RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
Page: <<   < prev  1 2 [3]
Login
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 2/5/2008 8:09:47 AM
Kmot
Status: offline
Thanks Jeff!
Okay, I have finished the FS-70 overhaul so I will start back on the radial shortly.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Ahhh......screw it!
(in reply to Jazzy)
       Post #: 51
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 2/5/2008 12:30:46 PM
Patxipt
Status: offline
I've been following this thread from the beggining and you do have a gift for mechanics.
The last job done on the OS FS70 is marvelous, a true joy to the eye. I wish I had some lights on how to paint engines so well (hint ).
Either way, I hope to see you back on the radial and see that baby humming once again. Keep up the excellent work!
Modelling regards,
Francisco
(in reply to Kmot)
       Post #: 52
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 2/13/2008 11:31:25 PM
Kmot
Status: offline
I removed the cylinders from the crankcase today. I had to cut down an Allen key to fit underneath the cooling fins. There is a clear cellophane gasket under the cylinder. You probably can't see it but the gasket is under the bolts heads on each cylinder.
I had previously numbered each cylinder position on the crankcase in pencil. But I wanted something more permanent since the pencil was getting rubbed off. So I stamped, very lightly, the number position on the crankcase.
To remove the name plate from the nose case I drilled the heads off the rivets and pulled the plate off. Then to remove the remainder of the rivets I used a #56 drill bit to bite into the rivet shank and then pull it out of the case.
Here is the intake manifold with the rubber boots removed.
And the brass sockets for the intake pipes removed from the manifold:
The sockets are o-ringed both inside and outside:
At this point, I knocked my camera off the workbench and broke the lens.
Ahhh......screw it!
(in reply to Patxipt)
       Post #: 53
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 2/16/2008 2:23:39 AM
Kmot
Status: offline
I had been thinking about painting this engine. But I decided to polish it instead. It will be going into a sport plane of some sort, so I think being polished will give the plane a nicer touch.
Here are the pieces of the power section, polished up.
Here it is stacked up.
Ahhh......screw it!
(in reply to Kmot)
       Post #: 54
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 2/16/2008 2:55:25 AM
Flyboy Dave
Status: offline
....is this a fun hobby, or what ?
FBD.
An engineer says.... "That won''t work".
A mechanic says..."Oh yeah, watch this".
"Old Age, and Treachery will overcome youth and skill".
Revver Bro #4.
(in reply to Kmot)
       Post #: 55
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 2/16/2008 6:37:10 AM
Kmot
Status: offline
Why, yes. Yes it is!
Ahhh......screw it!
(in reply to Flyboy Dave)
       Post #: 56
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 2/16/2008 6:46:03 AM
FlyingPilgrim
Status: online
Kmot, nicely done! That will certainly be a beautiful piece when you are done!
I know just enough to be dangerous
(in reply to Kmot)
       Post #: 57
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 2/16/2008 6:48:40 AM
Kmot
Status: offline
Thank you FP! This is just the first part of polishing. Wait till it's shiny!
Ahhh......screw it!
(in reply to FlyingPilgrim)
       Post #: 58
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 2/16/2008 9:47:31 AM
Patxipt
Status: offline
I'm speechless
Modelling regards,
Francisco
(in reply to Kmot)
       Post #: 59
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 2/16/2008 1:29:51 PM
SJN
Status: offline
Now thats pretty neat
Sonnich Johannesen
       Post #: 60
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 2/16/2008 1:35:35 PM
nilsreinert123
Status: offline
Hi SJN , have you flown your jamara stearman with the asp on yet?
(in reply to SJN)
       Post #: 61
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 2/16/2008 2:29:02 PM
SJN
Status: offline
nope...I have been lazy, and not finished the plane yet.
Sonnich Johannesen
(in reply to nilsreinert123)
       Post #: 62
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 2/27/2008 11:37:07 PM
FlyingPilgrim
Status: online
Kmot, now that you're done with the "Green Machine" O.S. engine, lets get back to your radial. More pics, please....
(since I can't afford one, I'll settle for checking out yours. This is the kind of article I'd like to see in the publications!)
Now where's my popcorn?
(in reply to SJN)
       Post #: 63
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 2/28/2008 1:54:55 AM
Kmot
Status: offline
In my best John Wayne voice: "thanks, Pilgrim"
Actually, as is typical, I have been sidetracked and am working on something else. That mad Russian МДС 10cc as well as a model boat. But I will be getting back on it soon. I need to do more polishing so the next pics will be of more polished parts. Nothing too exciting.
Ahhh......screw it!
       Post #: 64
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 3/11/2008 11:39:33 AM
bignuts181
Status: offline
