AirTech
TX, USA Status: offline
quote:
ORIGINAL: Steve Campbell Finally, the completed hook-up. Note the angles of the new rudder tiller, and the tiller on the tali wheel unit. I bent that by the scientific method of putting the end in my Pana-Vise and grabbing it near the base with a pair of mini vise grips. DuBro balls and cups are used for the connection, joined by a short piece of medium inner nyrod with 2-56 threaded couplers in each end. This makes a stiff steering rod, yet one that will give a bit if necessary. It might have too much ground feedback for a cheap servo, but the Futaba 9151 in the Extra is holding up fine after close to three years with this arrangement; and that is a 15 pound airplane. I'm also using a 9151 on this (hopefully!) less-than-ten-pound model. At any rate, this set-up isn't difficult to fabricate and works better than any tail wheel steering system I've tried to date. In the second photo, note the extreme deflection and how much the wheel is turned... IOW, much more than needed for positive ground handling. As always, YMMV... Steve, The reason springs are used in most Haig style tailweels is to absorb the forces generated during ground operations. A direct connection will transfer to much torque to the rudder and consequentially to the rudder servo. I am using a Small Sig Tailweel Assembly (SIGSH756) in several of my planes. These are very light and easy to setup.
