RE: ASP/MAGNUM FS400AR Rebuild/Overhaul    Gallery
Logged in as Guest
Users viewing this topic: AltEnergy, out2pasture, jtfleri
    Search This Thread
Printable Version
TurboHeader Muffler
Seller:  RC Specialties
Details:   $69.95   |  4/28/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
Page: <<   < prev  49 50 [51] 52 53 54 55 56 57 58   next >   >>
Login
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/8/2012 8:49 AM
Reverend
Score: 100
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: SrTelemaster150
Not only is your plane awesome as well as the engine sound, the Alps in the background are awe inspiring in their own right.
Thanks! Yes, flying here is a real gift. Check out some more of my videos here Click me softly. Especially the ones with the onboard cam in the glider behind the tug show this spectacular piece of the earth very well.
I have lived all over the place. Germany, UK, South Africa, and visited many many counties but every time I come home I know why people fly thousands of miles just to visit the valley called "Inntal" I live in...
Rev
_____________________________
If at first you don't succeed, skydiving isn't for you.
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 1251
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/8/2012 1:44 PM
Carosel43
Score: 100
Last Login: 5/21/2013
Status: offline
perhaps one day i will drive over there!
Hide Signatures
(in reply to Reverend)
       Post #: 1252
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/8/2012 2:22 PM
Reverend
Score: 100
Status: offline
you are welcome anytime! theres a lot of brits scuffling around in the old town where I work and seem to be enjoying it
Either bring something with an engine or you can have one of my planes to do some "high altitude alpine flying"
Rev
Hide Signatures
(in reply to Carosel43)
       Post #: 1253
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/8/2012 4:32 PM
Carosel43
Score: 100
Status: offline
i will bring something with many cylinders! although i imagine gliding is very enjoyable up there
Hide Signatures
       Post #: 1254
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/8/2012 7:45 PM
Kmot
Score: 168
Status: offline
I had already tested my Microsens glow driver while setting up the engine on the test stand. I no longer suspect it.
You know how it is though when something is not going right. You suspect 'everything!'
I am pretty sure it is a fuel delivery problem. I have had fuel delivery issues before with this setup.
I was taking video, btw. Reviewing the video, at one of the times I used my Sullivan squeeze bulb to pressurize the tank and force fuel to the carb I only saw a couple of drops fall out, when normally it would be a stream. So I am pretty sure now it is a fuel delivery issue. The only time the engine sputtered and ran for a couple of seconds is every time right after I had pressurized the tank.
But yesterday was my only window of opportunity to run the engine. For the next couple of days I have to keep the backyard area clean and uncluttered for the wife's functions. And then by Wednesday there is threat of rain showers so it may be a few days until I can have a go at it again. But at least I will have plenty of time to clean out the carby!
~Tom~
Hide Signatures
       Post #: 1255
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/8/2012 8:39 PM
Reverend
Score: 100
Status: offline
quote:
ORIGINAL: Carosel43
You do that but give me a couple of days notice
But honestly, maybe a nice vacation in Austria in 2013?
@Tom: That carb is about $17 @ hobby king. pays off to have a spare one lying around. http://www.hobbyking.com/hobbyking/store/__13098__AFS400AR_Carb_Assy.html I have three
Hide Signatures
       Post #: 1256
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/9/2012 4:06 AM
frets24
Score: 148
Status: offline
Wasn't there some talk at one time of upgrading the carby to an OS or a Saito Carb? I recall seeing that there was some milling or machining or overboring required but I don't recall ever seeing if there was any benefit from a different carb setup.
Has there been an issue, however minor, with the carb?
Rev, What is the necessity or rationale of having three carbs for the same motor? Not picking or trying to be obnoxious, just curious
I've had an OS 120 and a Saito 100 for decades and gallons upon gallons of fuel through them and never had to do more than clear a bit of unfiltered debris from either of them due to operator incompetence(oops!! ).
"The American taxpayer has always been politicaly deceived. Its their Birthright!"
Lord Mountjoy, The Mouse on the Moon
Hide Signatures
       Post #: 1257
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/9/2012 5:34 AM
Reverend
Score: 100
Status: offline
quote:
ORIGINAL: frets24
frets,
theres a couple of reasons.
