hrrcflyer
VA, USA Status: offline
Calvin, I personally haven't seen an Ultrasport 1000 with a gas engine in it, but I think they will be too heavy, even with the lighter gas engines available because you would still need things like an ignition battery, etc. but I may be wrong. Anyone who has flown a US of any size will tell you that flaps are not required for the plane. That being said, I did add them to my brothers plane but he hasn't flown it yet. If you do decide to add flaps I'd suggest you have a transmitter that is capable of mixing flaparons as well as mixing the flaps with elevator so the plane doesn't pitch down when the flaps are deployed. Personally, I don't like mechanical retracts, but ff you're still interested in using retracts, Spring Air makes excellent quality units, plus they have the advantage of automatically going down if air pressure is lost. I don't know their web address right off hand. but you can look them up. I've also been told that their customer service is outstanding and they are very helpfull with any questions you may have. Have you given any more consideration regarding your engine? Given your three engine choices listed, If it was my plane, I'd put the YS 140 in it. It has more power than a Saito 150 at a very comparable weight. Also you have the advantage of being able to move your fuel tank allot closer to the airplane CG since the motor is pumped. Also, you may want to consider asking a moderator to move this thread to the "Kit Building Forum". You might get a few additional responses to your questions.
_____________________________
Fly safe and have fun!! David
