HO-229
MD, USA Status: offline
Kevin, First, all this stuff is subjective & the user defines what is best for his/her needs. I find the following to be true in my case, it would be best for you to form your own opinions The below are my comments/opinions 1) I do not concern myself with complex alignment jigs 1A) The FRL & shape at the subject FS station is all that matters 2) It is easy to find a flat surface upon to do the build utilizing the half method scheme 3) Errors are easily corrected utilizing the half method scheme prior to fabricating the mirror image side 4) fidelity is ensured if not guaranteed 5) I am defining the project from own plans & drawings, I am not utilizing someone else's plans. 6) The parting board scheme has only the level of fidelity of the craftsman manufacturing it 7) simple 8) less time & material to manufacture 9) It does not matter were the powel pins are located or how many 10) joining/separating the left & right halves is quick & facilitates sanding & filling I believe the parting board technique has its place if reproducing aircraft that are whole Hope this helps Regards, Dave
