RE: ASP/MAGNUM FS400AR Rebuild/Overhaul    Gallery
Logged in as Guest
Users viewing this topic: speedaholic, Dauntae
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
Page: <<   < prev  42 43 [44] 45 46 47 48 49 50 51   next >   >>
Login
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/14/2012 9:14 AM
Carosel43
Score: 100
Last Login: 5/25/2013
Status: offline
YES! that is indeed a beast. Skip to 1.20 if you only want to see it fly http://www.youtube.com/watch?v=bzoEs2VtVYI
Hide Signatures
(in reply to Reverend)
       Post #: 1076
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/14/2012 2:08 PM
SrTelemaster150
Score: 229
Last Login: 5/26/2013
Status: offline
I would settle for one of these.
_____________________________
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
       Post #: 1077
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/15/2012 12:58 AM
vasek
Score: 147
Last Login: 5/23/2013
Status: offline
How about those Spitfire Merlins? As a European, can't get more patriotic than that!
http://www.youtube.com/watch?v=2VMuf7azt-I
Remember: Speed is life!
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 1078
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/15/2012 7:22 AM
Kmot
Score: 168
Status: offline
As much as I love the Merlin's and Allison's (look at my avatar!) let's stay focused. lol...
Here is my ASP FS400AR engine idling:
~Tom~
Hide Signatures
(in reply to vasek)
       Post #: 1079
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/17/2012 9:04 AM
Carosel43
Score: 100
Status: offline
Well my Pacer is almost ready for test runs with the new exhaust. I was silver soldering away happily the other evening with some success! I hope to get a video soon once i have worked out why the onboard glow has decided not to work propperly
Hide Signatures
(in reply to Kmot)
       Post #: 1080
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/17/2012 9:14 AM
Reverend
Score: 100
Status: offline
Can you post a pic of your exhaust?
If at first you don't succeed, skydiving isn't for you.
Hide Signatures
(in reply to Carosel43)
       Post #: 1081
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/17/2012 1:13 PM
Carosel43
Score: 100
Status: offline
i will as soon as i get home. 4 of the cylinders have flexi on them and one has a standard exhaust so i have use of a pressure nipple. the way i have done it is not exactly pretty but it should at least be functional as all of the exhausts exit below the model to help prevent the engine spraying goo everywhere
Hide Signatures
       Post #: 1082
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/17/2012 8:46 PM
Carosel43
Score: 100
Status: offline
Right then. Had some drama today as the brakes on my car siezed up while driving to work, so after work i spent a while fixing them and changing the worn out pads. that meant it was getting dark when i got home. unflustered i wanted to run my 400.....shame it refused to start...eventually it screamed into life at something close to full power, my throttle was doing nothing so i killed the glow and fuel supply. the problem was the throttle linkage not being tight....oops. anyway after a very stubborn series or restart attempts i did get it going, but it was too dark for the video and i didnt want to loose an arm in the dark. also the tuning was all to cock and i couldnt be dealing with it. However, it did sound pretty mighty with the new exhaust. as i say, its not attractive but it seems to work. the model was quite clean after the run
Hide Signatures
       Post #: 1083
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/18/2012 9:13 PM
Carosel43
Score: 100
Status: offline
Right then. I had another go at the 400 today and i almost kicked the whole model over the fence. for reasons i cannot begin to understand it refuses to start in any kind of useful way. by that i mean it takes 15 minutes to get it going. i have cleaned the carb as i suspected fuel issues to begin with, i have tried tuning to no avail. my lingering suspicion is the glow driver as the plugs are not glowing bright orange, in fact they are only just a dull red...sometimes. the thing is as its always started before i have never looked at the plugs and so dont know if they were always like that. however something has changed as it never used to be this much of a pain in the butt. Anyway, i did get it started but it wont idle below 2000rpm and it will just run down and stop. i did get a video however so at least you can hear it.
http://www.youtube.com/watch?v=jkw-5B3LQzY&feature=youtu.be
Hide Signatures
       Post #: 1084
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/18/2012 10:02 PM
Reverend
Score: 100
Status: offline
What Glow Driver do you have?
I had a very similar issue. Glow5LP. Plugs only luke warm. no idle. Tried running the engine on a 1,2V Lead battery and everything went fine.
Sent the Driver in and recieved it today. Will try on the Weekend.
Hide Signatures
       Post #: 1085
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/18/2012 11:45 PM
Kmot
Score: 168
Status: offline
Dang, I hope I don't find a bad glow driver when I get ready to run my engine again. I also use the Microsens.
~Tom~
Hide Signatures
       Post #: 1086
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/19/2012 8:36 AM
Carosel43
Score: 100
Status: offline
As i say im not 100% sure its the glow driver. all i know is that it was working well on the bench and now its not. if it is the glow driver i have no idea what has happened to it as nothing has changed and it was working just fine. Sigh. i will fully cycle the glow battery to make sure its not died as its possible a cell has gone down and it cant provide the current any more. We will see.
