Losing canopy screw every flight on 102" ??
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Quique's Aircraft Support >> Losing canopy screw every flight on 102" ??
Page: [1]
Login
Losing canopy screw every flight on 102" ?? - 12/18/2007 2:07:43 AM
husafreak
Status: offline
Hi guys, I have maybe 100 flights on my 102" with DA 100 in the year I've owned it. Suddenly the right rear canopy screw is missing every flight. I'm going thru canopy screws and they're expensive! I've checked all the bolts on this thing and they are all tight. I'll start using locktight but it seems odd. Has anyone gone thru this? Thanks
       Post #: 1
RE: Losing canopy screw every flight on 102" ?? - 12/18/2007 2:26:53 AM
mxcop114
Status: offline
Try using bonded washers, they work great. No locktite needed, just tighten snug.
Lee
_____________________________
Team JR
Horizon Hobby
(in reply to husafreak)
       Post #: 2
RE: Losing canopy screw every flight on 102" ?? - 12/18/2007 12:25:54 PM
randy racer
Status: offline
bonded washers are the way to go, i use them every place i need to keep screws from vibrating out.
rr
Revver Bro #196
Ford RV Refrigeration Training Center & The RVRN
(in reply to mxcop114)
       Post #: 3
RE: Losing canopy screw every flight on 102" ?? - 12/19/2007 1:57:00 AM
Tired Old Man
Status: offline
Why use metal screws or bonded washers at all? I went to using nylon screws after reading a suggestion on the Wild Hare forum. Since making the switch I have not had a canopy screw loosen on any plane I fly. Others have had the same experience.
Simply knock out any blind nuts that are in place. Tap the hole from the removed blind nut to accept a nylon screw from 8-32 up to 1/4-20. The size is only dependant on what space you have available to work with. Harden the threads with thin ca glue and clean up the threads with the tap once more. You'll never need to replace another canopy screw, and the end appearance can be as good or better than a metal screw.
If you can''''t fix it with a hammer, you have an electrical problem.
(in reply to randy racer)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.344RCU1
