RE: "OFFICIAL" Redcat Avalanche thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: "OFFICIAL" Redcat Avalanche thread
Page: <<   < prev  1 2 3 4 5 6 7 8 [9] 10   next >   >>
Login
RE: "OFFICIAL" Redcat Avalanche thread - 4/28/2008 4:08:41 AM
Swamp3r
Status: online
Least you figured it out, and I wouldn't call yourself an idiot I'll bet 100's of people have done it.
_____________________________
vancouverhobbies.com keeps me bashing
(in reply to impune)
       Post #: 201
RE: "OFFICIAL" Redcat Avalanche thread - 4/28/2008 4:45:00 AM
impune
Status: offline
thank you and i hope that sh link helps someone else too.. was pretty descript.
http://www.happysale.dk/images/SH28.pdf
the sh.28 helpful guide..above.
now i wait to try again... going to order the roto start to save my fingers...
just taking another day. these r/c''''s are to destress me...
(in reply to Swamp3r)
       Post #: 202
RE: "OFFICIAL" Redcat Avalanche thread - 4/28/2008 3:18:51 PM
impune
Status: offline
i was looking at the body mount nubs. the part that the body pins clip to so the body stays on.
anyone know the replacement part? i was woundering if aluminum replacement too? i could have sworn i saw the part, but could not locate it again.
thanks
any certain part i should stock up on or should upgrade with the avalanche?
       Post #: 203
RE: "OFFICIAL" Redcat Avalanche thread - 4/29/2008 3:35:20 AM
impune
Status: offline
still looking for the body mount nubs for the avalanche. the choice by choosing vehicle doe snot show the part. choosing all parts it shows part number 08047b and 02010 and 02144 and 81601b and 83902 and 82914 and 82911.
anyone break one yet and know the answer. not available answer by searching just the avalanche.
       Post #: 204
RE: "OFFICIAL" Redcat Avalanche thread - 4/29/2008 8:06:32 PM
Redcat Nick
Status: offline
This is what you need.
http://www.redcatracing.com/parts_searchresult.asp?basepartno=AVALANCHE+XP&q=83011
Just the body mount
http://www.redcatracing.com/parts_searchresult.asp?q=83009
comes with the brace and the mounts
The tank is half full but mostly empty :(
       Post #: 205
RE: "OFFICIAL" Redcat Avalanche thread - 4/29/2008 11:46:49 PM
impune
Status: offline
thanks nick. thats it. i appreciate it.
now i've got new problems with the avalanche.
so i restarted back to the original settings, the truck ran rich and then stalled once you try to apply gas to it. so as instructions the idle needle looks right and idles fine. i started the adjust ment for the low speed needle. very small turns and about 10 later the car when gased will go, i tried slowly, if stall adjust again. then i got it to start down the drive, looked like it was going to go now, engine had a better tune, some smoke still. then stalled. so i go to try again. pull the string and very loose. did not hear the engine spin, tried a few more times the string recoils back easily and every couple thumps like gurgle thumps slightly adn that was it. easy pull string, every other pull a little gurgle slight thump..
so what happened? all this effort and the one may bearing went out?
so i dumped all th fuel out and dropped a few frops of after run oil and tried to get a couple thumps.
so help me with this please. very discouraged...
(in reply to Redcat Nick)
       Post #: 206
RE: "OFFICIAL" Redcat Avalanche thread - 4/30/2008 12:40:53 AM
Redcat Nick
Status: offline
Ok sounds like your owb is still good just covered in oil. what you need to do is remove it and clean it with carb cleaner and let it dry. also what fuel are you using? if you are using Traxxas top fuel i strongly recomend using a different fuel it has way to much oil in it. i recomend sidewinder, Byronns, or Odonnels in a 20% blend.
       Post #: 207
RE: "OFFICIAL" Redcat Avalanche thread - 4/30/2008 12:58:40 AM
impune
Status: offline
yes you are right. i am using the traxxas fuel. always have with the stampede i have and four years the engine still good. so the fuel being too rich got the one way oiled up huh?
thanks. cause i pulled it and no resistance was a scarey moment. i've never burnt an engine so i don't know what to look for, but i haven't even gotten it hot yet. or really running.
thanks again.[)]
       Post #: 208
RE: "OFFICIAL" Redcat Avalanche thread - 4/30/2008 6:00:43 AM
Tom W78
Status: offline
My poor Avalanche won't start any more. It used to start up great after just a few clicks on the gun. I've put the needles back to break in and still can't get any results. It sounds like it's not getting fuel. One thing I noticed is when the line is empty to the carb. and it's cranking over it won't pull any fuel to the carb unless I hold the exhaust closed. Once I prime it, it acts like it wants to start but won't fire up. I've checked the glo plug, replaced it anyway, I've got a fully charged igniter and gun. It sounds like it wants to start but it just can't quite get there. The lines seem clear but I'm not sure about the carb and engine if it's getting clogged. Any suggestions?
       Post #: 209
RE: "OFFICIAL" Redcat Avalanche thread - 4/30/2008 7:42:52 AM
impune
Status: offline
well if it's the carb, just take the glow plug out, drop some fuel in there, put the glow plug back on and attach the igniter and pull. if it kicks over, then the carb is clogged up. doing this and the suction caused may clear it up to run, but should check and see why it was clogged or stuck in the first place.
if i am wrong, correct me. but the worse case scenario is that there is not enough compresion due to the loss of pinch in the sleeve and piston.
i had an hpi that had issues with the carb after sitting every time. if ran weekly it was good sit a couple weeks.. drop the fuel in head and kick i on and your good and fine. never figured out why though. looked clean, but there is a reason and there are some more intelligent guys here to help more than i.
(in reply to Tom W78)
       Post #: 210
RE: "OFFICIAL" Redcat Avalanche thread - 4/30/2008 7:45:58 AM
impune
Status: offline
what is the best way to remove the sh .28 from the avalanche to change the pull cord and bearing? i ordered the roto start and i apparently today greese monkeyed up the darn oneway trying to adjust the needles...
       Post #: 211
RE: "OFFICIAL" Redcat Avalanche thread - 5/1/2008 11:20:18 PM
impune
Status: offline
anyone know the answer to above on best way to remove? just the bolts underneath or the screws from top of engine mount? sh.28 from the avalanche.
       Post #: 212
RE: "OFFICIAL" Redcat Avalanche thread - 5/2/2008 12:48:14 AM
impune
Status: offline
never mind i figured it out myself.
       Post #: 213
RE: "OFFICIAL" Redcat Avalanche thread - 5/12/2008 12:43:31 AM
pede_kid
Status: offline
Has anyone ever used the 11 or 12 tooth clutch bell on the avalanche? How did it do?
       Post #: 214
RE: "OFFICIAL" Redcat Avalanche thread - 5/12/2008 1:28:14 AM
rclynx
Status: offline
gets the front wheels up like the Earthquake used to
Custom Cars bring out the stars / Home of the RCLYNX, RC IMPROVEMENT, MOD, SALES & SERVICE Dealer;XTM, CEN, HPI & much more
(in reply to pede_kid)
       Post #: 215
RE: "OFFICIAL" Redcat Avalanche thread - 5/12/2008 1:52:43 AM
pede_kid
Status: offline
so the 12 tooth cb wouldn't take away too much torque?
(in reply to rclynx)
