Cuda canopy
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> Cuda canopy
Page: [1]
Login
Cuda canopy - 12/12/2007 7:36:42 PM
5150flyer
Status: offline
I am now building the canopy structure and wanted your suggestions. To make the canopy flush on all sides is a major project. Is it worth it or do you guys have some tricks you can give me?
1) Should the canopy hang over the rear top deck or not? If so then is it worth making it flush?
2) Should the canopy be flush to the sides or let it drop down over the sides?
Thanks - I could have never built this thing without your help.
       Post #: 1
RE: Cuda canopy - 12/12/2007 10:05:47 PM
as722
Status: offline
It should be flush all the way around. The easiest way I have found is to cut some balsa sticks 3/8" x 7/16". This will give you a 1/16 on each side and once the canopy is on you can sand the fuse sides to match the canopy. As for the back of the canopy frame, just trace the front of the turtle deck on the 1/8 balsa and cut it on the inside of the line. This will give you the correct gap for the canopy assuming your blade isn't bigger than a 1/32" or so. I hope this helps.
Albert
< Message edited by as722 -- 12/12/2007 10:26:03 PM >
_____________________________
Carden Aircraft
(in reply to 5150flyer)
       Post #: 2
RE: Cuda canopy - 12/13/2007 12:50:02 AM
5150flyer
Status: offline
quote:
ORIGINAL: as722
Albert
Sorry to be so thick, but what is the 3/8" x 7/16" balsa sticks do? Thanks
(in reply to as722)
       Post #: 3
RE: Cuda canopy - 12/13/2007 6:51:06 PM
as722
Status: offline
The side rails for the canopy frame.
Albert
Carden Aircraft
       Post #: 4
RE: Cuda canopy - 12/13/2007 7:18:23 PM
5150flyer
Status: offline
quote:
ORIGINAL: as722
Albert
OK, I get it. Very helpful!
(in reply to as722)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.328RCU1
