Bob R2
FWIW, I've used a small Garmin with success, but you have to do a couple of things. First, go into the programming and set the sampling interval to the minimum - I believe it is one second. Second, fly large race track laps. If you fly vertical maneuvers, you get crazy speed readings. Apparently the vertical resolution isn't sufficient to accurately calculate speed in the vertical. The "how fast" device is smaller and pretty cool, but with the gps you don't have to poke holes in your plane.
