Building a SPAD Trainer
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> Building a SPAD Trainer Page: [1] 2   next >   >>
Login
Building a SPAD Trainer - 12/9/2007 10:23:55 PM
mclina
Status: online
My 9 year old wants to build her own plane, so we started on a SPAD trainer today. I am building it sort of per the BUHOR 25 plan, but enlarging it a bit. I am also adding a coro fuselage to hide/protect the radio gear and fuel tank, and to raise the wing up a little higher for better stability. Make sense?
So far we have the coro fuse, aluminum channel, engine mount, and wing pretty much fabricated. Right now, the wing span is 72", but the spar is shorter, so I'll probably trim the wing by 6-8". I'll see how stiff it is after it's all done and mounted. The wing is 2mm and the fuse & ailerons are 4mm. The tail will be built per the BUHOR 25 plan using 4mm.
I'm thinking that we will power it by a .32 BB engine, maybe a Magnum. Maybe even a .40LA. I am shooting for a nice, slow, stable flyer, suitable for training a 9 year old.
I am going to swipe the servos from the SPA3DT I started. I'm going to shelve that thing for a while.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
If all of your friends were named Cliff, would you jump off them? - Hugh Neutron
       Post #: 1
RE: Building a SPAD Trainer - 12/9/2007 11:57:42 PM
broke_n_bummin
Status: offline
I think you're going to need something bigger than a .40 LA. I know you started out with the plans for a .25, but you've made the wing bigger, added a fuse, and I'm hoping you enlarge the tail feathers as well. It will take at the minimum a .46. If you make the wing bigger, the fuse needs to be longer and tail feathers need to be bigger. All that adds up to extra weight. I have an excel spreadsheet called design.xls that I use when I'm enlarging plans. You can look it up on the net or e-mail me and I can e-mail it to you.
broke_n_bummin@alltel.net
< Message edited by broke_n_bummin -- 12/9/2007 11:58:01 PM >
I may have to give up R/C Airplanes and Golf ... They make my Torrets act up...
(in reply to mclina)
       Post #: 2
RE: Building a SPAD Trainer - 12/10/2007 12:15:15 AM
draftman1
Status: offline
that looks good. you will probably need the 46 size engine. I am flying the debonair. it has a smaller wing. but it sure is indesctructable. have fun, Im forgeting about balsa right now.
(in reply to broke_n_bummin)
       Post #: 3
RE: Building a SPAD Trainer - 12/10/2007 12:44:54 AM
ChrisSpad
Status: offline
first.... If your going to enlarge the wing, you need to enlarge the tail, and fuse length proportionally. Second, on the fuse - pick one. You don't need both the angle and the corofuse, its overkill. Third, the difference in stability of a high wing coro fuse, vs the aluminum channel is negligible. While there is some pendulum effect, the difference isn't enough to be noticable.
I'm not trying to be negative, but, your changes, while looking good on paper will most likely result in a plane that won't fly nearly as well as one built by the plans.
No matter how many planes i plant, they just won't grow.
[link]http://www.chrisspad.com/planes/[/link]
(in reply to draftman1)
       Post #: 4
RE: Building a SPAD Trainer - 12/10/2007 12:45:10 AM
mclina
Status: online
Thanks for the input. The larger engine does make sense, and there really isn't much of a price difference. I did scale up the tail a bit as well.
Here is everything dry-fit to show it's proportions. I'll weigh it after all of the gear is installed, minus the engine, and then we'll decide which engine to put in it. The way I'm mounting the fuse onto the rail, I can slide the whole assembly to correct for CG at the end.
Click for fullsize
       Post #: 5
RE: Building a SPAD Trainer - 12/10/2007 12:48:22 AM
mclina
Status: online
Chris,
Thanks for your input. If you don't think the coro fuse is worth the bother, then maybe we'll ditch it. So far, following plans have worked out much better for me than making it up as I go
I appreciate the advice.
(in reply to ChrisSpad)
       Post #: 6
RE: Building a SPAD Trainer - 12/10/2007 3:37:21 AM
broke_n_bummin
Status: offline
It might be the angle of the pic, but that fuse looks kind of short. A typical trainer with a 60" wing span should have roughly a 40" fuse. According to my excel program, a 72" wing would call for a 50.4" fuse, a 19.5" horizontal stabilizer and a 9" vertical stabilizer. It says a .45 will fly it. a .46 LA with a 11X5 prop would drag it around just fine for a trainer.
       Post #: 7
RE: Building a SPAD Trainer - 12/10/2007 11:11:02 AM
mclina
Status: online
Yes, the fuse is too short for that wingspan. I need to pick up another piece of channel and cut a longer one, and I am going to shorten the wing to 60 inches.
Thanks.
       Post #: 8
RE: Building a SPAD Trainer - 12/10/2007 1:19:08 PM
bkdavy
Status: online
Just build to the debonair plans. You'll be very satisfied. That's what learned on, and the plane is still flying. I use it for AP now.
Brad
       Post #: 9
RE: Building a SPAD Trainer - 12/10/2007 2:22:28 PM
draftman1
Status: offline
i love my deb!!
(in reply to bkdavy)
       Post #: 10
RE: Building a SPAD Trainer - 12/10/2007 7:15:00 PM
propbuster
Status: online
Check out this site for design calculators. I find them very useful when designing and building from scratch.
http://www.geistware.com/rcmodeling/model_calc.htm
Never run out of Altitude, Airspeed or Ideas all at the same time.
http://blueridgeaeroworks.blogspot.com/
       Post #: 11
RE: Building a SPAD Trainer - 12/19/2007 4:00:17 AM
OzMo
Status: offline
Nice wing! that size is close to a SPADET wing. take a look at those plans and modify your fuse to match. I think you are spot on in the wing. I have built a simular one for my nieces. I used the fuse building method That a SWIZZLE stick has and spad wing almost like yours. Here is a pic and it flys very slow and gracefully as you would want it to for a youngster. This plane has 2 pine door strips for fuse and a 1/4" balsa wing box with all the goodies in it. conventional balsa monokote tail for lite weight. the wing box wasn't glued to the rails until balancing time just like most spads.
Click for fullsize
Click for fullsize
< Message edited by OzMo -- 12/19/2007 4:02:52 AM >
Yes dear, I did glue my hand to the airplane to keep from dropping it.
(in reply to propbuster)
       Post #: 12
RE: Building a SPAD Trainer - 12/19/2007 10:58:51 AM
mclina
Status: online
Thanks. Progress has been a bit slow lately. It's hard to motivate a 9 year old to finish a project that she won't be able to use for 5 months.
We have mostly been gathering pieces, and we pretty much have everything now. I decided to try a Super Tigre 40. I have had good luck with my ST 45, and the ST 40 is only $49.99 and I had a $10 coupon code for Tower. I picked up a radio yesterday, JR Sport S400, same as in two of my other planes. I went with JR Sport because their servos are slightly narrower than Hitec and Futaba, and will fit into the 3/4" channel. I also have 3 other JR boxes to buddy with.
I have extended the fuse to 42". I am leaving the wing as-is for now. I'll bring a pair of scissors to the maiden flight, and I can trim a few inches off each wingtip if need be.
I'll post some pictures when it gets closer to finished. Thanks
(in reply to OzMo)
       Post #: 13
RE: Building a SPAD Trainer - 12/27/2007 9:42:21 PM
mclina
Status: online
We have made a little more progress on the trainer. We are going to leave the coro fuselage on for now. It only weighs a couple of ounces and we like the way it looks. It balances right on the spar as-is. We just need to i
