RE: Albatros DVa
Tower Hobbies
Logged in as Guest
  Printable Version
Top Flite Cessna 310 - ARF
Seller:  Jerryballs
Details:   $1,200.00   |  6/25/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Albatros DVa
Page: <<   < prev  1 [2] 3 4 5 6 7   next >   >>
Login
RE: Albatros DVa - 12/29/2007 1:52:59 PM
cocobear
Status: offline
Hi all and Happy New Year! Attached are some new photos showing all the framed parts. Am waiting on a muffler from Bennet and then I can finish sheeting. The pictures show the wings and stab ready for cap strips, the engine installation.
Dave
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to jtisch)
       Post #: 26
RE: Albatros DVa - 12/29/2007 1:56:38 PM
cocobear
Status: offline
2 more, switch installation (poor quality picture), and inside the fuselage showing it's monocoque construction. The switches and fueler will get sheeted over and then I will cut foles and add scale doors.
Click for fullsize
Click for fullsize
(in reply to cocobear)
       Post #: 27
RE: Albatros DVa - 12/30/2007 12:06:25 PM
OldScaleGuy
Status: offline
Looks like you are about ready to begin covering. Lookin' Good.
_____________________________
The difference between a good model and a great model is sandpaper.
www.LeisureRcModels.com
       Post #: 28
RE: Albatros DVa - 1/6/2008 8:56:46 PM
semeraro
Status: offline
Hi there,
I am the other club member Dave mentioned in his original post. We are both building the DV from his plans. We
get together about once a week to check progress. He shows me some new techniques and I try to slow him
down a bit. This is my first giant scale gas model and building along with Dave has helped my confidence quite
a bit. I thought the build would be a lot more difficult than it is. I have been taking lots of pictures of both airplanes
as they progress. Dave invited me to post some to this thread. Here are a few pictures of my progress. The first three
are of my rudder control installation, bending the wing tip bow, and cap stripping the lower wing. The last one is
a picture of Dave's fuse with the top wing in place. You can see the switch installation clearly in the last picture.
Regards,
Dave Semeraro
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 29
RE: Albatros DVa - 1/7/2008 3:00:32 AM
TFF
Status: offline
How are you going to make the spinner? It looks great!
(in reply to semeraro)
       Post #: 30
RE: Albatros DVa - 1/7/2008 10:04:20 PM
cocobear
Status: offline
Dave S is doing a GREAT job. Kind of makes me feel like a hack. This is his first large scale model. He has done lot of stick and tissue stuff and I have always felt that is the ultimate training ground!
DJ
(in reply to TFF)
       Post #: 31
RE: Albatros DVa - 1/7/2008 10:27:00 PM
OldScaleGuy
Status: offline
Lookin' good. So, do we have a new scale competitor here?
       Post #: 32
RE: Albatros DVa - 1/7/2008 10:31:59 PM
cocobear
Status: offline
He's planning his debut at the Mint Julep. I said no stinking Sportsman, Expert Baby!
(in reply to OldScaleGuy)
       Post #: 33
RE: Albatros DVa - 1/8/2008 2:50:48 PM
semeraro
Status: offline
Thanks TFF,
The spinner is purchased from Dave. He got it from Airizona Modelcrafters I think. It is a nice spun aluminum
job.
Dave
(in reply to TFF)
       Post #: 34
RE: Albatros DVa - 1/8/2008 3:00:43 PM
semeraro
Status: offline
I have always wanted to compete in RC scale. Like Dave says, I am planning to take the albatros to Mint Julip. I also want to
fly at the nationals at Muncie and the WWI fly in there this summer. I think three meets is about all I will be able to manage
this year. They are all within four or five hours of home. I will fly the Albatros in expert. I am also trying to finish up a
small Tiger Moth from Gordon Whitehead plans that I may throw in the van and fly in fun scale at Mint Julip.
As you know Dave is definitely not a hack. His advice to me is not to spend much time on stuff nobody is going to see. But
I cant resist trying to make scarf joints perfect and stuff like that. Last weekend Dave and I figured that I take about a
day to do what he does in about an hour, depending on the task. He has also introduced me to the joy of CA and 80 grit
sandpaper. Most of my building in the past has been smaller free flight and rc stuff. I used a lot of ambroid and titebond
on those models. CA definitely speeds things up.
Regards,
Dave S.
       Post #: 35
RE: Albatros DVa - 1/8/2008 4:55:06 PM
TFF
Status: offline
I saw Dave's plane last year at the MJ and I enjoyed watching it fly and looking at it on the ground. I liked his presentation.
I have the plans for that Tiggy, too. I like Whitehead designs.
       Post #: 36
RE: Albatros DVa - 1/11/2008 8:18:59 PM
semeraro
Status: offline
I have a little more progress to report. I have been working on the stab mount and sheeting the tail cone. This part is not easy for me.
The pictures tell the story. The first shot shows the ribs for the stab stubs going on. That part was not too bad. The next picture
shows the top of the stab stubs sheeted. Again, not to hard. The third shot shows part of the fuse sheeting that meets the
top of the stab sheeting. Now things get hard. Fitting this sheed turned out to not be so bad. The right side went on ok
but I messed up the left side and left a gap between the front of the sheet and the rear of the sheet on the fuse it meets
with. This gap was enourmous,,,, to me at least. I took the piece off and replaced it. It looks better now. The third and forth
pictures show the result so far. The sheet just above the ones I just put on has proved to be a real pain. I have split two
pieces so far. I decided to soften the wood first and I have a couple of pieces soaking in water and amonia as I type this.
My next attempt will be to bend the wet wood to shape and let it dry a bit to relieve the stress. I did this with another
airplane and was able to bend a 1/8th in thick piece 180 degrees around a 1.5 inc radius. I think wetting the wood should
help. If I get too frustrated I will just switch to another task. I still have my ailerons to attach and lots of other stuff
to do. Anyway that is it for now.
Regards,
Dave
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to TFF)
       Post #: 37
RE: Albatros DVa - 1/11/2008 10:24:24 PM
OldScaleGuy
Status: offline
Nice progress, sure is lookin' good.
       Post #: 38
RE: Albatros DVa - 1/13/2008 2:50:57 AM
cocobear
Status: offline
Making good progres on the dummy engine. Completed elevator hinges today. At that point in the project where you work and work with no apparent progress. Dave S and Iwere talking and Ithink we are both going to go the GT route on the wings. More pix soon.
DJ
       Post #: 39
RE: Albatros DVa - 1/13/2008 10:29:18 PM
semeraro
