Tail Drive gear/pulley    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> Tail Drive gear/pulley
Page: [1]
Login
Tail Drive gear/pulley - 12/12/2007 6:39 AM
Bjorn
Score: 100
Last Login: 11/20/2012
Status: offline
I stripped the gear/pulley on my 450S. The new one is made of metal. As there is no set screw, how do I fasten it to the shaft? The old one was plastic, with a press fit on to the splined shaft. Thanks in advance!
Bjorn
Hide Signatures
       Post #: 1
RE: Tail Drive gear/pulley - 12/12/2007 7:07 AM
321
Score: 100
Last Login: 3/2/2011
Status: offline
Use a drop of Loctite #609 to glue the pulley to the shaft. It also works great for pinions.
_____________________________
YLF
Hide Signatures
(in reply to Bjorn)
       Post #: 2
RE: Tail Drive gear/pulley - 12/12/2007 8:48 PM
techrtr
Score: 100
Last Login: 12/13/2012
Status: offline
Are you talking about the pulley under the big pulley on the main shaft? I didn't know you could get a separate metal gear. I've had a couple fail and it's a pain to take out the whole assembly. Would be nice to be able to loctite a new gear onto the slined end of the old shaft.
Hide Signatures
(in reply to 321)
       Post #: 3
RE: Tail Drive gear/pulley - 12/12/2007 9:05 PM
321
Score: 100
Status: offline
No, the upgrade assembly has a plastic gear and a metal pulley. There are no splines for the pulley, so that's where the Loctite comes in.
One note: you have to be careful about where you position the pulley on the shaft so that it lines up with the tailboom.
YLF
Hide Signatures
(in reply to techrtr)
       Post #: 4
RE: Tail Drive gear/pulley - 12/14/2007 6:16 AM
HeliTB
Score: 100
Last Login: 2/8/2013
Status: offline
It's the green loctite that comes in the Rex kit. Eventhough the main pinion has a set screw, I always add a little green loctite between the pinion and shaft to be safe.
Raptor v2 OS 37/Bobcat Jet OS .55 AX
Extra 330L 25% SV26cc/SIG Kougar OS .46 AX
Hide Signatures
(in reply to 321)
       Post #: 5
RE: Tail Drive gear/pulley - 12/15/2007 8:17 PM
Bjorn
Score: 100
Status: offline
Thanks guys, all fixed. A real pain to get at!
Bjorn
Hide Signatures
(in reply to HeliTB)
       Post #: 6
RE: Tail Drive gear/pulley - 12/17/2007 6:19 AM
[]TEX[]
Score: 126
Last Login: 4/30/2013
Status: offline
I have done the thread lock trick and it always fails.
This is what I did:
I got an SA belt gear/pulley, the white one. I removed the plastic pulley, then took the aluminum pulley and pressed it onto the splines with a vise. Never had an issue with the belt or pulley again.
Happy flying!
Lynx Team Pilot
GrandRC Field Rep
Hide Signatures
(in reply to Bjorn)
       Post #: 7
RE: Tail Drive gear/pulley - 12/17/2007 6:30 PM
techrtr
Score: 100
Status: offline
Good idea. I'm going to try that.
Hide Signatures
(in reply to []TEX[])
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.438RCU1
