Superbrain 960
Tower Hobbies
Logged in as Guest
  Printable Version
CEN Racing CT4S - RTR
Seller:  solidgold5
Details:   $200.00   |  7/15/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Academy Racing (MRC) Support >> Superbrain 960
Page: [1]
Login
Superbrain 960 - 12/17/2007 1:13:00 PM
B44&501xRacerEX
Status: offline
I have the new 960 charger and need some more information on it.
People have said it can charge past the 3700maH limit? Is this true or not?
_____________________________
B44 FT/Tamiya 501x "WCE"/HPI E-firestorm/Yokomo YR4 M2/Losi DT/F-150/Blackfoot Xtreme/Twin Force/TXT-1
       Post #: 1
RE: Superbrain 960 - 12/17/2007 10:19:59 PM
guver
Status: offline
Yes, it is true.
This is an apostrophe ''
(in reply to B44&501xRacerEX)
       Post #: 2
RE: Superbrain 960 - 12/18/2007 7:17:40 PM
B44&501xRacerEX
Status: offline
So I would have to charge the pack 2 times to fully charge a 4500Mah battery...
(in reply to guver)
       Post #: 3
RE: Superbrain 960 - 12/18/2007 9:15:59 PM
guver
Status: offline
No, it should go right up to full normally. Tim might give you more insight on why there's a "max" mah of 3700 listed. I can only speculate that it has it's hands full because of the length of time spent chargeeing at 4.5 is close to a whole hour.
The older 959 would get hot doing that job, but the 960 has a cooler running power supply and should stay cooler. You may not want to do back to back packs.
       Post #: 4
RE: Superbrain 960 - 12/18/2007 11:46:14 PM
B44&501xRacerEX
Status: offline
I could probably do my Elite saddles for my B44 back to back since they are 3600 and the charger manual
did say it could charge back to back packs. This 960 will be better as a racing charger due to not getting hot.
I like the charger, because I still have the old 959.
(in reply to guver)
       Post #: 5
RE: Superbrain 960 - 12/19/2007 6:26:48 AM
The Collector1
Status: online
I charge my 4200 packs with it and it gets warm but not hot to touch but I give it some time in between to cool off a little
TT01,Avante MkII,Rc10v1,Rc10Tv1,TA01,TA02,FF01, Clodbuster v1,Wyvern EX,Griffin pro,M1a2.Ford Amax.Durga,TB02,TLT1,AX10
       Post #: 6
RE: Superbrain 960 - 12/19/2007 6:13:15 PM
B44&501xRacerEX
Status: offline
I like the fact that is lightweight and smaller than the bulky 959, so I can take it to the track without the tackle box weighing a ton!
(in reply to The Collector1)
       Post #: 7
RE: Superbrain 960 - 3/8/2008 7:14:25 AM
rpespo
Status: offline
I purchased a 960 Super Brain to recharge the batteries for my RC18T and the receiver packs for my nitro vehicles. These smaller batteries are suppossed to be charged at 1 to 1.5 amps. The default charge rate on the Super Brain is 3 amps. I connected the battery, waited about 60 seconds and pressed display until the amps appeared. I pressed adjust in attempt to change the amps and nothing happened. The 960 would not let me change the amp rate. This happened with 2 different battery packs. Anybody have any ideas or suggestions? Thanks.
< Message edited by rpespo -- 3/8/2008 9:16:36 PM >
RC18T FT, Inferno GT
Monster GT, FG Sportsline
       Post #: 8
RE: Superbrain 960 - 3/12/2008 8:10:48 AM
gman1
Status: offline
you have to adjust the Amp rate before you press the start button. Hope this helps. Let me know.
Tamiya Durga-Mamba Max 6900- Team Orion 3600 Carbon Edition Lipo- Futaba R152JE Receiver- HiTec HS-625MG Servo- TRF Dampers!
(in reply to rpespo)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.625RCU1
