monocote cleaning reciepe    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> monocote cleaning reciepe Page: [1] 2   next >   >>
Login
monocote cleaning reciepe - 12/17/2007 1:25 AM
mjg3
Score: 100
Last Login: 5/21/2013
Status: offline
whats your reciepe for cleaning up your plane after agood day of flying?
Hide Signatures
       Post #: 1
RE: monocote cleaning reciepe - 12/17/2007 2:07 AM
BadSplice
Score: 100
Last Login: 5/22/2013
Status: offline
I have a spray bottle of rubbing alchohol. Cheap, works great on the plane, and on your hands to get the oil off before eating lunch
_____________________________
May the Force be With You; and if necessary, be prepared to go to the Hobby Shop and get More Force!
Hide Signatures
(in reply to mjg3)
       Post #: 2
RE: monocote cleaning reciepe - 12/17/2007 2:10 AM
Flylow
Score: 100
Last Login: 4/14/2013
Status: offline
Automotive windshield washer fluid. Less than a dollar a gallon and easy to find.
Have Fun! - Flylow
Hide Signatures
(in reply to mjg3)
       Post #: 3
RE: monocote cleaning reciepe - 12/17/2007 2:23 AM
nothinbetr2do
Score: 115
Last Login: 5/23/2013
Status: offline
i just use regular window cleaner in a spray bottle, try to find some without amonia(spelling)
< Message edited by gamesbeer1 -- 12/18/2007 10:29 PM >
just say no to "shelf queens"
aaf# 111285-25
A.C.E. member
Hide Signatures
(in reply to Flylow)
       Post #: 4
RE: monocote cleaning reciepe - 12/17/2007 3:54 AM
nitrohog
Score: 100
Last Login: 5/1/2011
Status: offline
I use windex most of the time, but the thing that works the best is baby wipes.
Hide Signatures
(in reply to nothinbetr2do)
       Post #: 5
RE: monocote cleaning reciepe - 12/17/2007 4:35 AM
mjg3
Score: 100
Status: offline
I brought this topic up only because now that im flying the great planes supersportrter mainly white and blue the 409 with rubbing alcohol dont seem to be cleaning it to well. I couldnt seem to see all the smears on my trainer ( lanier explorer ) which is yellow. thanks for all the info
Hide Signatures
(in reply to nitrohog)
       Post #: 6
RE: monocote cleaning reciepe - 12/17/2007 6:46 AM
rceric
Score: 100
Last Login: 6/2/2012
Status: offline
Simple Green
Hide Signatures
(in reply to mjg3)
       Post #: 7
RE: monocote cleaning reciepe - 12/17/2007 8:09 AM
Don41
Score: 100
Last Login: 9/2/2010
Status: offline
I'd use caution with Windex. That's what is commonly used for attaching Monokote trim to Monokote. It would seem to me that it MAY loosen the trim.
Hide Signatures
       Post #: 8
RE: monocote cleaning reciepe - 12/17/2007 2:29 PM
jetmech05
Score: 133
Last Login: 5/26/2013
Status: offline
windex with amonia will loosen trim.....I've used straight alcohol..now I use baby wipes..they all have pluses and minuses....
Hide Signatures
(in reply to Don41)
       Post #: 9
RE: monocote cleaning reciepe - 12/17/2007 2:54 PM
JL636
Score: 100
Last Login: 5/25/2013
Status: offline
The absolute best I've run across is a tid bit I got off of RCU. I mix a cup of rubbing (denatured) alcohol with a cup of windshield washer fluid. That stuff cuts through the grim and residue like you would believe. I won't use another mix, this stufff works too good. Joe
AMA 344995
ProBro2423
Hide Signatures
(in reply to jetmech05)
       Post #: 10
RE: monocote cleaning reciepe - 12/17/2007 6:46 PM
Deadeye
Score: 119
Status: offline
I've found it isn't so much what your spraying on the plane to clean it, as it is what you are wiping it off with. Sprayway glass cleaner and microfiber rags here.
Randy Rossmiller, member, Golden Triangle Flyers
Theres no such thing as too much power. Member, Club Saito
Ultra Sport Brotherhood #52
Hide Signatures
(in reply to JL636)
       Post #: 11
RE: monocote cleaning reciepe - 12/17/2007 7:53 PM
bkdavy
Score: 146
Status: offline
Windex and the microfiber rags from Wallyworld for me. When the rags get too disgusting, a quick wash in a bucket with Tide and Oxyclean. Rinse, ring, dry, and they're ready for another couple months.
Brad
Hide Signatures
(in reply to Deadeye)
       Post #: 12
RE: monocote cleaning reciepe - 12/17/2007 8:35 PM
jmupilot
Score: 100
Last Login: 1/14/2012
Status: offline
Windex wont do anything to the monokote its just used to apply the trim as a slippery agent to keep the sticky side of MonoKote Trim from adhereing before you get it in place.. We use it on full size car and aircraft decals too. Just squeege out the excess and allow to dry. It does nothijng the the adhesives or glue used on decals or MonoKote.