First of all for me, I, like tom, have limited time with two kids, a busy job and a house to take care of. If I want to go flying, I do not want to spend hours getting the engine running. So on my last hobby king order I threw threee of these carbs (and some other 400 spares) in the basket.
Secondly, lets be honest, the carb is not what you would call a swiss watch. For example the throttle lever is pressed on and stamped. It will develope serious play after some running hours. The low speed needle is held in and fixed in position by an O-ring. This ring will lose tention at some stage and the needle will start to wander off.
finally if this engine developes a fault like in toms case I want to have a spare carb for diagnosis. swap the carb and if the engine still is not running, its not the carb
now, I think it would be enough to have one on spare, I am a kid of the eighties and we were tought to always have at least three sets of batteries for the flashlight in the basement...
changing the carb to an os will give you a better quality carb. it did not, however, give me more rpm,
rev
< Message edited by Reverend -- 10/9/2012 8:03 AM >
Hide Signatures
(in reply to frets24)
       Post #: 1258
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/9/2012 7:31 AM
frets24
Score: 148
Status: offline
Thanks, Rev.
Points well taken and understood.
This engine is new to me and I haven't spent much time with it yet. Other projects higher in the que right now.
Like you; I've got kids at home home, busy job(self employed and no qualified candidates to be found to spread the load ) and limited time so I well understand the diagnosis aspect and benefit of a spare carb now that you bring it up
For a $17 carb it doesn't sound bad...just "disposable". Not terrible value either, even if you figure on trashing it and replacing after 100 flights. Thats only 17 cents per flight
Hide Signatures
       Post #: 1259
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/9/2012 8:26 AM
Carosel43
Score: 100
Status: offline
I am the only one using an os carb (i think) as my old SC carb was so bad the engine just didnt work. Tuning was just impossible and the whole thing was hopeless. As a result i gained more consistant running, better performance and reliability as well as the thing acutally working! but my old sc carb was totally crap!
Hide Signatures
       Post #: 1260
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/9/2012 6:10 PM
Kmot
Score: 168
Status: offline
I am going to pull down the engine today and remove the carb and give it a checkup.
In defense of this carb, though, last time the engine was set up it ran fine and I made several videos.
It is most likely a piece of dirt in there, and it is my fault for not having properly prepared for running again by double checking and cleaning the fuel tank, fuel lines, and in particular the carb.
~Tom~
Hide Signatures
       Post #: 1261
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/9/2012 10:26 PM
Kmot
Score: 168
Status: offline
I just finished the carb. There was a bit of leftover castrol crud inside of it. It's spotless now, and I also cleaned the fuel tank out with denatured alcohol, and installed all new lines, clunk, and stopper rubber. I thought I had another large size tank but I only have smaller tanks meant for standard size airplanes and I did not feel like a trip to the LHS. I am also using more of the medium fuel line I have a roll of since the engine ran just fine on it before.
Rain has moved back a day so I should be able to run it tomorrow.
~Tom~
Hide Signatures
(in reply to Kmot)
       Post #: 1262
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/10/2012 6:58 PM
Kmot
Score: 168
Status: offline
Just a quick note to say I got my engine running this morning.
Need to set the carb for idle though, as it's not working well.
New manifold, new fuel, different weather conditions. It will get sorted.
Strangley, it seems my Microsens detected a low battery after about 10 minutes of running. This is an 8000 mAh 1S LiPo. Might be rubbish though, as it is rather old.
I can say right now, though, that there is a lot less oil on the test stand.
~Tom~
Hide Signatures
(in reply to Kmot)
       Post #: 1263
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/10/2012 9:56 PM
Kmot
Score: 168
Status: offline
I have finished running my engine. Was good to listen to it again.
I discovered I was in "start mode" on the glow driver the whole time. A set up problem with my test stand throttle servo. So yeah, it drained the battery to the low voltage signal.
It seems weird to run fuel that has practically no color, due to only 7% oil. But it ran great, and the engine seemed perfectly happy with it. No oil smoke in the backyard either.
I will have a full report, and video, in a couple of days, describing the Rogeau intake manifold.
