RE: ASP/MAGNUM FS400AR Rebuild/Overhaul    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
Page: <<   < prev  47 48 [49] 50 51 52 53 54 55 56   next >   >>
Login
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/3/2012 5:55 PM
retransit
Score: 125
Last Login: 6/16/2013
Status: offline
I looked at all the videos. One thing I didn't see was the disassembly of the e-clips from the link pins.
Bob
_____________________________
Fleet Brotherhood #1
Club Saito #800
Hide Signatures
(in reply to Kmot)
       Post #: 1201
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/3/2012 6:00 PM
Kmot
Score: 168
Last Login: 6/19/2013
Status: offline
lol!!!
~Tom~
Hide Signatures
(in reply to retransit)
       Post #: 1202
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/4/2012 5:15 AM
Kmot
Score: 168
Status: offline
I installed the new C-E-Circlips-Rotor Clips-Retaining Rings tonight.
I do not have a special tool, so I used a combination of a seal hook and a ball head socket screw driver. Three of the e-clips came off fairly easily. But one was a bit*h to get off. My hook kept slipping under pressure and I made a lot of scratch marks on the master rod. They look bad but are superficial and of no consequence. There is no way 3.3 or even 7 lbs is going to toss these clips!
I did notice that the old clips were slightly stretched. But then, these have been installed, removed, installed, and finally removed again.
Interestingly, from the photo's posted in this thread, not all clips used by Sanye are the same. Some clips from Sanye, are black phosphate coated. Some clips, like mine, look like they are stainless steel. I ordered black phosphate coated clips as replacements.
Well, I feel like it was a worthwhile preventative maintenance to perform. Thanks to Rev77 and his insight. Although, Phillip, I did not recall that you had lots of local fellows having their clips fall off.
The weather in my area has been brutally hot, for what seems like months now. We are supposed to finally get some cooling over the next few days and I hope to get my FS400 mounted and tested with the new Rogeau Intake Manifold (RIM) during this time.
My wife loves it when I work on the dining table.
The motor opened up, the stock clips stayed in place during all those video taped runs a couple of years ago:
This clip was a beeee-yatch!!
The tools:
Old and new e-clips:
Old clip is now slightly stretched:
~Tom~
Hide Signatures
(in reply to Kmot)
       Post #: 1203
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/4/2012 5:53 AM
jmmt
Score: 100
Last Login: 6/4/2013
Status: offline
KMot
Do you prefer the Black-finish steel rings than the Stainless steel rings (from McMaster)? which one is stronger or which do you recommend?.
Hide Signatures
(in reply to Kmot)
       Post #: 1204
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/4/2012 7:10 AM
frets24
Score: 148
Status: offline
quote:
ORIGINAL: Kmot
LMAO!!!
I had been given grief over that same thing for years. Then came the day that the head on her car's engine needed to be rebuilt. Coldest, windiest, wettest winter we've had for years and the shop/shed just would not get, nor stay warm. I told her I would do the messiest parts out there but when it came time for assembly I was going to throw a blanket and a board on the kitchen table. All went well, the car ran great and it was only a few days days instead of weeks that she had to drive one of "the land yachts" which she hates to drive.(my Explorer or one of the boys' Jeeps)
She was happy, I was happy and not a word since when I cover up the dining table and "play tools and stuff" or build.
< Message edited by frets24 -- 10/4/2012 8:17 AM >
"The American taxpayer has always been politicaly deceived. Its their Birthright!"
Lord Mountjoy, The Mouse on the Moon
Hide Signatures
(in reply to Kmot)
       Post #: 1205
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/4/2012 8:20 AM
Kmot
Score: 168
Status: offline
jmmt: Technically, stainless steel is not quite as strong as plain steel. But I would not have any qualms about using SS inside the engine. I bought the black ones because it came in a order of 100 pieces versus the SS which was double the price and 1/4 as many pieces.
~Tom~
Hide Signatures
(in reply to frets24)
       Post #: 1206
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/4/2012 8:41 AM
Carosel43
Score: 100
Status: offline
Looking at the photos of my engine on page 10 (when it killed itself) mine are stainless i think. And im sure i gave them a little squese to remove the stretch. time will tell
Hide Signatures
(in reply to Kmot)
       Post #: 1207
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/4/2012 8:42 AM
Reverend
Score: 100
Status: online
To be honest, the new black clips even LOOK tougher...
Anyways, I had 40 Minutes last night so I started piecing the engine together again. Three cylinders are on, two to go.
fwiw, If you are not a friend of decorative tatoos on your main conrod, you can use two wooden chopsticks to push the clips off. The sandblasted aluminium surface really scratches very easily.
Rev
Click to see fullsize image.
Click for fullsize
If at first you don't succeed, skydiving isn't for you.
Hide Signatures
(in reply to Kmot)
       Post #: 1208
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/4/2012 8:59 AM
Reverend
Score: 100
Status: online
quote:
ORIGINAL: Kmot
Tom,
I know of at least four engines here in austria where one of these clips has come off on engines that had not been opened. All of them where SS btw. I still think that they are of inferior quality and if not enough care is taken assembling them, they will be so stressed that they may not be up to the job anymore.
Lets be honest, these Engines are not being assembled with tlc by engine specialists/enthusiasts as for example is done at AGC with the Laser engines but by some underpayed chinese bloke or girl who probably doesn't even know (or care) what this chunk of metal is for and is doing so for 12 hours a day.
To be honest, at the end of the day I would probably be yelling "zhū" at every ring while hammering it in with a large blunt mallet...