Pete
< Message edited by jmupilot -- 12/17/2007 8:36 PM >
AMA CD2098
Saito Club #562
Hide Signatures
(in reply to Don41)
       Post #: 13
RE: monocote cleaning reciepe - 12/17/2007 10:41 PM
Deadeye
Score: 119
Status: offline
quote:
ORIGINAL: jmupilot
Pete
While your statement is true as a slippery agent, the ammonia in Windex and Glass Plus does kick off the adhesive side on the Monokote. Take a small swatch and wet it down, stick it to a small swatch of white and let dry overnight. Peel off the next day and you will see the color left on the white.
It doesn't stick it well enough to not use trim solvent or iron the edges down, but it does start to activate it.
Hide Signatures
(in reply to jmupilot)
       Post #: 14
RE: monocote cleaning reciepe - 12/18/2007 12:48 AM
*JCB*
Score: 105
Last Login: 5/12/2013
Status: offline
Simple Green here. I buy it by the gallon (cheap too)! Then if you want the shiny look, just go over the plane with a dry microfiber towel and whamo, you got a nice lookin' plane.
Ultra Sport Brotherhood #25
Hide Signatures
       Post #: 15
RE: monocote cleaning reciepe - 12/18/2007 6:45 AM
DanPatoyian
Score: 100
Last Login: 10/11/2008
Status: offline
Try Speed Clean, look at thier web site www.speedclean.us It can't harm any plastic, keeps it looking new while getting off all the crud. Even full-size aircraft piots us it to clean thier planes.
Hide Signatures
(in reply to mjg3)
       Post #: 16
RE: monocote cleaning reciepe - 12/18/2007 7:11 AM
TexasAirBoss
Score: 151
Status: offline
windex or generic but I love, love VIVA paper towels !!!!
ME: "I need a good rate down to one three thousand". EXPRESS: "Roger, we''re coming down like a Bonanza full of doctors"
Hide Signatures
(in reply to DanPatoyian)
       Post #: 17
RE: monocote cleaning reciepe - 12/18/2007 10:24 PM
SeamusG
Score: 199
Last Login: 4/10/2013
Status: offline
I'm a rookie so consider the source
How about putting a coat of automotive wax (pure wax - no polish or cleaning agents!) on a clean covering - should make cleanup easier.
Yea - I was about to test the theory on my Kadet Senior. But during the maiden voyage of the "waxed" Senior - the wings collapsed on a slow loop (15th flight for the plane). Nothing left but some memories ...
Hide Signatures
(in reply to mjg3)
       Post #: 18
RE: monocote cleaning reciepe - 12/19/2007 2:07 PM
mjg3
Score: 100
Status: offline
i was told yesterday to use furniture polish (pledge) it will get rid of the smears plus make it shine. i personallly think that it would abigger mess next time you try to clean it after flying
Hide Signatures
(in reply to SeamusG)
       Post #: 19
RE: monocote cleaning reciepe - 12/19/2007 9:38 PM
Vic3D
Score: 100
Last Login: 8/12/2012
Status: offline
I only need to clean mine if I've used smoke. Otherwise it's always clean.
Hide Signatures
(in reply to mjg3)
       Post #: 20
RE: monocote cleaning reciepe - 12/19/2007 11:25 PM
tlgibson97
Score: 100
Last Login: 3/29/2011
Status: offline
I use a 50-50 mix of windex and alcohol.
Hide Signatures
(in reply to Vic3D)
       Post #: 21
RE: monocote cleaning reciepe - 12/20/2007 2:11 PM
telejojo
Score: 130
Status: offline
Brake parts cleaner from auto parts store or wall mart,leaves no residue and you can spray in cracks and your engine,looks new...........drys fast and it has'nt hurt any thing yet and I have benn useing it over a year.
Hide Signatures
(in reply to tlgibson97)
       Post #: 22
RE: monocote cleaning reciepe - 12/20/2007 2:12 PM
telejojo
Score: 130
Status: offline
< Message edited by telejojo -- 12/20/2007 2:16 PM >
Hide Signatures
       Post #: 23
RE: monocote cleaning reciepe - 12/22/2007 3:18 AM
mjg3
Score: 100
Status: offline
brake cleaner will be a little harsh on the monocote yeah? i know it works great on t-maxx
Hide Signatures
(in reply to telejojo)
       Post #: 24
RE: monocote cleaning reciepe - 12/22/2007 4:11 AM
timothy thompson
Score: 100
Last Login: 7/2/2008
Status: offline
e power guys no mess!
Hide Signatures
(in reply to mjg3)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.719RCU1
