RC David
IL, USA Status: offline
ea01bg, Sorry if I confused you. The two main issues are: #1 There is a "chance" that a CF frame (metal content) can block the 2.4 Ghz signal from a receiver antenna and cause a problem. Not a high probability but a "chance" that if you are using a single module receiver like the AR6100 and it's on one side of the heli and you fly too far out with the receiver/antenna on the FAR side of the heli NOT FACING YOU, it can loose the signal. If you have an AR7000 that has (2) receive modules and position it properly (3+ inches apart with each modules antenna legs pointing in opposite directions) then you have a MUCH better chance of NOT losing the signal (unless you fly BEHIND a large metal object like a bus or water tower). I DO NOT want to experience this with a heli (especially a 450 or 550) so I will ONLY use the AR7000 receiver in my helis and in doing so I don't think I'll have a problem. I'm still not sure I want a CF frame H550 but mainly because of the cost of replacement. #2 The "reboot" issue seems to affect some people but not others. Basically you NEVER want the Spectrum receiver to reboot in mid flight. The older receiver firmware requires 3-10 seconds to re-boot and that likely means "SPLAT" for your heli. This is caused by the BEC voltage dropping too low. It has not been a problem for me on the mini-Titan yet but I did experience it with my Blade CX-2 last fall. The newest receivers have been updated to re-boot in about 2 seconds. I think Spektrum is updating older DSM-2 receivers if you send them in. I have not done so yet. I hope I made that more clear. I'm new to helis but not RC. I raced cars/trucks and had a boat back in the early 80's. Now that I'm back in the hobby, I'm hooked on 2.4Ghz and will never go back to 27, and 72 Mhz radios. Now, I did just read a post that said you could NOT fit a 6S battery in the plastic frame H550. Can someone confirm this and explain further? If it's true then I guess that's the deal-breaker. I'll HAVE TO buy the CF frame because I want to be able to use 6S packs in the future. Also, I flew my E325 mini-Titan outside for the first time today. It was a handfull in 10-12MPH wind so I'M DEFINITELY buying the Hurricane now -) Dave D.
