samparfitt
Joined: 9/1/2002 From: West Chester, OH, USA Status: offline
Al, Not sure how well the Frisket will go aroung sharp corners. When doing really tight corners, I've used masking tape on a piece of glass and cut off very thin pieces with a razor blade and metal straight edge and then use tweezers and toothpicks to push it down. I haven't used the Frisket yet but it may work like the masking tape. The masking tape works well because it takes compound curves very well when it's only 1/32" wide or less. It's more work using thin pieces but you get the tape exactly where you want it. Except for flat surfaces, masking tape needs to be cut down to thin pieces to get good results. Even flat surfaces should also have the one side cut to remove any fuzzies. Also, buy 3M (or other high quality) masking tape found at your local auto store that has a paint department: stay away from the cheap 'big box' masking tape. Also, for small detail pictures, modeler's paint work best because of the very fine pigment used in their paint. You also might try this liquid mask: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXC099&P=M
< Message edited by samparfitt -- 2/10/2008 5:08:13 PM >
_____________________________
G. Samuel Parfitt