Hide Signatures
(in reply to Kmot)
       Post #: 1087
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/19/2012 8:37 PM
Carosel43
Score: 100
Status: offline
it seems my glow driver battery has given up. reads 1.3 something volts idle but drops to .6v under load
< Message edited by Carosel43 -- 9/19/2012 9:18 PM >
Hide Signatures
       Post #: 1088
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/20/2012 12:35 AM
Heli-NuBee
Score: 100
Status: offline
OK, it is time to jump in. Hobby King has the ASP 400 radial in stock right now. I just ordered one today. I already have two other radial engines including a Saito 200 Radial and a UMS Evolution 777 radial engine. I plan to put the ASP 400 in my 80" CMP Zero. I think that will be a good combination. I have been a bit reluctant to purchase the ASP 400 because of others problems and failures that were posted on the web. However, I really like my radials so I am going to give it a shot.
Best wishes and good safe flying,
Heli-NuBee (Roger)
Hide Signatures
       Post #: 1089
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/20/2012 10:08 AM
Carosel43
Score: 100
Status: offline
Hi Nubee. In fairness to the engine i think most of the issues reported online are the only issues as all the people with no issues are happily flying! Also my SC is not representative of the current quality of the engine as frankly, mine is rubbish. that said when it is actually working and not broken it runs very well and makes a nice noise to say the least!
In anycase the cmp zero has been a very popular home for the 400. I assume the soon to arrive ESM zero will be as well. Either way i look forward to video of the engine in action
Hide Signatures
(in reply to Heli-NuBee)
       Post #: 1090
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/20/2012 1:22 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: vasek
Speaking of Merlins.
This is the closest sound to a Merlin I have found in a reasonably priced glow engine.
I picked one up NIB for a great price from an e-bay vendor in the spring. It was definately NIB. It was a museum piece from a collecter.
It fits into an 83" Brian Taylor MK I-V Spitfire cowl like a glove.
OK, back to the ASP 400R5.
Hide Signatures
(in reply to vasek)
       Post #: 1091
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/20/2012 1:36 PM
jaav
Score: 106
Status: offline
Ok guys way of topic..The most real sound Ive heard in RC is this bird (non radial) the P51 Galopping Ghost..
http://www.youtube.com/watch?v=AmYbW4o5PRk
Right after a spectacular crash, the pilot yelled out ''Channel 35 clear!
Hide Signatures
       Post #: 1092
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/20/2012 1:40 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: jaav
Yes, but we are talking BIG bucks there.
I think that engine cost more than a 400cc Moki.
< Message edited by SrTelemaster150 -- 9/20/2012 4:36 PM >
Hide Signatures
(in reply to jaav)
       Post #: 1093
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/20/2012 1:42 PM
Carosel43
Score: 100
Status: offline
I love watching that video. It even sounds better than my 300v twin! but only just
But, while it sounds great and would be ideal in a racing aeroplane or a pitts or extra, but still not right for a warbird :P
Hide Signatures
(in reply to jaav)
       Post #: 1094
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/20/2012 4:36 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: Carosel43
How about this one?
A trio of ASP400R5s in a smaller version would sound pretty good too I'l bet.
Hide Signatures
       Post #: 1095
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/20/2012 5:11 PM
Carosel43
Score: 100
Status: offline
sorry guys but im not impressed. at idle it sounded ace, but he flew it too fast and it was far from scale. Also at the higher speeds the engines were beginning to whine. When he did some 'slow' passes the model sounded much better, but even these passes were about twice the speed they should have been. i see the lufthansa ju52 fly at duxford almost every year and its like its hardly even moving forward most of the time, it just purrs along. a shame as the model looks awesome on the ground
Hide Signatures
       Post #: 1096
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/21/2012 12:22 AM
Kmot
Score: 168
Status: offline
I need to mix up some fuel, and I must start out with using commercial fuel.
I need fuel with 7% oil by volume.
I have Powermaster 15% Sport fuel, which is 18% oil by volume.
My math is as follows:
128 oz of fuel =
86 oz of methanol
23 oz of oil
19 oz of nitromethane
If I take 16 oz of the fuel, I have:
10.725 oz of methanol
2.875 oz of oil
2.4 oz of nitromethane
The above is still 18% oil by volume.
Now, by my calculations, if I add 30 oz of pure methanol to the 16 oz of this Powermaster fuel, I will have:
46 oz of 7% oil by volume, fuel.
Which would be:
40.725 oz of methanol
2.875 oz of oil
Does anyone see anything wrong with my math?
~Tom~
Hide Signatures
       Post #: 1097
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/21/2012 8:39 AM
Carosel43
Score: 100
Status: offline
Are you using fl/oz as your oz? as doing it with actual ounces (weight) wont work. in the txt you say volume but i got confused with units! gimme ml anyday!
Hide Signatures
(in reply to Kmot)
       Post #: 1098
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/21/2012 12:44 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: Carosel43
He stated oz "by volume". That would be fluid oz.
Hide Signatures
       Post #: 1099
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul - 9/21/2012 1:12 PM
Carosel43
Score: 100
Status: offline
i assumed as much but wanted to check :P
Hide Signatures
       Post #: 1100
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.203RCU1
