Hybrid w/DL50 pics
Tower Hobbies
Logged in as Guest
  Printable Version
Ohio Model Products Fusion X3D - 90
Seller:  cdp2buck
Details:   $525.00   |  10/7/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> OMP - Ohio Model Products Support Forum >> Hybrid w/DL50 pics
Page: [1] 2   next >   >>
Login
Hybrid w/DL50 pics - 12/16/2007 8:07:19 PM
cwhite
Status: offline
Here are some pics of my almost-finished Hybrid. Try guessing where the color scheme came from. This is what is on it: DL50 w/stock muffler, HS5955's on all surfaces, (2) Elite 1500 6v packs on receiver, (1) Elite 1500 4.8 for ignition, control horns from Extreme Flight, carbon fiber control rods, and 7 ROLLS OF FILM. The weight came in between 15.5lbs and 16lbs (bathroom scale-so not very accurate). This kit has been a fun build and it looks great. Too bad there's snow on the ground and it's probably be a couple of months before I can fly it.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 1
RE: Hybrid w/DL50 pics - 12/16/2007 8:16:11 PM
cwhite
Status: offline
Here's a couple more.
Click for fullsize
Click for fullsize
(in reply to cwhite)
       Post #: 2
RE: Hybrid w/DL50 pics - 12/16/2007 8:53:23 PM
LeeHop
Status: offline
Beautiful job!
When you cover wings like that, is it red over white or white over red? I'm serious - I'm a covering novice
-Lee
       Post #: 3
RE: Hybrid w/DL50 pics - 12/16/2007 9:17:01 PM
mrbigg
Status: offline
I agree, looks sharp!
_____________________________
PROVERBS 15:22 - Plans go wrong for lack of advice; many counselors bring success.
(in reply to LeeHop)
       Post #: 4
RE: Hybrid w/DL50 pics - 12/16/2007 9:58:59 PM
AFSalmon
Status: offline
I know! Isn't that the Greg Poe Edge 540 scheme? Looks great! Sounds like a super light build job as well. Great job!
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes, Team OMP Captain
(in reply to mrbigg)
       Post #: 5
RE: Hybrid w/DL50 pics - 12/16/2007 10:46:24 PM
Berwyn Bill
Status: offline
quote:
ORIGINAL: AFSalmon
Looks like my old .40 size OMP Edge ARF!! Nice Job!!
(in reply to AFSalmon)
       Post #: 6
RE: Hybrid w/DL50 pics - 12/17/2007 12:37:48 AM
cwhite
Status: offline
Here's some pics of rudder servo intallation, tank location, rudder and elevator hook-up and DL50.
LeeHop - I usually like to go dark over light but it didn't matter in this case because I had the purple stripes on both sides of the white. I think you can skin that cat several different ways and do a good job. Use as little as heat as possible to avoid bubbles.
Click for fullsize
Click for fullsize
       Post #: 7
RE: Hybrid w/DL50 pics - 12/17/2007 12:42:57 AM
cwhite
Status: offline
Here's the other two:
Click for fullsize
Click for fullsize
       Post #: 8
RE: Hybrid w/DL50 pics - 12/17/2007 6:39:05 AM
blkmerlin1
Status: offline
Very nice job mine is almost finished all the construction is done need to cover and install coctrols and engine it looks like the dl-50 fits the same as a da would again nice job the ground at your place looks like the ground at mine white hope all have a good Christmas.
       Post #: 9
RE: Hybrid w/DL50 pics - 12/17/2007 1:29:43 PM
AFSalmon
Status: offline
CWhite, did you drill or cut a round hole in the firewall behind the carb for it to breath better? I had to do that for my DA 50 engines as the carb was so close to the firewall....kinda like the DL. I think the engines ran much better with this setup.
(in reply to blkmerlin1)
       Post #: 10
RE: Hybrid w/DL50 pics - 12/17/2007 5:28:57 PM
cwhite
Status: offline
I'll definately take your advise on the hole in the firewall. Does there need to be an exit hole in the back for the air to circulate?
       Post #: 11
RE: Hybrid w/DL50 pics - 12/17/2007 5:56:04 PM
AFSalmon
Status: offline
quote:
ORIGINAL: cwhite
In the back of what? I did not put any hole elsewhere in the fuse if that is what you are asking. The carb doesn't really breath air from the fuse but rather the hole allows the air in the cowling to feed around the back easier...at least that was my theory! It just seemed kinda tight and closed off with the carb that close to the firewall. Plus with the choke valve open it will hit the firewall depending on how much spacing you have.
       Post #: 12
RE: Hybrid w/DL50 pics - 12/17/2007 8:51:51 PM
Pita
Status: offline
That is a sharp looking plane. Would you post a video of your first flight? I know we all would like to see that beautiful bird in the air. What did you think about the quality of the kit?
       Post #: 13
RE: Hybrid w/DL50 pics - 12/17/2007 9:23:19 PM
cwhite
Status: offline
I'll definately post a video when I can get out to the field.
(in reply to Pita)
       Post #: 14
RE: Hybrid w/DL50 pics - 12/18/2007 3:11:04 AM
carmerxr400
Status: offline
How did the CG come out. I have read that the Hybrid comes out a little tail heavy with a DA-DL setup. I have the fuse all done on mine and I'm going to start on the wings this weekend. I will be putting a DL in it. How did you get to the throttle and choke linkage to hook them up.
I suffer from AAADDDRCA. Accute Adult Attention Deficite Dissorder Due To Radio Controlled Aircraft.
       Post #: 15