~Tom~
Hide Signatures
(in reply to Kmot)
       Post #: 1264
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/10/2012 9:59 PM
Carosel43
Score: 100
Status: offline
Sounds good tom, i look forward to the video
Hide Signatures
(in reply to Kmot)
       Post #: 1265
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/10/2012 10:07 PM
retransit
Score: 125
Status: offline
Tom, did you mix your own fuel?
Bob
Fleet Brotherhood #1
Club Saito #800
Hide Signatures
(in reply to Kmot)
       Post #: 1266
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/11/2012 6:53 AM
Kmot
Score: 168
Status: offline
Yes Bob I did.
I had thought about how I should do it, but decided to poll the forums and fortunately it was pointed out to me that I was wrong in my assumptions.
Once I was straight on what to do it was easy. For my run, I mixed 16 oz of Powermaster 15% nitro, 18% oil fuel with 25 oz of pure methanol. This gave me a blend of about 6% nitro and 7% oil.
Video is finished. Just need to get it uploaded, and figure out the best way to get the article I wrote in PDF format, converted for forum use.
~Tom~
Hide Signatures
(in reply to retransit)
       Post #: 1267
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/11/2012 7:10 AM
Kmot
Score: 168
Status: offline
Here is a teaser clip.
~Tom~
Hide Signatures
(in reply to Kmot)
       Post #: 1268
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/11/2012 8:37 AM
Carosel43
Score: 100
Status: offline
Hide Signatures
(in reply to Kmot)
       Post #: 1269
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/11/2012 12:19 PM
Reverend
Score: 100
Status: offline
Tom, brilliant. Like the Videoeffect too. Its
I am sure you know that you could tweak the sound of that radial immensly by putting a larger exhaust pipe on that ring. I'd use a 40mm pressed oval so it will fit the ring. The exhaust fumes will be slowed down immensly and sound awesome!
Hide Signatures
       Post #: 1270
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/11/2012 12:37 PM
Carosel43
Score: 100
Status: offline
I am quite happy with the sound i get from my 11mm i/d pipes. But they are quite long so i guess that helps. When my glw driver shows up i will do another video and hopefully fly the thing! I know we are off topic, but rev did you give the 450 saito any more love? the other thread has ground to a hault. I need an airframe to fly mine in, im stuck until then
Hide Signatures
       Post #: 1271
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/11/2012 1:14 PM
Reverend
Score: 100
Status: offline
I put all my time into finishing and flying the Stearman. Now I am repairing my ESM D9 so I can fly it once more before the snow comes.
The Saito is on the test stand and I want to do some tests with different exhausts.
My dream of putting it into the SiSt Focke Wulf died silently last weekend. I have been worrying so much about the diameter I completely forgot about looking at the lengt. It ist 35mm too long . I would have to do a lot of reworking on the Firewall and then I would not have enough space for the exhaust. I might swap it for a good new UMS 7-77.
Rev
Hide Signatures
       Post #: 1272
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/11/2012 3:39 PM
retransit
Score: 125
Status: offline
quote:
ORIGINAL: Kmot
Yes Bob I did.
Tom, isn't there a concern about adequate oil? We are, in effect, running five .80 four strokes on a common crankshaft. I know larger displacement engines require less oil content, but this engine should be considered a moderate in size as compared to a single 1.80. Is my thinking flawed?
By the way, I have a fuel mix chart in Excel for mixing ingredients. If anyone needs it, PM me.
Bob
Club Saito #800
Hide Signatures
(in reply to Kmot)
       Post #: 1273
Carosel43
Score: 100
Status: offline
I have the same issue with the esm sea fury (if it ever arrives) as i need to loose 30mm somewhere. As for the D9 you will have to get a video of it! assuming the planets align i may finally get to test fly my P39 this weekend :O
Hide Signatures
       Post #: 1274
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 10/11/2012 3:42 PM
Carosel43
Score: 100
Status: offline
the oil requirement for the rings is tiny, and as most of the engine is ball raced i dont think running low oil is a problem. laser engines have been run as low as 5% oil by some customers but there were some seizures on the big end. The big ends on the radial are doing less work as they are not rotating sop should be ok. Also with 5 cylinders feeding one crankcase im sure it wil be ok, especially if the breather nipple is blocked off
Hide Signatures
       Post #: 1275
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.793RCU1
