RC David -> RE: My Hurricane 550's first Hover (5/16/2008 7:30:53 AM)
ea01bg, That's a good question. I think several are running the 15t pinion but I think it depends on the other gears. I'm not even familiar with the gearing on this model so I'm sure I'll have questions for you guys when I get it ready to fly. On the pinion, I've read some posts that said the H550 kit came with a 14t and some a 15. I want to have a 13, 14, 15 and 16 so I can get it geared just right for a lower headspeed on the z20A motor and my (2) 3s 2200mAh packs. I'll probably get all 4 when I order just in case. I've noticed that my LHS has many different brands of 550mm blades in stock but NO 500mm blades so I guess it's good I'm going to go 550 to start. Kaelan, I think I will probably get 3300mAh packs after I see how much flight time I get on 2200's with my gearing and motor choice. Dave D. quote:
ORIGINAL: ea01bg I'm using the 3300 packs from Hobby City. I'm only running them for 10-11 min but they are not even warm after. I need to get a charger that displays how much it puts back into the battery. I was also looking at the zippy 4000's they are not that much larger. RC David , what gear combo are you going to run for the 550 blades?
