RE: XF-85 Goblin started...
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: XF-85 Goblin started...
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: XF-85 Goblin started... - 1/8/2008 6:36:27 AM
Boomerang1
Status: offline
quote:
It was intended to be used on a B-36 which incidentally would make an awesome PSS, or powered model.
Correct! - John,
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by Boomerang1 -- 1/8/2008 6:38:23 AM >
_____________________________
Distributor for: Nothing! So my posts can be unbiased.
(in reply to crashontakeoff)
       Post #: 26
RE: XF-85 Goblin started... - 2/16/2008 7:54:05 PM
petronio
Status: offline
It doesn't look like too much progress ...but sanded the fuselage after having applied putty (and hopefully filled all scratches and holes), made the cutouts for the "diagonal rudders", and made a first attempt of a cabin, I need to find a bigger bottle with no grooves on it. I have little time to work on it unfortunately, I will let you know when there's more done . byee
Click for fullsize
(in reply to Boomerang1)
       Post #: 27
RE: XF-85 Goblin started... - 2/17/2008 6:42:10 PM
petronio
Status: offline
Fitted temporarily all the tail feathers to see how the EGG looks like, you can also see how I made the canopy. Greeetingsss
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to petronio)
       Post #: 28
RE: XF-85 Goblin started... - 2/18/2008 1:57:04 AM
scale dail
Status: online
Looking good! will finish with Flite Metal?
If it's not scale,it's not worth building.
       Post #: 29
RE: XF-85 Goblin started... - 2/18/2008 9:11:14 AM
petronio
Status: offline
Flite Metal is too heavy for a (presumably) PSS model, but I will surely use chrome monokote , I just hate the fact that I will have to be very careful to apply it otherwise I would melt the foam .
(in reply to scale dail)
       Post #: 30
RE: XF-85 Goblin started... - 2/29/2008 3:32:35 PM
FliteMetal
Status: offline
I knew it was but a matter of time and one of these would appear on my radar. It
really looks nice. You are correct in that without skinning or at a minimum glassing
your surface it would not be a proper Flite-Metal covering candidate...not the weight
of Flite-Metal, but the all up weight with a hardened surface. At the size it is, your in
for a treat when it flies well.
Here's a more detailed look at the plane through Fiddler's Green who won't be hurt
this post at all... ; )
Keep the photos coming in : )
< Message edited by FliteMetal -- 3/1/2008 3:57:27 PM >
Ed Clayman
http://www.FliteMetal.com
       Post #: 31
RE: XF-85 Goblin started... - 2/29/2008 9:21:51 PM
petronio
Status: offline
I will. Thanks for the "tips" Ed, a friend of mine is building his first warbird, a TF P-51 1:5 scale and used Flite-Metal, it looks awesome and considering its his fist one its even more impressive.
Returning to mine, in fact I'm a bit concerned, even though it is glued together and it will be ironed I have the impression that it probably will fall into pieces if I only slightly bump it to the ground, I dont know if I should glass at least the bottom a bit. No worries by the end of next month I should have some more done, but first I will try to redo the cabin. Thanks for the interest.
ps: I love the GOb, but I have to say its the kind of plane you either like very much or dislike very much . Hopefully it flies after all, though the fact of being PSS makes it rather more difficult, if it doesn't fly to well and survives the maiden I may electrify it with a DF, we'll see. byee
(in reply to FliteMetal)
       Post #: 32
RE: XF-85 Goblin started... - 3/17/2008 9:46:34 PM
FliteMetal
Status: offline
Where have things progressed to on your Goblin? I can imagine building a dolly and 1/3 hot wired,
skinned and FM'd one with a small turbine would be interesting... : )
Ed Clayman
       Post #: 33
RE: XF-85 Goblin started... - 3/18/2008 2:52:24 PM
petronio
Status: offline
Its Eastern holidays right now here in Spain, I thought I could dedicate the little Gob some time but unfortunately it stays the same, I didn't even have time to see it and give it a good-night kiss . Precisely because of my shortage of time I ordered the wing to be done by a friend, so at least I will save some time on that, once the wing arrives theres not much more to be done on the fuse (though I will probably end up glassing at least the bottom of it), then I will start ironing which will take me some time since I would like to make some sort of rivets. We will see.. Thanks anyway for your interest, no worries I will keep you updated as soon as I have some more done. Byeee
       Post #: 34
RE: XF-85 Goblin started... - 4/19/2008 2:50:28 PM
FliteMetal
Status: offline
I'm beginning to believe "All Hallows Eve" will be here before we see another Goblin
What format were your templates in? Would you be willing to give up a set of them?
Ed Clayman
       Post #: 35
RE: XF-85 Goblin started... - 4/20/2008 11:11:07 AM
petronio
Status: offline
Hi,
No time to work on it yet but I will surely finish it in July (hopefully). The plans were drawn in Autocad 2006 in dwg format. First of all I have to finish the plane and see if it flies ok, then I will consider if publishing the plans or not, lots of work in it ).
       Post #: 36
RE: XF-85 Goblin started... - 5/5/2008 2:06:57 AM
lz-23
Status: online
Cool project! Will keep an eye on your progress!
       Post #: 37
RE: XF-85 Goblin started... - 7/6/2008 10:07:14 PM
petronio
Status: offline
I went this weekend home after ages and was able to work a bit on the elevator. The good news is that in 2 weeks or so I will bring the bird with me and I will be able to continue with him in my spare time (hopefully), so here's the bit I made. Byee
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 38
RE: XF-85 Goblin started... - 7/6/2008 11:25:27 PM
Ram-bro
Status: online
interesting work. So is this going to be a sloper?
       Post #: 39
RE: XF-85 Goblin started... - 7/7/2008 6:37:05 PM
petronio
