HimotoRacingUSA
Joined: 2/27/2006 From: howard beach, NY, USA Status: online
sounds like the one way bearing, what fuel are you using, if there is too much oil it can cause it to slip, the sh engine has the one way on the inside of the backplate, you can take it out, clean it with carb cleaner, scuff up the shaft it goes on with steel wool and usually this will let you get some more time out of it. just be careful to make sure the one way shaft is clean after you scuff it up so you get no pieces of steel wool in the engine.
_____________________________
OFFICIAL SUPPORT HIMOTORACING.COM / OWNER HIMOTORACINGUSA.COM ***Its me EHROOF!!!!*** THE REVOLUTION HAS BEGUN
