RE: Sundowner 50 Arf    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: Sundowner 50 Arf
Page: <<   < prev  25 26 27 28 29 [30] 31 32 33 34   next >   >>
Login
RE: Sundowner 50 Arf - 5/8/2010 11:33 PM
Iflyglow
Score: 122
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: BIGBADBOB65
TSYSSA: What motor/prop are you using to get 140+ mph? My Jett .56 is less.
Thanks Bob
He uses a 30CC gas engine.
Hide Signatures
(in reply to BIGBADBOB65)
       Post #: 726
RE: Sundowner 50 Arf - 5/8/2010 11:41 PM
Iflyglow
Score: 122
Status: offline
quote:
ORIGINAL: summerwind
i must have gotten a wing tube (from the same place) that was made from a different batch, although it's the same spec as yours, because mine weighs more than an ounce.
So was I was a little off, trying to remember the weight from memory. It is a huge difference though of over 2 ounces though. The axles that I machined for it and Foam tires from another left over Arf contribute to a Huge weight breakcombined with the Carbon Wing tube. I also have aluminum wheel collars on the plane, since every little bit helps.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to summerwind)
       Post #: 727
RE: Sundowner 50 Arf - 5/9/2010 2:17 AM
summerwind
Score: 148
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: Iflyglow
haha....i really didn't care, just thought maybe you drilled some holes in the CF wing rod too in order to save even more weight
_____________________________
AMA 70865
Team Satellite
Hide Signatures
(in reply to Iflyglow)
       Post #: 728
RE: Sundowner 50 Arf - 5/9/2010 4:47 AM
Syssa Aircraft
Score: 175
Last Login: 4/13/2013
Status: offline
14x14...but going to a 14x16 soon (custom mod prop) with the SAP-180HP (30cc) gas engine as you can tell the engine is not getting loaded enough because when your straight and level flying at 100 and you punch it..it goes right up to top speed and stays there.
I really wish I could buy a 14x18.,,,any idea where to get one?
I'll have to put the tuned pipe to get it over 170 mph. Right now its just got a stock pitts muffler on it.
Also, I really want a carbon fiber wingtube...the aluminum one is an anchor...where do you get it?
Best regards, Todd Syssa
Syssa Aircraft Performance
Hide Signatures
       Post #: 729
RE: Sundowner 50 Arf - 5/9/2010 5:26 AM
Iflyglow
Score: 122
Status: offline
quote:
ORIGINAL: Iflyglow
So was I was a little off, trying to remember the weight from memory. It is a huge difference though of over 2 ounces. The axles that I machined for it and Foam tires from another left over Arf contribute to a Huge weight breakcombined with the Carbon Wing tube. I also have aluminum wheel collars on the plane, since every little bit helps.
The correct terminology would be a CF Wing Tube.
< Message edited by Iflyglow -- 5/9/2010 6:30 PM >
Hide Signatures
       Post #: 730
RE: Sundowner 50 Arf - 5/9/2010 6:32 PM
Iflyglow
Score: 122
Status: offline
quote:
ORIGINAL: Iflyglow
I am getting there. The new solid balsa stab is fastened, and the engine box has been reinforced with a couple CF strips, a little glass cloth, and a little Balsa. I also fuel proofed the inside of the fuse. The little .60 should haul it nice.
Delete please:
Hide Signatures
       Post #: 731
RE: Sundowner 50 Arf - 5/10/2010 5:21 PM
earlseaholm
Score: 100
Last Login: 3/11/2013
Status: offline
I took some time yesterday and got a few more flights on the SD. What a sweet plane.
I flew some of the old .60 pattern maneuvers, and it nails them - pilot could use a little practice.
Reverse cuban 8s, split S, 3 rolls, loops, etc. all at 1/2 to 3/4 throttle.
I had to make some full out runs too!!
Landed on the last flight - draggin it in at a couple clicks off idle - taxied up to my feet.
At the bench I took the plug out and the wire was virtually gone - a little lean.
I can't say enough good about the Jett .56 - the thing has never died on me.
I did check the stiffness of the horizontal, and mine is pretty stiff. Lucky enough to get some good wood - I guess.
< Message edited by earlseaholm -- 5/24/2010 6:48 AM >
Hide Signatures
       Post #: 732
RE: Sundowner 50 Arf - 5/11/2010 4:20 AM
airraptor
Score: 130
Status: offline
any pics of this 30cc in the nose of a .46 size plane?
