Demon-Leather
Joined: 12/11/2001 From: Rex, NC, USA Status: offline
No good with cc's but You can use a standard or metric cooking/baking measuring cup to mix a qt(or Canadian Metric equivilent)... ingredients Metal Can Kerosene (lamp oil/parraffin) Quality Castor Ether/starting fluid 1 roll teflon plumbers pipe-thread tape Amyl-nitrate (ignition-improver) Mix one cup kerosene with one cup Castor in metal can add 2 capfulls Dr Diesels Amyl-nitrate into can teflon plumbers tape threads on can spray entire contents of starting fluid in can in well-ventilated area (good idea to cover can opening around starting fluid nossleas much as possible) Place lid on can tightly,shake well... Serve to diesel at room-temperature through approved gas/diesel fuel line always replace cap tightly Bon-apitite" & happy flying Bob Now,..Before someone gets onto Me about My math,this doesn't make a full quart,but does the job nicely.The can is 12 oz,but spraying it out and losing ether in evaporation,and I never can seem to get the last couple oz out of the can,it makes for a mildly "hot" mix,which is great for smaller diesels. PS: This is pretty standard for ALL size diesels regaurdless of cc or cu.in. some folks up the ether(starting fluid) just a bit for the smaller .55 to 1cc but only by an ounce or so......but you should be roughly 3/4 to 1 oz greater already with the above mix.
< Message edited by Demon-Leather -- May 5 2003 1:43AM >
_____________________________
Demon-Leather Experienced crasher
