RE: Albatros DVa
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Albatros DVa
Page: <<   < prev  1 2 3 [4] 5 6 7   next >   >>
Login
RE: Albatros DVa - 3/6/2008 2:50:59 PM
cocobear
Status: offline
Put together my rocker boxes and cam gear drive and gave them a coat of finishing resin. I hope I will be assembling the engine this weekend.
DJ
(in reply to FokkerAce)
       Post #: 76
RE: Albatros DVa - 3/14/2008 3:41:59 AM
cocobear
Status: offline
have got all the engine parts in primer. I built the radiator this morning and am getting ready to cover the wings! I need to wash and prep the GT fabric tomorrow. Dave S. came over with a gallon of nitrate and butyrate last Saturday. Let the doping begin!!!
(in reply to cocobear)
       Post #: 77
RE: Albatros DVa - 3/14/2008 1:58:38 PM
caribefoto
Status: offline
"wash and prep" - I get the wash part, what else do you do to "prep" before applicaton. Thanks..John
_____________________________
Well, if crime fighters fight crime and fire fighters fight fire, what do freedom fighters fight?
       Post #: 78
RE: Albatros DVa - 3/14/2008 3:23:08 PM
cocobear
Status: offline
Iron and trim strings. It is kind of a pain in the a.. It feels like wasting time but is required.
(in reply to caribefoto)
       Post #: 79
RE: Albatros DVa - 3/17/2008 1:52:41 PM
semeraro
Status: offline
Dave and I did some more work on the DVs over the weekend. He mounted his top wing and did some adjustments to the wing alignment. He also
sheeted his wing stubs. I worked on my cowl. I have attached some pictures of the wing stub sheeting and of me doing some fine tuning of my cowl
with a rasp. Dave says the rasp is the secret to a really smooth finish and is also one of the secrets to how he is able to build so fast.
DS
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 80
RE: Albatros DVa - 3/17/2008 7:20:21 PM
vertical grimmace
Status: offline
I heard a tip about applying dope. After applying it, turn the wing over and let it dry upside down. This way the dope settles to the top surface and requires less applications. Also it may help with the problem of sticking to the spars. I would still apply wax to them though. I think after the initial coats are complete the final coats could dry right side up but it sounded like a good idea.
Good luck. I found the fabric to be great fun actually.
(in reply to semeraro)
       Post #: 81
RE: Albatros DVa - 3/27/2008 3:57:03 PM
cocobear
Status: offline
More proress. Getting into the fun stuff. Below are some pictures of the guns and shell shoots and the radiator in primer.
DJ
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to vertical grimmace)
       Post #: 82
RE: Albatros DVa - 3/28/2008 4:18:33 PM
rcfanuk
Status: offline
Dave, do you have any pics or details on the radiator build?
Steve
       Post #: 83
RE: Albatros DVa - 3/28/2008 5:44:31 PM
allanflowers
Status: offline
Also Dave, any info on how you do the fuselage skinning?
I assume you use balsa? Thickness? Scarf joints or what? How do manage the more compound surfaces without getting kinks in the form? Glue used? Tricks you are willing to disclose?
Sorry about picking your brain so obviously but you ARE the master.
(in reply to rcfanuk)
       Post #: 84
RE: Albatros DVa - 3/30/2008 2:51:00 AM
cocobear
Status: offline
The radiator is really quite simple. It is just 4 1/16th plywood plates slightly taller than the airfoil. You just match drill (or if your lucky laser) a bunch of holes for the "cooling tubes". I use soda straws for those. The top frame and deck are 1/64th ply. It is primed in the picture. I will next spray the tubes with aluminum engine block paint and then mask them and paint the rest to match my chips.
Allan, the fuselage is 3/32" balsa sheet the panels are but jointed using Great Planes Thick CA. On the Albatros, the only real challenging part is the tail cone area. You can look back at Semeraro's rant on that:-). If you stick to the scale paneling in most plywood aircraft, the sheeting goes on pretty easy as they didn't design many compound curves in as that would make the plane harder to build. One trick on the sides is to use longer pieces of sheet for strength and then just score in the panel lines with a very sharp exacto. when you stain the fuselage the stain will accumulate and you will not be able to see the difference compared to a real joint. I just stained mine (finally!!) today and will post pictures in a few day once the tone of the stain mellows a little. It is horrifyingly dark when first aplied. I always almost panic. It is already looking much better. I like to let it set about a week before clearing.
DJ
(in reply to allanflowers)
       Post #: 85
RE: Albatros DVa - 4/1/2008 5:56:05 PM
allanflowers
Status: offline
Thanks, it's great to have these tips - will save me a ton of problems on my next project.
Allan
       Post #: 86
RE: Albatros DVa - 4/8/2008 5:55:26 PM
cocobear
Status: offline
Some more progress and pictures. i have fallen behind where I wished to be due to some medical stuff.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 87
RE: Albatros DVa - 4/8/2008 7:23:14 PM
OldScaleGuy
Status: online
That's lookin' great!
The difference between a good model and a great model is sandpaper.
www.LeisureRcModels.com
       Post #: 88
RE: Albatros DVa - 4/10/2008 2:56:30 PM
cocobear
Status: offline
I set up my aileron servos and linkages and soldered extensions. Finally ready to cover the top wing. I will try and remember to take some pix of the setup before I cover.
DJ
(in reply to OldScaleGuy)
       Post #: 89
RE: Albatros DVa - 4/10/2008 3:39:15 PM