Rev
Hide Signatures
(in reply to Kmot)
       Post #: 1209
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/4/2012 2:55 PM
retransit
Score: 125
Status: offline
Tom, good pics showing the dimentional disparity of the stock vs. replacement e-clips.
I have a question about the intake gaskets. Since things do not always go well when I attempt them, what material would you use to replace intake gaskets that may be ripped or torn upon disassembly?
Bob
Club Saito #800
Hide Signatures
(in reply to Kmot)
       Post #: 1210
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/4/2012 3:23 PM
Reverend
Score: 100
Status: online
Right, to prove I am not just hot air (well at least not all the time) my club prez Klaus Heiss (thanks Klaus!) has sent me the pictures he took.
Stearman airborne with the 400
Yes tom, I know... the Prop. Wanted to test the APC as well and that was the flight that was put on ccd...
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1211
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/4/2012 4:13 PM
retransit
Score: 125
Status: offline
Love your cap to keep the prop wash out of your hair.
Bpb
Club Saito #800
Hide Signatures
(in reply to Reverend)
       Post #: 1212
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/4/2012 4:35 PM
retransit
Score: 125
Status: offline
I haven't tested any props, but this one is my favorite for looks.
Bob
Click for fullsize
Club Saito #800
Hide Signatures
       Post #: 1213
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/4/2012 4:49 PM
Kmot
Score: 168
Status: offline
Phillip, love the cap and goggles!
Bob, at your LHS or online you can buy small pieces of green gasket paper sold by "Perfect":
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDF10&P=ML
~Tom~
Hide Signatures
       Post #: 1214
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/4/2012 6:09 PM
Carosel43
Score: 100
Status: offline
Woop AGC Engineering! Ok im done :P
Although i agree, we all need to get those hats!
Also, Rev and Tom i have a present for you..check your pms
Hide Signatures
(in reply to Kmot)
       Post #: 1215
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/4/2012 7:33 PM
retransit
Score: 125
Status: offline
OK, Tom. Thanks for the link.
Bob
Club Saito #800
Hide Signatures
(in reply to Kmot)
       Post #: 1216
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/4/2012 11:00 PM
Kmot
Score: 168
Status: offline
Here is a little 'artistic' FS400 porn for everyone.
Click on the link and it will take you to the full size image. It can be printed up to 30x40 inches if you so desire.
http://www.fototime.com/38F737E1AB39526/orig.jpg
~Tom~
Hide Signatures
       Post #: 1217
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/4/2012 11:02 PM
retransit
Score: 125
Status: offline
You have to mount that on one of those wing thingys and fly it..
Bob
Club Saito #800
Hide Signatures
(in reply to Kmot)
       Post #: 1218
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/4/2012 11:14 PM
Heli-NuBee
Score: 100
Status: offline
AHhhh - to change clips or not to change clips - that my friends, is the question!
Roger the radial rabbit
Hide Signatures
       Post #: 1219
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/4/2012 11:24 PM
Heli-NuBee
Score: 100
Status: offline
Hey frets24, I haven't been able to find that 80" Zero build forum. Please give me the link if you can. I can tell you that the engine is a very tight fit in the cowl though. I just may have to cut some holes to clear the valve covers.
Roger the radial rabbit.
Hide Signatures
(in reply to Kmot)
       Post #: 1220
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/4/2012 11:28 PM
Reverend
Score: 100
Status: online
oh joy of joys! my engine lives yet again! finished assembly, hooked everything up, two turns priming and she roared like before! Did take an hour longer than anticipated due to a lost cam follower. turned the whole bl00dy shop over looking for it. finally found it in the front casing o_O. Now the weekend can come
that hat: Its my lucky hat for maidens. I got it from my grandfather (and best friend) before he passed. used to be his motorcycle cap in the thirties. No maiden without it...
Hide Signatures
(in reply to Heli-NuBee)
       Post #: 1221
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/4/2012 11:29 PM
Reverend
Score: 100
Status: online
quote:
ORIGINAL: Kmot
cant print that poster size, its missing the tom custom badge!
Hide Signatures
(in reply to Kmot)
       Post #: 1222
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/4/2012 11:33 PM
Patxipt
Score: 105
Last Login: 6/18/2013
Status: offline
quote:
ORIGINAL: Kmot
Image saved and bookmarked! Better than a chick!
Club Saito member #632
Once you hear the sound of a multicylinder 4-stroke, you''ll be hooked forever!
Hide Signatures
(in reply to Kmot)
       Post #: 1223
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/5/2012 4:02 AM
frets24
Score: 148
Status: offline
quote:
ORIGINAL: Heli-NuBee
Hey frets24, I haven't been able to find that 80'' Zero build forum. Please give me the link if you can. I can tell you that the engine is a very tight fit in the cowl though. I just may have to cut some holes to clear the valve covers.
Link; http://www.rcuniverse.com/forum/m_6485074/mpage_15/key_/tm.htm
Maybe you and tomandjan@live.co.uk can wake this thread up again
Hide Signatures
       Post #: 1224
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/5/2012 5:33 AM
Kmot
Score: 168
Status: offline
quote:
ORIGINAL: retransit
Bob
If I had two things:
1) Money
2) Space
quote:
ORIGINAL: Reverend
Ahh, but that makes if so no matter whether your favorite flavor is Magnum, ASP, SC, or PH, it has you covered!
quote:
ORIGINAL: Patxipt
Yep, this one has five jugs.
~Tom~
Hide Signatures
       Post #: 1225
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.469RCU1
