Tom W78
KS, USA Status: offline
Ok, I've broken in my Avalanche which wasn't that hard once I figured out the tuning. I'm actually having more trouble with the transmitter. I downloaded the manual but it reads like a bad translation. How do I get it in reverse? I'm new to these rc cars. I have the lcd fm, and I set it up to match the 'ordinary settings' in the manual. From what I understand you just push, instead of pull the trigger, but all it does is apply brake. Is there another setting I need to adjust or is there a switch I must engage before it will go into reverse? I've seen some with a toggle to maneuver it into reverse.
