NeoGenesis
OH, USA Status: offline
quote:
ORIGINAL: huttcraft I bought a New Bright planning to mod it, but it was pretty obvious once I got it that a nitro or FE conversion is a serious undertaking. If you follow some of the threads here in the Unusual RC forum you'll see that virtually every component of the sled needs to be swapped out or beefed up for it to *sort of* handle the extra power. These things are made to go 5mph, not 50. The front suspension is soft plastic, the struts and springs are for appearance only, the track suspension geometry's not right, and none of the transmission components can handle a bigger motor. And even if you replace all of the suspension and drive components you're still running an ABS plastic sled. I welcome MNKay, Fastorange and the others who've actually taken a serious run at modding the New Bright to throw in their own 2 cents here -- they may completely disagree. All of that said, I'm still convinced the New Bright is a better modding platform than the Walmart and Radioshack toys. There's more room under the cowl and seat, and there's lots of info in this forum on what works and what doesn't. I've never looked at an Art Attack sled up close, but at least it was designed with nitro in mind. For performance it might be the best off-the-shelf choice. It would be great if Jordan Krupp's REV went into production, but at this point it remains a one-of we can only drool over. Does anyone know what model this is?: http://www.youtube.com/watch?v=0UPt4_VFDTI What a rocket! I suspect its a custom but this video makes it look like quite a success. Dave That appears to be a Artattack sled. I'm building one up right now....just unsure of whether I want to go electric or nitro. Neo
< Message edited by NeoGenesis -- 1/3/2008 2:28:03 AM >
_____________________________
Fly it like you stole it!!!!!!!! Revver Brother #122
