kahloq -> RE: KMP NEW A1 Skyraider - pics (12/17/2007 4:42:16 PM)
quote:
ORIGINAL: Craig-RCU The only part of full scale planes built to take that kind of rough contact are the landing gear. You can lift and swing a model around by its tail surfaces with no worries that they are going to break off. You couldn't do that with a full scale plane. Since you don't really need to be able to swing a model around by its tail surfaces, manufacturers of ARFs and kits might be able to ease up a bit on the over design of structures aft of the C.G at least. This is not true. Sorry Craig, but there are many, many videos showing ground crew man-handling the tails of full size planes to push them around..so yes you could do that. Most KMP planes are not over designed in the tail areas. In fact, there is very little balsa or ply in the tails at all. Case in point is the ME-109E. The only ply back there was an internal block to mount the tail wheel to. There are no formers. Nothing. For KMP planes at least, having to add nose weight is exactly scale as these planes are built closer to scale then any World Models or Great Planes(Top Flite is not included in this) arf out there. Real plane engines are heavy...period. In order to keep scale outlines, weight is needed in some form usually up front. Other manufacturers may build their planes to look kinda close to scale, but they cheat and do things to make them either fly easier, or balast without weight by shortening the tail section, or other no scale things.
