RE: ASP/MAGNUM FS400AR Rebuild/Overhaul    Gallery
Logged in as Guest
Users viewing this topic: Carosel43, SrTelemaster150
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
Page: <<   < prev  60 61 [62] 63 64 65 66 67 68 69   next >   >>
Login
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/14/2012 1:04 PM
jaav
Last Login: 5/12/2013
Status: offline
Cant believe its the same engine! Swap you for a slightly used OS91fs
good to see some Men at work Cause I come from the land down under.
Yep I love my 80s music.
_____________________________
Right after a spectacular crash, the pilot yelled out ''Channel 35 clear!
Hide Signatures
(in reply to Reverend)
       Post #: 1526
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/14/2012 2:53 PM
Reverend
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: jaav
lets see, engine + 450 euros in parts + 30 hours of work... ummm.. no
if i did that, i would be dancing with tears in my eyes...
If at first you don't succeed, skydiving isn't for you.
Hide Signatures
(in reply to jaav)
       Post #: 1527
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/14/2012 5:14 PM
Kmot
Last Login: 5/18/2013
Status: offline
You done good Phillip! Engine looks great!
~Tom~
Hide Signatures
       Post #: 1528
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/14/2012 6:41 PM
Carosel43
Status: online
The finish looks like that of an os300, and that looks pretty smart! assuming you dont freeze to death on the test bench i look forward to the running video!
Hide Signatures
(in reply to Kmot)
       Post #: 1529
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/16/2012 10:37 AM
Reverend
Status: offline
Guys,
thanks for the kind words. Like the look as well.
did a quick try with the 400 because it should go on display at a local exibition between christmas and the 6th of Jan. but it is blowing from all cylinder heads. Compression is very bad. Small setback. I have to change the cylinder liners too. They are so corroded at the top that the cylinder heads can't keep them sealed.
I have ordered new ones from HK, they are 8 bucks a piece so not that bad. Will be 2013 before the engine runs. Exhibition will be static then.
Apart from that not very motivated for RC. The news we are getting from connecticut is simply devastating and thoughts about it keep going round in my head. I have two kids about that age and I cannot even begin to imagine what those parents are going through after those senseless and brutal events.
My heart and prayers go out to them.
Sorry for the OT.
Philipp
Hide Signatures
(in reply to Carosel43)
       Post #: 1530
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/16/2012 4:20 PM
Carosel43
Status: online
My cousin has children of 3 and 6 so rev i am right there with you. I have many friends in america, half of which are of high school age and i do often worry.
I know people will go on about it being unconstitutional (which is rubbish) but honestly, they were children at school. And what of the people just watching a movie? or the police officers attending any number of issues. I think America needs to have a long hard look in the mirror and the govt need to act to protect their population.
Irrespective of the long term changes, this is another tragic event that should not have been allowed to happen.
Hide Signatures
       Post #: 1531
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/16/2012 6:46 PM
Kmot
Status: offline
I am in shock over this as well as the whole nation and possibly the world.
However, continued discussion of this can go wildly out of bounds and make enemies of friends, so let's drop it now please.
~Tom~
Hide Signatures
       Post #: 1532
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/16/2012 9:41 PM
Reverend
Status: offline
Tom, completely with you. sorry, did not want to start a discussion. did not want to imply an american problem. Its a human one, sometimes in the house next door.
Had some more bad news today and just had to get my mind off things so back to radials...
sorry, not the 400 yet but (almost) as good.
rev
< Message edited by Reverend -- 12/17/2012 8:12 AM >
Hide Signatures
(in reply to Kmot)
       Post #: 1533
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/16/2012 11:20 PM
Kmot
Status: offline
Sounds pretty sweet with the ring exhaust!
~Tom~
Hide Signatures
       Post #: 1534
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/17/2012 8:37 AM
Carosel43
Status: online
Sounds great Rev, and it looks clean as well on the low oil fuel? as much as you can tell from a slow run anyway.
Sadly i did not have the weather for any radial action, its too cold and its just a pain to start it. So, some V twin laser action did the trick,  but alas no video.
Hide Signatures
(in reply to Kmot)
       Post #: 1535
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/17/2012 8:42 AM
Reverend
Status: offline
quote:
ORIGINAL: Carosel43
It is a lot cleaner than the 400, even though it is still running on 10% oil.
No flying for me either, lots of sled action with the kids
Hide Signatures
       Post #: 1536
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/17/2012 1:28 PM
Carosel43
Status: online
I am still flying but only simple stuff, the warbirds are sleeping!
And i am sure dragging the kids up hills will keep you fit at least!
Hide Signatures
       Post #: 1537
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/18/2012 3:41 AM
israelillo81
Last Login: 12/18/2012
Status: offline
Hello Guys,
I Follow this Forum since July and im happy to see so many  Enthusiasts in radial engines. Im  also a proud owner of an ASP 400 from hobbyking. so far so good. I struggled a little bit to get all cylinders running until I followed some suggestions from Tom.
Have any of yu ever heard from this machinist guy named George Luhrs ?. He built the smallest 5 cylinder radial engine for a contest sponsored by sherline tools in 2001. Unfortunately i havent seen a video of the engine running and I dont even know if the guy is still aive but is quite an achievement what he made. his webpage is minimodelengines].com  (remove the square bracket to go to the webpage).
Regards,
Israel
Hide Signatures
       Post #: 1538
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/18/2012 5:59 AM
Kmot
Status: offline
Hello Israel, welcome to the forum.
Being a model engineering enthusiast myself, I am quite familiar with George Luhrs' micro engines, he has built many different types. He is not alone, it seems many model engineers try to make things as small as humanly possible. I suppose that is the challenge they seek to conquer.
