coro_sk
quote:
ORIGINAL: nonstoprc The balancer idea should work, although A123 cells are less prune to overcharge risk than liops. Why inline diode idea does not work in this case? I have no Triton to confirm exactly its behaviour, but most of chargers will try to confirm pack voltage first, and they will find no voltage at all (thru diode). Perhaps any big resistor in parallel to diode may help, but I am not sure. Well, knowing that A123 pack can be charged at very high currents, You should consider also power looses over the diode - it will heat and may be destroyed. Thermal load is equal to lost power, amps multiplied by diode voltage drop, e.g. 0.5V * 5A = 2.5W and it will heat much over a small diode. Such problem is exactly comming with charging transmiter battery, there is a diode and users have to bridge it to charge TX using charger. (I recall charger Jamara X-Peak 3 did charge thru diode, and it was considered rare.)
< Message edited by coro_sk -- 12/22/2007 1:33:50 PM >
