RE: ZDZ 80RV New Carb
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> ZDZ & RCS Support >> RE: ZDZ 80RV New Carb
Page: <<   < prev  1 [2]
Login
RE: ZDZ 80RV New Carb - 5/14/2008 10:13:39 PM
gapple12
Status: offline
The Walboro 71 will bring this engine back to life. Going on 30 flights so far since I replaced mine with NO issues. Runs perfect.....
Drew
(in reply to 3D Toy_yoyo)
       Post #: 26
RE: ZDZ 80RV New Carb - 6/22/2008 11:47:44 PM
Hinckley Bill
Status: offline
Hey lennyk...
Could you explain 6-6-1.........I think I know what it means but feel that it's better to proclaim one's ignorance than sit back and prove it.
Oh, I have a Bing carb that's been giving me starting problems after the first flight and I'm going to switch to a Walbro WJ-71
Thx,
Bill
(in reply to lennyk)
       Post #: 27
RE: ZDZ 80RV New Carb - 6/23/2008 5:28:29 AM
juanes1969
Status: offline
5-5-1.. once fuel reaches the carb:
5 flips with full throttle, choke closed, ignition OFF
5 flips full throttle, choke opened, ignition OFF
1 flip high idle, choke open, ignition ON and it should start.
_____________________________
Just fly it!!
(in reply to Hinckley Bill)
       Post #: 28
RE: ZDZ 80RV New Carb - 6/23/2008 12:32:44 PM
Hinckley Bill
Status: offline
Juanes1969
Thanks for taking the time to "make it perfectly clear".........................your help is most appreciated.
Bill
(in reply to juanes1969)
       Post #: 29
RE: ZDZ 80RV New Carb - 6/24/2008 8:35:22 PM
gapple12
Status: offline
Hey guys, I have been doing it a little different and works GREAT!!
I simply turn plane on. Then turn ignition on and full choke. I flip maybe three times and get the pop. Then choke open and flip till it starts. Usually starts about five to seven flips.
When engine is warm, I go ignition on and choke closed. I get a pop on first flip, then choke off and three flips to start.
Hope this helps. I have the older copper version ZDZ 80RV with the WJ-71 carb.
Click to see fullsize image.
Click for fullsize
       Post #: 30
RE: ZDZ 80RV New Carb - 9/21/2008 9:59:37 PM
Andrew_S
Status: offline
is the stock throttle arm on the wj71 usable or do u need to grin t off an use something else?
What do heli''''s and ceiling fans have in common? When the blades stop turnin, You start sweatin ! ! !
(in reply to gapple12)
       Post #: 31
RE: ZDZ 80RV New Carb - 9/25/2008 5:05:47 AM
Oilsands
Status: offline
quote:
ORIGINAL: juanes1969
I use the same except for the last part. I use 1 flip LOW idle (1 click up from lowest), choke open, ignition ON and it starts. Not sure if that is what you meant, but it is what I use.
       Post #: 32
RE: ZDZ 80RV New Carb - 9/25/2008 10:14:58 PM
gapple12
Status: offline
I had to make my own throttle arm. The geometry I needed would not work with the stock arm. I simple made a longer arm and mounted it right on top of the other. Made for an easy fix.
Drew
(in reply to Andrew_S)
       Post #: 33
RE: ZDZ 80RV New Carb - 10/3/2008 11:16:07 PM
Highlights
Status: offline
OK so I also have a new Walbro 71. I am hoping this will resurect my RVJ.
Question?....... what the heck is the third black needle above the Low and High?
       Post #: 34
RE: ZDZ 80RV New Carb - 10/3/2008 11:35:20 PM
Highlights
Status: offline
Never mind. In looking at it I would assume it to be the idle needle. It is tapered and would effectivley raise the low idle if we were to keep it intact for purposes of chainsaws and lawnmowers. In the case of R/C however that feature becomes redundant once the throttle mechanism is sheared and replaced with the control arm.
(in reply to Highlights)
       Post #: 35
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.547RCU1
