sailing1
OK, USA Status: offline
AirTech, I am also running the Evolution 26GT, version one. Mine has the side mount muffler which I guess could be a little lighter than your pitts style. I think we are using the same prop, an 18x6 Evolution wooden prop. My ignition box is mounted on the bottom of the engine box just behind the firewall and the ignition battery, a 4 cell NiMh is mounted inside the engine box at the extreme front, just behind the firewall. My spinner is light weight nylon with a lightened back plate (Great Planes I think). I am not using the wheel pants so that is a savings of 3 ounces and I do not use a choke servo so there is another 1-2 ounces. I also swapped out the stock tail wheel for a Sulivan one but think they are probably about the same weight. It is strange that our balance is so different with the same engine. I just guessed at CG on my first flight and had the ignition battery back by the wing tube and the receiver battery at the back towards the rear of the platform and was way tail heavy. Talk about snappy--it pretty much flew in a harrier and was a bear to land. I then moved the ignition battery to its current location behind the firewall and moved the receiver battery to the front of the platform. That made the plane a little nose heavy but oh so much better on my nerves. After a couple more flights and experimenting with battery placement on the platform I now have the CG so that the plane will just nose down a little on a 45 degree upline. I have also found the 14 ounce tank I am running to be more than enough fuel to fly 10-12 minutes with lots of reserve. This is my first experience with an Evolution engine or a gasser this small and I have to say I am really impressed with the engine and plane combination. My two concerns with this engine/airframe were balance and viberation and neither has proved to be a problem.
