RE: Sundowner 50 Arf
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: Sundowner 50 Arf
Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
Login
RE: Sundowner 50 Arf - 2/17/2008 4:14:39 AM
easton24
Status: offline
Sorry brew I have never owned a 55ax so I couldnt advise you. I flew my sd yesterday about 8 times and 2 times today. I am still running my engine rich but seems to be starting to let loose. I started yesterday with a 13-8 apc. I was getting about 10000 rpm. Flew ok but not very impressive. With a max rpm of 16000 i knew i had to get the rpm higher if I wanted to get some speed. I next flew with a 12-8 apc. Rpm went up to about 10600 so a little better. Speed wise I was unable to tell if it was faster. So I then tried a 11-8. I didnt have a apc so ended up using a master airscrew. I got 13600 rpm. Alot better rpm wise but did not improve on speed. I thought with a apc 11-8 the speed would improve. Figured I would end the day there and go to the lhs for some apc props in the 11 inch size. Today I had a 11-8 and 11-9 apc. I went ahead with the 11-9. I got around 11000 to 10800 rpm. I took her up and noticed the speed improved over the 12-8. Even in the windy conditions this plane flies great. So now I am searching for the best prop for this plane and engine combo. Due to this engine being newly released there is not much data out there for what type of props to use. Atleast these 11 inch props are not as expensive as those 14 inch props.
(in reply to Brew07)
       Post #: 101
RE: Sundowner 50 Arf - 2/17/2008 4:27:01 AM
patzane
Status: offline
Thanks guys. I will try to get some better video, my camera guy is a rookie at it. I was not sure how well the video was to come out as it was little windy. I will try to get some slow flight video next time I fly and whatever else people like to see.
Brew that does sound right. I have a new OS 55 on a Viper 500 and I am breaking her in on a 11x7 prop and getting about the same RPM reading on a stock muffler. I running her on the rich side as it new and only have 1 tank through her. Once I get her broken in I will be going to a 10x10.
_____________________________
Don't go where the path leads
But go where there is no path
       Post #: 102
RE: Sundowner 50 Arf - 2/17/2008 3:33:44 PM
Brew07
Status: offline
I did not think you could prop that low on the .55 I will have to try. 10x10 should make it scream. I got the Jett incowel muffler for 30 bucks thought I would give it a try they claim 500 if not more rpm gain. If I use this set up in the SD I would have to cut out the front of the cowel to make room for that muffler. I am in pain trying to make up my mind on what motor I should put in. Like I said in one of my posts I have a .61 FX and .55 AX on hand to use in this plane.
(in reply to patzane)
       Post #: 103
RE: Sundowner 50 Arf - 2/17/2008 3:39:58 PM
easton24
Status: offline
My thinking is if you have to cut the cowl anyway might as well put in the strongest motor.
       Post #: 104
RE: Sundowner 50 Arf - 2/17/2008 4:02:46 PM
Brew07
Status: offline
So easton you think I should try the 55 instead of the 61. I could get the 75 but I thought I would use what I got. Going to put the SD together today all but the motor till I make up my mind.
(in reply to easton24)
       Post #: 105
RE: Sundowner 50 Arf - 2/17/2008 5:37:16 PM
patzane
Status: offline
Brew you know how you like to fly. i don't think the 61 would give you a big big big speed difference than the 55. i know it work, try the 55 and if you like the speed stay with it. if no go head a bolt a 75 on nose. you can move things around with the 75 so you would not to add dead weight.
i just finish my Great Planes Viper500 with an OS 55. My total weight without fuel is 3 lbs and 12oz. Going to try 10x10 prop and work my way down for the best speed.
       Post #: 106
RE: Sundowner 50 Arf - 2/18/2008 2:13:30 AM
Brew07
Status: offline
easton did you use the stock muffler with the 75AX? I want the speed so I may bite the bullet and get the 75 just would like to know if I need the pitts mufflet or not. Thanks
       Post #: 107
RE: Sundowner 50 Arf - 2/18/2008 8:41:05 AM
patzane
Status: offline
good Brew not you hanging with the big boys. I wish there were a class of racing here in AZ that this little sundowner can enter in I would like to race. No one the fly would race me as they say I would smoke them. there was the guy from the video at would race me, but he was cheating
       Post #: 108
RE: Sundowner 50 Arf - 2/18/2008 2:06:39 PM
easton24
Status: offline
Brew I used the stock muffler. Oh by the way nice video Patzane. Looks like you got your sd scooting.
< Message edited by easton24 -- 2/18/2008 2:08:33 PM >
       Post #: 109
RE: Sundowner 50 Arf - 2/18/2008 4:37:27 PM
russm
Status: offline
patzane,i have a liltoni out there. have a moki 61 with a straight pipe on it . decent combo. but, i could pull my jett 90lx off one of my tonis here and throw it on out there. i will be back out there in a week. what do you think?
       Post #: 110
RE: Sundowner 50 Arf - 2/18/2008 11:00:55 PM
patzane
Status: offline
russm you are correct. It is the AMPS field. Great field and we flying 24\7 there. Russm that sound cool. I fly there about 3-4x weekly. I use to fly on Sat not to much any longer as to many people. PM me i give you my number and we can hook up.
Well I flew the sundowner today with a 11x9 prop. It was not as fast as the 12x8 that I had on her before. I am not a big masterscrew prop person but I put a 11x6 on the 75 and got 13,890 RPM on the ground. I will try that 2morrow and maybe try a 11x7 masterscrew to see it I can get her over 14,000.
(in reply to russm)
       Post #: 111
RE: Sundowner 50 Arf - 2/18/2008 11:10:55 PM
JS615
Status: offline
I finally got my os.91 fx on my sundowner,, had to fill in the predrilled mounting holes with dowls and redrilled new ones for the 90 size mount. i will use a slimline pitts muff,, im thinking of using a apc 12x7 prop,,, anyone have a better suggestion on the prop size???
       Post #: 112
RE: Sundowner 50 Arf - 2/18/2008 11:12:29 PM
russm
Status: offline
patzane, i will be back in az monday. my dad normally flys mon, wed, and fri mornings. he does not fly on weekends either. his group likes to leave the weekends to the working men. i will bring my jett 90lx with me. looking forward to seeing the sundowner fly. it will be my next purchase with the same combo you have. let the races begin.
       Post #: 113
RE: Sundowner 50 Arf - 2/19/2008 4:36:18 PM
roofer
Status: offline
JS615
Does the cowel fit over the 91 fx or did you need to butcher it got a 91 fx + slimline pits on the shelf and was wondering wil it fit the SD maybe a pic if you can - my experiance with the 91 fx I would even go to a 13 x prop and you should stil rev out to max rpm with a 15% + nitro
(in reply to russm)
       Post #: 114
RE: Sundowner 50 Arf - 2/19/2008 10:01:57 PM
JS615
Status: offline
i was shocked when i put the cowl on and the engine did not touch the cowl anywhere, it was very close in places but it did not touch,
now i dont have the slimline muff on yet so im not sure if its going to clear the cowl or not? i will find out thursday,... i dont know if the 13x prop will work well or not,, this is a small plane and there is only so much clearance from the prop to the ground, i sure dont want to be mowing alot of grass going down the runway..
(in reply to roofer)
       Post #: 115
RE: Sundowner 50 Arf - 2/20/2008 12:56:55 AM
