Tigger N. Bennie
Older Callaway Corvette, C-12. What about a Callaway C-16. http://www.callawaycars.com quote:
650 bhp (SAE) Supercharged 6.2 liter (378 cu.in.) V8, 90°, cast aluminum block and heads; 6-bolt cross-bolted main caps; Supercharger- Eaton/Magnuson Roots-type; with air/liquid intercooler integral to intake manifold. 44" Hg manifold pressure, absolute. (7 psig) Bore x Stroke: 4.060 x 3.622 inches Compression ratio: 10.4:1 Torque (SAE) 585 lb-ft @ 4,750 rpm Redline: 6,500 rpm Fuel system: Increased flow (42 lb/hr) fuel injectors; auxiliary fuel pump controller Ignition system: coil per cylinder; Callaway UHC-8 sleeved silicone ignition wires Throttle body: 90mm diameter, drive-by-wire From last November 2006: http://www.callawaycars.com/callaway/main/contentpages/press/C16LAShowReleasefinal.pdf quote:
The Callaway supercharged 6.0-liter LS2 V8 produces an impressive 616 bhp at 6,200 rpm and develops 582 lb-ft of torque at 4,750 rpm. The Callaway C16 does 0 to 60 in 3.3-seconds, and a quarter mile in 10.9 seconds. Top speed of the manual transmission coupe is 206 mph. Equally impressive is its fuel efficiency rating of 18 city/28 highway. It is emission compliant worldwide. quote:
ORIGINAL: RCadmin Wow is all I can say. This thing will push like in excess of 650HP and do low 3's for the zero to sixty runs. That's better than all the 300k plus ferrari's and lambos. The ZR1 vette will cost about 100 grand. Trying to spend that $20M already? Granted, the Callaway costs more than the ZR1 vette; however, I used to belong to one of the largest corvette clubs in the USA and there were numerous people who either owned and/or had owned a ZR1, but I never met one who owned a Callaway. My point: if you really want to stand out in the corvette community, perhaps a Callaway is the way to go and been seen.
< Message edited by Tigger N. Bennie -- 12/21/2007 3:39:45 AM >
_____________________________
Lots of RCs, two cats, and two Nikon cameras.
