Kmot -> RE: ASP/MAGNUM FS400AR Rebuild/Overhaul (12/22/2007 2:47 AM)
The engine is now almost completely disassembled. Some things of note: The master rod needle bearing is made in Germany: [img]http://www.fototime.com/5B8E6E71453A483/standard.jpg[/img] The main rear bearing is an NSK made in Japan: [img]http://www.fototime.com/267004DA95967AB/standard.jpg[/img] The front main bearing is no name, but is a rubber sealed 6000RS: [img]http://www.fototime.com/F92EDFC2D574A74/standard.jpg[/img] The master rod capture bolt is left hand thread: [img]http://www.fototime.com/5A453507201BEC8/standard.jpg[/img] Some miscellaneous photos for anyone keeping a reference file: [img]http://www.fototime.com/E9E3AB62582B925/standard.jpg[/img] [img]http://www.fototime.com/60BC563F0467B5B/standard.jpg[/img] [img]http://www.fototime.com/454B3239E819E74/standard.jpg[/img] [img]http://www.fototime.com/E2346854BAA57F3/standard.jpg[/img] [img]http://www.fototime.com/B1BDA5C6BD9966A/standard.jpg[/img] [img]http://www.fototime.com/35C6C62D90C3290/standard.jpg[/img] This is a stand I made to keep the cylinders, pistons and rods, and linkpins organized: [img]http://www.fototime.com/11430A2A7A2E0B2/standard.jpg[/img] [img]http://www.fototime.com/E6E61C0283037D9/standard.jpg[/img] The cylinders have a permanent liner, that is pinned. The steel liner then slides into it, and is keyed on the pin: [img]http://www.fototime.com/3776DDFE8B100AF/standard.jpg[/img] [img]http://www.fototime.com/D1F65FDFB24DD90/standard.jpg[/img] To be contined...