If you haven't yet, you should peruse the Model Craftmanship Museum website, by the owner of Sherline.
http://www.craftsmanshipmuseum.com/luhrs.htm
~Tom~
Hide Signatures
(in reply to israelillo81)
       Post #: 1539
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/18/2012 6:06 AM
Kmot
Status: offline
Hey everyone, I just noticed that todays date is the 5 Year Anniversary of this thread!
Who woulda thunk!
~Tom~
Hide Signatures
(in reply to Kmot)
       Post #: 1540
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/18/2012 10:11 AM
Carosel43
Status: online
Happy Birthday to the thread, happy birthday to the thread, happ..... hey wait, do we all get presents for being involved? if so where is mine?!
Hide Signatures
(in reply to Kmot)
       Post #: 1541
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/18/2012 10:20 AM
jaav
Status: offline
Hi guys...If you have too much rain and snow, please send it over here.....Constant over 34 deg with about 7-85% humidity. I sure do miss that radial rumble at idle..The twin 2 stoke is just loud.. Still cant land the bird without doing some UC damage.
Hide Signatures
       Post #: 1542
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/18/2012 1:37 PM
Carosel43
Status: online
Jaav whats the issue with the landing? is thr u/c very poor or is the model tricky to get down without a bump?
Hide Signatures
(in reply to jaav)
       Post #: 1543
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/18/2012 2:49 PM
Eulboyington
Last Login: 4/22/2013
Status: offline
Hi all gang,
Another overhaul on a ASP F400 AR, I discover  another time what is " engine build on monday morning" ... see photos ...
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1544
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/18/2012 7:57 PM
israelillo81
Status: offline
  Hello Olivier,
Do you have any news in converting the ASP400 from glow to,ignition?. I think i read a post from you where you mentioned doing some research in to adapting some ignition system.
There was alsomone guy in this thread  that mention that some small company wanted a sacrifice engine for the sake of making an ignition system for the ASP400.
Somebody already ventured into it?. I have seen some youtube videos of a guy running gasoline/ ignition on a ASP400 but he adapted 5 independent ignitons.
I have also seen that some hobby stores sell ignition systems for some specific 9 cylinder radials, as well as some spare parts, kits from plugs, distributors, coils, hall sensors. But nothing specific for a radial 5 cyl such as the ASP 400.
Regards,
Israel
Hide Signatures
(in reply to Eulboyington)
       Post #: 1545
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/18/2012 8:25 PM
Eulboyington
Status: offline
Hello Israel,
RCEXL is working hard about ignitions for radials ; first of all, the 3 cylinders ignitions will come  very soon on  references 13XX, a very good new for all SAITO Radials 3 cylinders owners and customs engines !
1301 = 3 cylinders / 1/4-32 sparplugs sockets bent 90°,
1302 = 3 cylinders / 1/4-32 sparplugs sockets bent 120°,
1303 = 3 cylinders M10 (NGK CM-6) sparkplugs sockets bent 90°, and
1304 =  3 cylinders M10 (NGK CM-6) sparkplugs sockets bent 120°
All LiPo  2S compatibles, expected street price 140 USD
RCEXL is also working on ignition for SANYE Radials 5 cylinders, I had a lot of discussions with Xu Liang about the market and number of radial engines sold in the world.
I'm developping a personal solution for specific hall sensors positioning on the back of the engine with my "upgrade" rear cover ( quite  impossible with original rear cover).
The working solution with 5 x single ignitions is far too heavy and need a lot of place.
With my upgrade cover, those engines can now run with methanol based fuels with 7% lubricants, and they  are ready for a future spark conversion to run with gasoline + 3 % synthetic oils because the intake gaz goes through the crankcase for better lubricate before suck by intake pipes ( As used in EVOLUTION-UMS-SEIDEL and MOKI engines )
I think we will get a technical solution for SANYE Radial engines middle or end of 2013.
Hide Signatures
       Post #: 1546
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/18/2012 8:57 PM
Kmot
Status: offline
quote:
ORIGINAL: Eulboyington
Sweet!!
~Tom~
Hide Signatures
       Post #: 1547
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/18/2012 10:55 PM
jaav
Status: offline
(Jaav whats the issue with the landing? is thr u/c very poor or is the model tricky to get down without a bump)
last week http://www.youtube.com/watch?v=DfT8W9eEtNc
some one else. http://www.youtube.com/watch?v=S9KBkURg4b0
Hide Signatures
(in reply to Kmot)
       Post #: 1548
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/21/2012 5:59 AM
Kmot
Status: offline
Hi all gang,
Another overhaul on a ASP F400 AR, I discover  another time what is '' engine build on monday morning'' ... see photos ...
Olivier, those parts are abominable. Should have been factory rejects with all that porosity. And what about surface finishing of the parts before installing them into an engine? Makes one wonder if the Sanye factory pulled all of its QC inspectors off of the radial engine line to another department!
~Tom~
Hide Signatures
       Post #: 1549
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 12/21/2012 3:25 PM
Carosel43
Status: online
There does seem to be a massive amount of flaws in the material, and the grinding leaves more than a little to be desired thats for sure! the problem is will a replacement be any better? Also i doubt the imperfections will cause a problem for the engine as long as they dont form cracks and break over time. if the crank was in a bush not ball races then clearly something would need to be done.
@ Jaav - i can see the problem, not sure what to do about it mind! but in the 2nd video the guy did kinda throw it at the ground and hope for the best, in your video it was hard to see as the model was a long way away. it seems however that rate f decent is fairly high and the speed it is landing at quite fast, is that as slow as it will go because it seems to takeoff at a far lower speed?
Hide Signatures
(in reply to Kmot)
       Post #: 1550
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.156RCU1
