2.1
(viewport=8192x8192) (texturesize=8192) (stencil=8)
gl extensions=GL_ARB_color_buffer_float GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_half_float_pixel GL_ARB_imaging GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shadow GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_bindable_uniform GL_EXT_depth_bounds_test GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_EXT_timer_query GL_EXT_vertex_array GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_copy_depth_to_color GL_NV_depth_buffer_float GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_texgen_reflection GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
wgl extensions=WGL_ARB_buffer_region WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_pixel_format_float WGL_ARB_render_texture WGL_ATI_pixel_format_float WGL_EXT_extensions_string WGL_EXT_framebuffer_sRGB WGL_EXT_pixel_format_packed_float WGL_EXT_swap_control WGL_NV_float_buffer WGL_NV_multisample_coverage WGL_NV_render_depth_texture WGL_NV_render_texture_rectangle
gl: extensions=(multitexture) (framebuffer) (separate color) (anisotropic filter of 16.00) (compressed texture) (cubemaps) (shader objects)
wgl: extensions=(wglpixelformat) (swapcontrol) (multisample)
gl: reducing max texture size from 8192 to 2048
tmsystem: fullscreen modes=(rj-640x480x32x59) (rj-640x480x32x60) (rj-720x480x32x59) (rj-720x480x32x59) (rj-720x480x32x60) (rj-720x480x32x59) (rj-720x480x32x60) (rj-720x480x32x60) (rj-720x576x32x59) (rj-720x576x32x59) (rj-720x576x32x59) (rj-720x576x32x60) (rj-720x576x32x60) (rj-720x576x32x60) (800x600x32x59) (1024x768x32x59) (1152x864x32x59) (1280x720x32x59) (1280x768x32x59) (1280x1024x32x59) (1600x1200x32x59) (1920x1080x32x59) (1920x1200x32x59) (rj-640x480x16x59) (rj-640x480x16x60) (rj-720x480x16x59) (rj-720x480x16x59) (rj-720x480x16x60) (rj-720x480x16x59) (rj-720x480x16x60) (rj-720x480x16x60) (rj-720x576x16x59) (rj-720x576x16x59) (rj-720x576x16x59) (rj-720x576x16x60) (rj-720x576x16x60) (rj-720x576x16x60) (1280x960x16x59) (1680x1050x16x59)
tmsystem: opengl samples buffers=4
directinput: searching joysticks=none
(1: (1: (1:programobject
framebuffer object created (512, 512)
framebuffer object created (256, 256)
tminput: searching for input devices...(1)
tmsystem: searching usb interface (0) 0=unable to open interface device
tmsystem: searching usb interface (1) 0=unable to open interface device
tmsystem: searching usb interface (0) 0=unable to open joystick device
tmsystem: searching usb interface (1) 0=unable to open joystick device
tminput: 0 devices found
tminput: searching for input devices...(2)
sim: loading scenery scenery/pagefield.geo...
sim: 1 objects 0 dynobjects
sim: start position 1 (not for helicopter)
sim: start position 2 (not for helicopter)
sim: start position 3 (not for helicopter)
sim: start position 4 (not for airplanes)
sim: start position 5 (not for airplanes)
sim: ballons=10 (-10.00,-7.00,2.00) (-24.00,7.00,6.00)
tmgl: loading geometry objects/balloon.obj= ok
sim: dragrace=(100.00,270.00)
sim: spotarea=(25.00,14.00)
sim: load texture grid 5x5 (pano=0) (compress=1) named pagefield/pagefield=(3.600x4.000) (5x5) (20x10)
sim: sphere params(0)=0.0000 0.0000 110.0000
sim: loading ground object scenery/pagefield/pagefield.obj=tmgl: loading geometry scenery/pagefield/pagefield.obj= ok
ok
sim: loading time=1718667 mus
sim: 1 photo scenes
tmcollision: 7361 triangles using 942208 bytes
tmcollision: omin=(-2333.1,-2579.2,-1.9) omax=(2492.3,2272.8,31.4) octmin=(30.0,30.0,30.0)
tmcollision: otnodes=343 otendnodes=172 otdepth=17 otlistareas=120819
tmcollision: otnmaxareas=341 otnavgareas=50 otnminsize=(18.849,18.953,16.637)
tmcollision: otareas=8749 mem=977204
tmcollision: 343 octrees, using 52136 bytes
tmcollision: total mem=1029340 bytes
tmcollision: time=0.03s
tmcolldynamic: no dynamic objects or triangles
sim: loading aircraft 1 geebee...
