102" Yak/DA-85
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Quique's Aircraft Support >> 102" Yak/DA-85
Page: [1]
Login
102" Yak/DA-85 - 12/15/2007 1:45:01 AM
eraser
Status: offline
Just thought I would let every Yak lover out there know that I just completed the 102" with a DA-85 and the Jtec large volumn muffler. I was concerned about balance.With the muffler way up front and 2 reciever, 5 cell 1700 ni-cads, and 1 1700 4 cell ignition battery mounted in the engine box, it balanced right on the money. I also only used 1 rudder servo to minimize weight behind the wing tube.
The fuselage and stabs are Gen 2, and the wings are Gen 1.
Total dry weight is 24lb. 6 oz.
Hopefully it will have enough power, but I have yet to test fly it do to snow and extreme cold.
       Post #: 1
RE: 102" Yak/DA-85 - 12/15/2007 3:49:06 PM
krayzc-RCU
Status: offline
kewl and that DA-85 is a beast....
_____________________________
smooth as silk!
(in reply to eraser)
       Post #: 2
RE: 102" Yak/DA-85 - 12/15/2007 11:53:15 PM
eraser
Status: offline
Well, I braved the cold and snow and flew the maiden today.
Fired up the DA-85 for the first time and I could not believe how smooth it was. I was shocked, it seemed as smooth as my DA-100. After a little tweeking of the needles, I took off over a snow covered runway (yeah I'm nuts).
Power seemed to be pretty close to the DA-100, but I didn't push it on the first flight. I was skepticle at first, but I think this is going to be a good combination after the motor gets broken in.
(in reply to krayzc-RCU)
       Post #: 3
RE: 102" Yak/DA-85 - 12/16/2007 1:55:51 AM
krayzc-RCU
Status: offline
eraser
u r seeing what we/u that actually have the 85 the real deal and the net is still saying:
its could not be as smooth as a twin
its could not be as powerful as the 100
it could not be XXXX
what a joke those guys......
smooth as silk!
       Post #: 4
RE: 102" Yak/DA-85 - 12/16/2007 1:56:12 PM
pelone
Status: offline
Well,
that are really good news!
I recieved a part of my new Gen3 on friday, the rest must be there tomorrow ( there was a transport mistake)....
I'm still not decided between the DA 85 and the 3W 85XI CS, but i has time because i have exams to prepare
Would it be possible to get a few pics of the engine/muffler installation? Did you encounter any problems installing the powerplant?
David
David
       Post #: 5
RE: 102" Yak/DA-85 - 12/17/2007 2:28:23 AM
eraser
Status: offline
David
I dont think you can go wrong with either motor. I know the DA-85 works great. A couple of picks.
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to pelone)
       Post #: 6
RE: 102" Yak/DA-85 - 12/17/2007 9:44:44 AM
pelone
Status: offline
Thank you!
Wow you really maidened your plane in the snow
I can't use a pitt's muffler like you did because of the noise restrictions here, I will have to work out a solution for that because i have to use a muffler which has 80mm diameter or a pipe that would be very long...
David
       Post #: 7
RE: 102" Yak/DA-85 - 1/5/2008 7:46:59 PM
Wildstyle
Status: offline
Eraser, what does the Jtec muffler weigh?, or do you have a part number?. What servos did you use? I was thinking DA-85 w/mtw td75 can.
Anthony
       Post #: 8
RE: 102" Yak/DA-85 - 1/5/2008 8:21:24 PM
Rezagh
Status: offline
Good Job Eraser! Looking awesome in that snow :-) Any videos at all?
Thanks for sharing,
Reza
Quique's Aircraft Company
(in reply to Wildstyle)
       Post #: 9
RE: 102" Yak/DA-85 - 1/6/2008 4:34:04 AM
krayzc-RCU
Status: offline
i think my jtec was around 10 oz
smooth as silk!
(in reply to Rezagh)
       Post #: 10
RE: 102" Yak/DA-85 - 1/8/2008 2:20:32 PM
pelone
Status: offline
Hello,
meanwhiel i received my Gen III Yak and the problem is that i can't figure out how to fit a proper muffler for a DA85 or a 3W85 in the muffler tunnel
Has anybody an idea ????
< Message edited by pelone -- 1/8/2008 2:21:39 PM >
David
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
