johnnyo
Joined: 4/20/2002 From: Overland Park, KS, Status: offline
Samual, just a note, got your email, glad things will work out on the rudder cabels. I noticed your aerlerone set up. I used this same configuation to activate the aerlones on my true scale 1/5 T28 (100" wing). Works great, looks good, no linkage hanging out. Unfortuantly it really does not perform as well as you might think on these large models. I actually used 4/40 steel rods and brass sleaves with no slop in the rod to sleave, very tight fit, no slop. On the third flight we decided to do a bit of a high speed run down the field. lo and behold tremendous flutter from the aerlones. I am using 180oz digitals on these surfaces. Fortuantely do to my over built wing design the aircraft sustained no damage to the wing etc., slowed down and landed. Researching the problem we found that when the servo is in the nutural position there is no mechanical advantage on the servo arm, there is no load on the servo, thus the tiniest bit of slop in this position is going to give you problems. I have since installed conventional set up and have not had another problem. If you keep the T6 in a conservative flight mode you may not have a porblem, however, get the power up and the nose down for that impresive low fly-by. be ready. I know there are some large models being flown with this set up, such as Bob Pattons 120" T28, Bob is a very good but pretty conservative flyer and doesn't really push the his aircraft. So just a word to the wise, been there, done that. Great build article johnnyO