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
       Post #: 733
RE: Sundowner 50 Arf - 5/12/2010 8:44 AM
summerwind
Score: 148
Status: offline
hey how about us guys with the Jett 56 powered SD's meet up with the EVO 60 guys and let's race?
any takers?
AMA 70865
Team Satellite
Hide Signatures
(in reply to airraptor)
       Post #: 734
RE: Sundowner 50 Arf - 5/12/2010 2:57 PM
Syssa Aircraft
Score: 175
Status: offline
This link should work.
http://www.youtube.com/watch?v=GGdPKIiKmuU
Fast forward to 8:50 to see a somewhat fast pass.
Hide Signatures
       Post #: 735
RE: Sundowner 50 Arf - 5/13/2010 5:15 AM
earlseaholm
Score: 100
Status: offline
any takers?
Now that is interesting. If possible, count me in.
Hide Signatures
       Post #: 736
RE: Sundowner 50 Arf - 5/13/2010 5:25 AM
summerwind
Score: 148
Status: offline
yeah i'll bet "Iflyforfood"...will chicken out
AMA 70865
Team Satellite
Hide Signatures
(in reply to earlseaholm)
       Post #: 737
RE: Sundowner 50 Arf - 5/15/2010 3:40 AM
Iflyglow
Score: 122
Status: offline
Bring it to WI and its on. Make a trip to Air Airventure 2010 "EAA Convention", and bring your plane's, and I will supply the 800' landing strip with no noise restrictions or obstacles. Am I supposed to buy the Beer since I have money left over?
Hide Signatures
       Post #: 738
RE: Sundowner 50 Arf - 5/15/2010 3:44 AM
summerwind
Score: 148
Status: offline
haha.....Beer good.
got an ALW yet?
mine came in at 2,645 grams, or 5.84lbs. which i'm real happy about.
you'll probably be lighter with all the do-dads you did, but to be under 6lbs should make this a sweet flyer.
AMA 70865
Team Satellite
Hide Signatures
       Post #: 739
RE: Sundowner 50 Arf - 5/15/2010 3:56 AM
Iflyglow
Score: 122
Status: offline
haha.....Beer good.
got an ALW yet?
I am @ 6 lb's even, and currently locating the receivers (Jr 6200 w/remote). I hope to run the engine some more in the plane on sunday weather permitting. It's still crappy and cold and windy here in WI. We just recieved snow a week ago again. We are now in the thunderstorm Tornado month.
< Message edited by Iflyglow -- 5/15/2010 6:26 AM >
Hide Signatures
       Post #: 740
RE: Sundowner 50 Arf - 5/15/2010 4:03 AM
summerwind
Score: 148
Status: offline
man that sucks.............i know bad you wanna see that EVO run too
hope it gets better soon.
AMA 70865
Team Satellite
Hide Signatures
       Post #: 741
RE: Sundowner 50 Arf - 5/15/2010 6:33 AM
Iflyglow
Score: 122
Status: offline
I along with a couple other guys in the club want to see it go too. There is another Sundowner 50 with the same combo in the club, but He is really slow working on it. I was hoping to have someone to race against, but I don't think He's ever going to get it finished for this summer.
< Message edited by Iflyglow -- 5/15/2010 9:17 AM >
Hide Signatures
       Post #: 742
RE: Sundowner 50 Arf - 5/15/2010 9:52 PM
summerwind
Score: 148
Status: offline
only thing left to do is to cut the opening in the bottom of the fuse.
using smaller and lighter digitals in the wing, and the throttle saved weight. also using a dual battery system, batteries are under servos.
12oz BJ tank
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by summerwind -- 5/16/2010 6:12 PM >
AMA 70865
Team Satellite
Hide Signatures
       Post #: 743
RE: Sundowner 50 Arf - 5/16/2010 8:28 AM
Iflyglow
Score: 122
Status: offline
Good News! I ran out to the field today, and put three flights in. The combo performed awesome. The performance is spectacular with vertical that is out of this world. The second flight was a dead stick, as it hickuped and I quickly throttled back, but the tank was empty! The 11 oz tank does not last very long and goes by very quickly when you are having fun. The landing was uneventfull thanks to are huge field.
