can someone recognize this aircraft    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $129.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Full Scale planes, cars, helis, boats >> Airplanes - Full Scale >> can someone recognize this aircraft
Page: [1]
Login
can someone recognize this aircraft - 12/16/2007 10:41 AM
Ragz
Score: 100
Last Login: 5/18/2013
Status: offline
I saw this aircraft this morning at the local airport. Wondering what it is.
Click to see fullsize image.
Click for fullsize
_____________________________
Anurag
Hide Signatures
       Post #: 1
RE: can someone recognize this aircraft - 12/16/2007 10:49 AM
Rotorwrench
Score: 100
Last Login: 10/11/2008
Status: offline
Looks like a Long EZ. A composite aircraft developed by Burt Rutan. Also from http://www.velocityaircraft.com/airabout.html
Hide Signatures
(in reply to Ragz)
       Post #: 2
RE: can someone recognize this aircraft - 12/16/2007 12:04 PM
Ragz
Score: 100
Status: offline
if so, wonder whats it doing in central India
Anurag
Hide Signatures
(in reply to Rotorwrench)
       Post #: 3
RE: can someone recognize this aircraft - 12/16/2007 8:36 PM
seemefly_1
Score: 115
Last Login: 8/13/2010
Status: offline
i would be wondering where the nose wheel is
soloed november 17, 2007 at 4:50pm eastern time
Hide Signatures
(in reply to Ragz)
       Post #: 4
RE: can someone recognize this aircraft - 12/16/2007 9:49 PM
slick95
Score: 105
Last Login: 2/7/2011
Status: offline
You have to retract the nose wheel to get in and out.
SLICK
Hide Signatures
(in reply to seemefly_1)
       Post #: 5
RE: can someone recognize this aircraft - 12/17/2007 8:33 AM
Lowlevlflyer
Score: 100
Last Login: 3/30/2011
Status: offline
It's a Vari EZ or a Long EZ, cant tell for certain which one. Also, with the three blade prop, it COULD be a Berkut, which is basically just a modified, higher performance version of the Long EZ. I always loved these aircraft, they are REAL performers if they're built right.
< Message edited by Lowlevlflyer -- 12/17/2007 8:35 AM >
AMA# 770153
"Hey ya'll, watch this..."
Hide Signatures
(in reply to slick95)
       Post #: 6
RE: can someone recognize this aircraft - 12/17/2007 8:35 AM
Ragz
Score: 100
Status: offline
Why would they retract the nose wheel like this? Even if its for repair, shouldnt it be supported correctly with something underneath the nose?
Anurag
Hide Signatures
(in reply to Lowlevlflyer)
       Post #: 7
RE: can someone recognize this aircraft - 12/17/2007 5:46 PM
Taildragger726
Score: 100
Last Login: 5/22/2013
Status: offline
I think the EZ aircraft have a tendency to tip back on the main gear without the pilot/passenger installed as ballast. It is standard operating procedure to rest on their nose and provisions are in order for resting in that state. To enter the aircraft,the pilot firsts lifts the nose and extends the nose gear. Being careful not to let the aircraft tip back onto the rudders or propeller, then hops in.
RedAeroRC
Hide Signatures
(in reply to Ragz)
       Post #: 8
RE: can someone recognize this aircraft - 12/17/2007 10:40 PM
Chad Veich
Score: 265
Last Login: 5/25/2013
Status: online
quote:
ORIGINAL: Ragz
Standard operating procedure when nobody is in the cockpit.
Hide Signatures
(in reply to Ragz)
       Post #: 9
RE: can someone recognize this aircraft - 12/18/2007 3:49 AM
seanpcola
Score: 100
Last Login: 7/30/2011
Status: offline
I and a friend built a Long-Eze, starting in 1981 and finished around 1989. The nose down parking served several purposes. Mainly, as mentioned is the tendency to fall back without pilot weight. Also it may help while tied down, resisting wind gusts. It is also retracted in the air for drag purposes. Rutan felt that a retractable nose gear was worth the effort as a drag penalty but the mains would add to much complexity and weight to the design and was therefore deemed not worth the additional effort. During building the bottom of the nose at the ground contact point is fitted with a metal and/or rubber shoe as a sort of sacrificial piece to take the scrapes when lowered. As a side note there have been a few cases of pilots either forgetting to lower the nose gear or the gear not locking completlely and as the aircraft slowed on rollout the nose gently dropped onto the shoe acting as a pretty effective brake with no damage to the airframe. Forgetting something. I'll edit later if my old feeble mind remembers.
Sean
Hide Signatures
(in reply to Chad Veich)
       Post #: 10
RE: can someone recognize this aircraft - 12/18/2007 10:05 AM
Ragz
Score: 100
Status: offline
thanks for the explanation.
Anurag
Hide Signatures
(in reply to seanpcola)
       Post #: 11
RE: can someone recognize this aircraft - 12/18/2007 2:34 PM
spider007
Score: 100
Last Login: 1/8/2011
Status: offline
canard builders forums
http://www.canardzone.com/forum/index.php
http://www.canardcommunity.com/
Hide Signatures
(in reply to Ragz)
       Post #: 12
RE: can someone recognize this aircraft - 12/24/2007 8:01 PM
Tbone4life
Score: 100
Last Login: 7/23/2009
Status: offline
Did John Denver own 1 of these?
Club Saito #540
Hide Signatures
(in reply to spider007)
       Post #: 13
RE: can someone recognize this aircraft - 12/27/2007 8:28 PM
johnm15141
Score: 100
Last Login: 5/5/2011
Status: offline
quote:
ORIGINAL: Tbone4life
No he was "owned" by one of these!
http://www.airsafe.com/events/celebs/denver.htm
Hide Signatures
(in reply to Tbone4life)
       Post #: 14
RE: can someone recognize this aircraft - 12/27/2007 8:56 PM
Gravityisnotmyfriend
Score: 100
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: seanpcola
That exact thing happened a few years ago at my local airport. I witnessed a long eze make a beatufil landing on the mains - but I noticed the nose gear was not down. After the plane skidded to a stop, the pilot got out, extended the nose gear and took off. The plane (apart from some scuffed up paint) was undamaged. Apparently he didn't want to come in and get ridiculed for his mistake - I can't blame him.
The mathematician sees the glass as twice as big as it needs to be. The engineer sees it as full with a Safety Factor of 2.
Hide Signatures
       Post #: 15
RE: can someone recognize this aircraft - 1/3/2008 1:16 AM
seemefly_1
Score: 115
Status: offline
thats not nice
Hide Signatures
(in reply to Gravityisnotmyfriend)
       Post #: 16
RE: can someone recognize this aircraft - 2/20/2008 11:25 PM
Ercoupe N99879
Score: 100
Last Login: 4/15/2013
Status: offline
At Oshkosh during the airshow, we refer to these aircraft as "YARD DARTS"
Hide Signatures
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