tmgl: loading geometry aircraft/geebee/geebee.obj= ok
tmdairfoil: loading m665 ok
tmdairfoil: loading naca0009 ok
tmdairfoil: loading naca0015 ok
openal: register sound sound/g15-3000.wav=(12, rd=5.52) ok
openal: register sound sound/g15-5000.wav=(13, rd=5.52) ok
openal: register sound sound/g15-10000.wav=(14, rd=5.52) ok
generating shadow 0=radius=2.61 bbmin=(-1.30 -1.30 -0.59) bbmax=(1.30 1.30 0.35)
sim: creating blurr=Propeller
tmmusic: off
openal: shutdown=ok
directinput: shutdown
saving configfile config/main.mcf=ok
saving player configfile config/player1.mcf=ok
tmsystem: 0 memory blocks:
tmsystem: shutdown, 0 memory blocks left using 0 bytes
       Post #: 4
RE: AFPD doesn't start unless i deactivate my soundcard - 12/7/2007 7:46:39 AM
rajul
Status: offline
Hi, can you uninstall AFPD and reinstall it and use patch 1.9.7.11 The uninstallation procedure and patch can be found here http://www.aerofly.com/www/downloads.html
Mike Marks
RCU Moderator
       Post #: 5
RE: AFPD doesn't start unless i deactivate my soundcard - 12/7/2007 8:35:37 AM
Komb.at
Status: offline
ah sorry, that's the patch i've installed. I was looking at the update's filename when i wrote my post. I suppose 1110709 is the reverse of 1.9.7.11
(in reply to rajul)
       Post #: 6
RE: AFPD doesn't start unless i deactivate my soundcard - 12/7/2007 8:40:48 AM
rajul
Status: offline
Your tmlog says that you installed 1.11.7.9 Pls uninstall and reinstall AFPD as per the procedure and try 1.9.7.11
Mike Marks
RCU Moderator
       Post #: 7
RE: AFPD doesn't start unless i deactivate my soundcard - 12/7/2007 8:50:13 AM
Komb.at
Status: offline
I'll try when i get home tonight...
however, the filename of the update 1.9.7.11 from the link you posted is afpd1110709.exe, which is the file i still have on my desktop.
i'll try re-downloading and re-installing it though
(in reply to rajul)
       Post #: 8
RE: AFPD doesn't start unless i deactivate my soundcard - 12/7/2007 9:02:29 AM
rajul
Status: offline
Look slightly further down the page and you'll see two other patches 1.9.7.11 and 1.8.0.25 The uninstallation/installation instructions can be found right at the bottom of the same page. If you only have addons 1 and 2, patch 1.9.7.11 will be sufficient and won't take up so much resources as 1.11.7.9 I would recommend 1.11.7.9 only if you have the latest addons 3 and 4
Mike Marks
RCU Moderator
       Post #: 9
RE: AFPD doesn't start unless i deactivate my soundcard - 12/7/2007 9:48:32 AM
Komb.at
Status: offline
aaahh, that makes sense, i'll try that tonight..
hope it works, thanks
(in reply to rajul)
       Post #: 10
RE: AFPD doesn't start unless i deactivate my soundcard - 12/7/2007 10:02:15 AM
Komb.at
Status: offline
another short question. Since the version on the cd is 1.11.7.1 already, can i even downgrade that to 1.9.7.11 with the patch?
       Post #: 11
RE: AFPD doesn't start unless i deactivate my soundcard - 12/7/2007 1:44:30 PM
rajul
Status: offline
In this case, after you install the 1.11.7.1 main disk, there should be no need to apply the 1.11.7.9 patch, but you can. The difference is 7.1 has soft shadows enabled by default, 7.9 its turned off.
I have feedback the issue to IPACS and the initial feedback is that they will have to look at the openal/creativelabs/vista issue. They will take a a few weeks to resolve it. I will keep you updated
< Message edited by rajul -- 12/7/2007 2:38:46 PM >
Mike Marks
RCU Moderator
       Post #: 12
RE: AFPD doesn't start unless i deactivate my soundcard - 12/7/2007 3:45:28 PM
Komb.at
Status: offline
Allright, thanks for your time, i appreciate your effort
I'll also keep you informed about any progress i can make
(in reply to rajul)
       Post #: 13
Page:   [1]
Page: [1]