The exhaust exiting the Bottom also funtioned better than I thought it would since there was "NO OIL on the stab at all and I don't have to worry about fuel running back in the fuse if I overfill the tank. The takeoff's are very easy with just a little rudder, and the landing's are uneventfull. It does come in hot, but no different than my other two race style planes, but looses lift faster than the Shoestring and Midget Mustang which will float forever. I never did try any stall tests because I was to busy buring holes in the sky. I set it up with the recommended throws, and ballanced it right at the 2-1/2 inches like the manual calls for. My all up weight is 6lb 1 OZ since I added an ounce to the engine mount to finalize the ballance point. I plan on programming a little more aileron in it, but other than that, not touching anything else. Loops and split S's as large as you want to make them. I did leave the side hole open, and am trying to figure out how to finish it off as a cooling vent. The whistle it makes in the air is awesome. I have two little Cheater holes for Cooling on the Bottom of the Cowl, and the Slits. I had no problems with overheating at all. The slits really help as I have also done that to my Midget Mustang and Shoestring.
5/16/2010 Put another five flights on it today. This combo really hauls the mail. Take off to totally unlimited vertical.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Iflyglow -- 5/17/2010 5:28 AM >
Hide Signatures
       Post #: 744
RE: Sundowner 50 Arf - 5/17/2010 6:30 AM
AngLeo
Score: 105
Last Login: 4/9/2012
Status: offline
Finally...a good flyin day,and was able to run a few tanks thru my new Sundowner.What a great flyin plane!Needed one click of up and it was strait and flew very,very smooth.In fact almost to smooth,the low rate suggestions in the book for the elev. is too low,I had to add nearly full up on turns,to keep it up at med speed.I flicked it to high rate and all was better.It flew like a dream...smooooooth as can be, just a click or two up on the thottle @ landing and she comes right in...a little hot,but not bad at all.Im very happy with the performance of it and even at a rich setting....its a rocket,hittin 75-80 easily,and keeped its gentle flight almost the same.I love this plane! Its a great addition and will keep for years.
Hide Signatures
       Post #: 745
RE: Sundowner 50 Arf - 5/19/2010 3:18 AM
bob27s
Score: 105
Last Login: 5/7/2013
Status: offline
12oz BJ tank
Its coming together nicely
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
Hide Signatures
       Post #: 746
RE: Sundowner 50 Arf - 5/20/2010 11:41 PM
Iflyglow
Score: 122
Status: offline
12oz BJ tank
I only have one battery with 20 ga Silicone insulated wire. I fabricated a harness that uses MINI Deans plugs similar to the picture of a large scale unit meant for large planes but on a smaller scale for a simple positive electrical circut. I am not that trusting of switchs and vibration.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 747
RE: Sundowner 50 Arf - 5/21/2010 3:41 AM
summerwind
Score: 148
Status: offline
that's a nice setup. but i'll take a redundancy setup anyday over using just 1 battery pack.
you still fly with the possibility of losing power from a single pack.
chances of losing a battery on 1 switch and a switch going bad on the other pack are astronomical........thus, (and it's not mandatory) you still fly with the chance of losing a high speed model in the air thus creating a missle.
oh wait, you are only turning around 15K......my bird is powered by an 18,600rpm screamer...........much more dangerous.
AMA 70865
Team Satellite
Hide Signatures
       Post #: 748
RE: Sundowner 50 Arf - 5/21/2010 8:01 AM
Iflyglow
Score: 122
Status: offline
I just wish we lived closer so you could actually see first hand how the 10" prop is so much more effective vs the little 9" prop. You might have a little bit more Top end maybe with a 9-8, but it will take forever to get there, and never ever match the Climb Performance or Acceleration out of a corner that my set up spinning a 10-8 @ well over 15 thou will. It appears as if you are under rating the EVO and over rating the Jett with your numbers again, since Dubb's own RPM for the EVO with a 10-8 was 15,500. Every indication I have read places a Jett .56LX @ about 18,000 with a 10-6. Where are you finding the extra 600 rpm that other guys have not mentioned (The 9-8 turns 18,000, and the 10-6 turns a little over 17,000 from another member with a Jett .56).
9" props remind me of the "Old Ducted Jett Days". Alot of noise with sluggish acceleration.
< Message edited by Iflyglow -- 5/21/2010 9:35 PM >
Hide Signatures
       Post #: 749
RE: Sundowner 50 Arf - 5/23/2010 4:10 AM
earlseaholm
Score: 100
Status: offline
I enjoy all this bench racing. Sure wish I could travel to WI for the big race.
Maybe you fellas should come to MT. There is some beautiful scenery here, and no noise restrictions at our field either.
My Jett LX will turn a 10-6 APC around 17500 (now that it is broke in) at 3900 ft altitude.
I have tried a number of props in the 9 - 8.75 - 10 range, and the 10-6 is the best of the bunch.
I am going to try a 10-7 just to see, but the weather needs to dry up a little. Lots of rain in this country this spring.
Hide Signatures
       Post #: 750
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.219RCU1
